C43 bigger throttlebody
8mm,, unfortunately i don’t have pics., but you can go to: http://m.www.mbworld.org/forums/showthread.php?t=368196
as example........
ZAYED,,
as example........
ZAYED,,
What kind of gains are we talking going from a 74mm to an 82mm? Isn't there other modifications that should be done to take advantage of the bigger TB?
C32K/SLK32K/55sK # "112 078 03 49" or "113 078 01 23", then reprogrammed the ECU, after that im soo happy about results,,
unfortunate no dyno, but big difference NOTICED........
ZAYED,,
Is it possible to connect an E55 W211 TB?
Is the plug the same?
you after i finish my duty...........
ZAYED,,
to swap........
ZAYED,,
I´m the Owner of the C43 Supercharged...
Now, today we tryed to change the TB of my C43.
I´ve took the TB of my friend munich55. We connect
the wire of the engine with the e55 TB with the same
colours...
Unfortenetly it´s not working... It´s not relevant, how we
teach the TB, manual or with Star...
Please help
Hamburg, he Thankfully gave me the wiring diagram of the M113 TB, 2 years ago,, also im already swapped the round connector to the square one, i
didn’t noticed any difference between the colours......
https://i.imgur.com/CmkKx.png
ZAYED,,
The Problem is, there are two wire´s which got not 100% the same colours,
they didn´t match to each other...
Black, Blue, Yellow, White -> Clear...
But Purple and Grey!
The e55 TB got a "lightpurple" wire and also the "unknown colour"
If you connect the lightpurple to purple and the unknown to grey, it´s not working. Also when you change them, no chance...
After both connections, we tryed to teach the TB with star. Normally if you teach the TB with star, you can hear automatically working the TB, it is not doing that... Also there is a error report after:
M16/6 (stellglied drosselklappe) istwert-potentiometer
M16/6 (throttle control element) actual value potentiometer (Translatet with google
) The manual teaching of the TB is also not working ;(
Regards
Aziz
