OBDII Bluetooth + iPhone apps
I have already downloaded a couple apps and can't wait for the bluetooth device to arrive so I can try it out.
Here is a link to the bluetooth device I bought for $25 on ebay:
http://cgi.ebay.com/ebaymotors/ELM32...QQcmdZViewItem
Here is a function list:
Functions
- Read diagnostic trouble codes, both generic and manufacturer-specific, and display their meaning (over 3000 generic code definitions in the database).
- Clear trouble codes and turn off the MIL ("Check Engine" light)
- Display current sensor data: Engine RPM, Calculated Load Value, Coolant Temperature, Fuel System Status, Vehicle Speed, Short Term Fuel Trim, Long Term Fuel Trim, Intake Manifold Pressure, Timing Advance, Intake Air Temperature, Air Flow Rate, Absolute Throttle Position, Oxygen sensor voltages/associated short term fuel trims, Fuel System status, Fuel Pressure
I will post results once I get the OBDII device, should be in a week or less
Yes please, keep us informed of the results
I thought the CEL light was the big yellow triangle in the speedo dial which lights up when something is really wrong? All the other little lights are for other "minor" problems
Here is a vid that shows the same OBDII bluetooth transmitter I bought, @ 9:49 or so into the video you can see where he has it connected:
http://www.youtube.com/watch?v=Ay-ZvTn3fLo
seriously euro cars never had the CEL.
when my o2 fokked up I didn't know what was wrong with my car and I kept driving with it.
with a CEL I would have known something was bad.
all the time I thought my transmission was going bad until I got the codes for bad o2.
P.S. Where do you download the apps for iPhone?
Ivan bagged out
We plan on doing one in a couple weeks once I have my painted rotors and calipers installed and he installs his new avantgarde grille, I have been SUPER busy lately and have a pile of parts (rotors, pads, SS brake lines, e brake kit) to install on my car but have had no time
That sucks. Nevertheless, I am looking forward to see that the photoshoot will happen anytime soon. I want to see your C43's upgrades so bad. Makes me so envious...
Here is a screen shot from the WIS, it is shown on a W210 but the WIS states it is in the same location on a W202 and judging from the picture I believe it to be true. This is a screen shot of a EOBD (Euro OBD):
X11/4 (rectangular plug) is the location of the OBDII connector, the one under the hood (circular plug) appears to be the connector for the SDS.
When I had to change my MAF, my mekanik plugged this black plug with millions
tiny small pin holes for reading codes, this I know about.But
When you open the passengers door, not the underside plastic cover where the cabin filter is located!
It's on the side of the dash there is a small plastic cover if you pull it, there's somekind of round pin connector??
What is that 4?
What is that 4?
What is that 4?
Seems like I've seen that round plug before . . . . . . .
But back to the other round plug.
Btw, whatever happened to the weekend photo shoot of two C43s with a buddy of yours?
