Finally got some new cross drilleds!
I got Zimmerman Cross Drilled rotors and Akebono ceramic pads!
Here are my original rotors (notice you can actually see the lip!!
Here are the new ones on my car, sorry I didn't get a better picture
And the new pads
Also, as a side fix
Look at my old flex disk
I've only got the fronts on right now and my old ones on the rear and it is a night and day difference!
I absolutely love them
I just hit 160,000 miles last week
I only did the front. the rear looked just fine except for a hairline crack, I will probably change that out next year, my mechanic did it for just $130 for me
I got a free mercedes multi point inspection in the mail and they let me know every little detail that is wrong with my car, and the flex disk was on there, so I am slowly doing each one of those.
If you can get under the car, you can easily see the two flex disks and if they need changing or not
thanx
did you put your old 334mm rotors on the rear axle, is it what you're saying?
if yes do they brake good with the wrong rear pads?
when i said old, i just meant they haven't been changed yet
As far as the flex discs I changed mine out as soon as I bought my C43, it was literally the first thing I did. $90 per disc and 15 minutes to change them out, it was SIMPLE
I didn't know how serious the flex disk issue could be if they gave out
If I knew I would have done the same thing as you, change them when I got the car that is!!
