Misfires
I gunned it on the highway and the engine light came back on, and has gotten increasingly worse. Same code of Random cylinders. I recently put in MB sparkplugs. No oil leaking in them.
Now it will just pop code even without putting it in drive. It'll close down power to about 20 mph max.
SO next suspect was the over due coil wires. Only 10 of the 16 came in from UPS. They vary in length. I wanted to re-do the side I just worked on and used 9 shorter wires. The code was reset and is still an issue. (If the wire will reach its not a major issue is it??)
PCV valve had a crack but would that really cause an issue like this?
What to do with this Love Hate relationship. Anyone have similar issue?
Mas Airflow Sensor being next suspect? I tapped lightly 3x on the MAF Sensor light with 3 fingers over the top to see if anything would change in idle. It stalled out. I was able to repeat the failure. I am not covering the hole over depriving it of air. Just a tap 1-2-3 and it cuts out. NO MAF code is showing on the OB2 reader I have . Just P0300 code (random) and every once in a while narrows down what cylinder misfired.
Cleaned the MAF sensor, no change. Ran some codes on it and Cylinder 2 and 7 were a constant of the random misfires. Others do code but 2 and 7 are main ones. I swapped coil packs and got the same results so its not coil packs.
Mechanic says bad gas would had caused all cylinders to go goofy.
Running a smoke test and compression test next. Any advice here?
http://www.benzworld.org/forums/w163...esponse-2.html
Grane its almost empty, I will be adding shell 93 into it. I always run the high test but admit I did fill up in PA "sheets" gas stations quit a few times prior to this.
Wouldn't the CAT converter pop a code if it were the issue? Gonna try taking out a 02 sensor and see if the bong hole chamber will help. If not I am gonna need a bong to get through this....I keed, I keed.
Wouldn't the codes for a bad o2 sensor come up somewhere???
Is there a way to test em vs keep throwing money at it? I'd be all for replacing em all if i knew it was it.
Unfortunately my car is 7 yrs shy of being allowed to go straight pipe in my state. I guess I could for now, but eventually have to replace them.
Has anyone drilled out their cats vs putting on straight pipes?
What is going to be an easier job (for the long run also)
A. Go straight pipe until emissions day. Then take on a Magnaflow type converter.
B. Drill out the cats. Then put in new cats when time comes.
I am looking to do this job fast as possible. Car has been down for to long at this point. I wish I knew of a shop that could just take care of it.
Any suggestions appreciated.
I was quoted about $100 to straight pipe the two secondaries, which I think I will probably do in the fall - but we don't do emissions testing at all, so I can get away with just about anything. I think in your case, you should probably get new cats now and be done with it - otherwise you're gonna be going in there twice to cut and weld.
BTW, is your name really Frank or are you a big fan of the Punisher?
I am not sure if its called primary or secondary
. I was hoping i could separate them, and split it apart enough to be able to get into it to hollow it out. I think your right...penny wise pound foolish. I will have to revisit the issue again. I really dont want to wait for the part to come in though.I looked at Magnaflows site and C43 is not an option? It had C36...what gives? C36 same 3" pipes?
If the O2 sensors are the original parts, you may want to replace them. Unless the heater is dead, they throw a code long after they stop working.
Magnaflow comes up with zero product for the cat
Summit racing came up with Magnaflow 9905HM for it. So.........?
CLK55 is the same? What year ranges sync up with the C43.
FUN FACT: Out of curiosity I have called around Meineke had quoted me $2k upon hearing Mercedes.
503, you had deleted your 2nd cats. Any issues with emissions or codes ?
Did you keep primary? I am looking for possible replacement cat and zero luck on here or the interetsss.
I had my secondary cats removed and kept the primaries. I have had it like this for around a year with ZERO issues, no CELS, passed DEQ, and sounds NICE!!!
I plan on installing the kleemann headers which delete the primaries. I will be installing 300 cell metal cats where the secondaries were. As long as the O2 sensors are rerouted there should be no issues.
