Rear diff fluid?
Rating: Thread Rating: 2 votes, 5.00 average.
Old Feb 5, 2012 | 02:37 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
Rear diff fluid?
I am looking to replace the fluid in my rear diff. Is this the stuff I want?
Liqui Moly
Miscellaneous Fluids/Treatments; Gear Oil, Synthetic; 75W-90, 1 Liter
This gear oil is recommended for manual transmission, transaxle, or rear axle differentials requiring specification API GL-5, please verify prior to ordering. Meets specification API GL-5 and MIL-L-2105C/D.
Old Feb 5, 2012 | 02:45 PM
320 dreamer's Avatar
2003 porsche 996 turbo
do you have a lsd? do you need inhibitors ? i used mobil 1 in my oem diff and it worked fine for my wavetrac i use motul synthetic with no additives
Old Feb 5, 2012 | 02:51 PM
No LSD yet, just looking to replace the fluid in my stock diff.
Is this the stuff you are referring to?
http://www.mobiloil.com/USA-English/..._75W-90LS.aspx
I just found a post from speedybenz and he is saying he uses Red line shockproof light weight gear oil, anyone else use this??
http://www.redlineoil.com/product.aspx?pid=43&pcid=7
Old Feb 5, 2012 | 04:55 PM
importfan21's Avatar
1998 C43, 2017 Honda Accord Sport
You need 1.4qt (1.3L) of Hypoid Gear Oil SAL 85W-90.
(according to the owner's manual)
Old Feb 5, 2012 | 11:32 PM
Super B's Avatar
'97 c36
I just threw in some napa premium hypoid gear oil.. not saying you should but really nothing special about the non LSD diff in our cars. Let me know if you have a problem getting those allen drain/fill plugs out. I had to drop the muffler to get in there with a small torch to heat and wd-40 the crazy stuck fill plug. I also had to cut down the allen wrench to get the clearance needed. Hopefully yours wont be as stuck...
Old Feb 6, 2012 | 01:20 AM
cm60k's Avatar
Im always using "Castrol SAF-XJ (75w140)" from MB # "001 989 52 03/10".........
ZAYED,,
Old Feb 6, 2012 | 11:53 PM
Attachment 227945
ZAYED,,
This is ok to use in the stock C43 diff?
Old Feb 7, 2012 | 03:03 AM
DRBC43AMG's Avatar
Why not! It is fully synthetic and top quality stuff mainly used for high performance vehicles and for AMG models with LSD. It looks like Zayed has quoted an older oil at it has been replaced by this one.
Some details:
cm60k's Avatar
Sure Jason,, im using this oil with all cars, since 4 years.........
ZAYED,,
Old Feb 7, 2012 | 03:06 AM
cm60k's Avatar
Some details:
ZAYED,,
Old Feb 12, 2012 | 02:16 AM
KJWHIT's Avatar
1998 C43 AMG
how hard was this to change your rear diff. oil?
Old Feb 12, 2012 | 03:29 AM
cm60k's Avatar
Its soo easy, just jack up the car & remove the diff. oil screw, let the old oil to go, then put the new oil, and prefer if you add "2" bottles of oil
additive from "MB or Mugen sieki super silicone 3000 or 5000".......
ZAYED,,
Old Feb 12, 2012 | 04:05 AM
DRBC43AMG's Avatar
I didn't know that Mugen or MB made or even recommended their "snake" oils
Have you some details specs?
Old Feb 12, 2012 | 07:44 AM
cm60k's Avatar
I don’t have that info about it,, as i know: its a synthetic concentrated formulated additive designed to help lubricants to reduce a friction point
in the gears & pinions, as example; Amsoil also recommend it with there lube products,,
http://www.amsoil.com/storefront/ada.aspx
ZAYED,,
Old Feb 12, 2012 | 04:34 PM
I just bought some Royal purple full synthetic 75w140 as my local parts store was out of the Castrol and Mobile 1.
Anyone have any experience with royal purple?
Old Feb 12, 2012 | 10:49 PM
cm60k's Avatar
Royal purple is also a very good choice 75w140, they have a same formula specs. of "Liqui moly & Würth",, if you can add "2" bottles of
additives, it well be great.......
ZAYED,,
Old Feb 14, 2012 | 02:46 PM
Super B's Avatar
'97 c36
how did it go? Fill or drain Plugs stuck?
Old Feb 14, 2012 | 05:02 PM
I am replacing the fluid on Thursday but I will let you know how it goes
Old Feb 15, 2012 | 03:16 AM
DRBC43AMG's Avatar
Will also be doing mine when I get around doing my "Spring season" updates and mods in April when I will have all the time in the world (retirement) to get my hands oily
Old Feb 16, 2012 | 11:18 PM
Changed the rear diff fluid today with Royal purple 75W140 full synthetic and all I can say is WOW!
I decided to change the fluid after looking through the WIS and noticing they recommend changing the diff fluid every 2 years. I checked my records from the last "B" service I had performed and noticed they didn't change the diff fluid (I wish I knew why ) so since I have had my C43 for 2 months shy of 2 years I figured it was due. The difference is astounding! My car is SOOOOOO much smoother I wish I had done this sooner.
I changed out both of my flex discs as well as the rear had 2 cracks in it, the front turned out to be fine but I wanted to get them both changed while I was down there.
I will posts pics of the flex discs and the cracks later.
Old Feb 17, 2012 | 01:58 PM
Super B's Avatar
'97 c36
That's interesting. I wouldnt have imagined the diff fluid change would have made that much of a difference. I wonder how much that smoothness came from the flex disks. Did you check the centering bushing for wear while you had the drive shaft down?
Old Feb 17, 2012 | 02:10 PM
JohnnyRock's Avatar
1998 C43 AMG
503, I've seen this "WIS" referenced numerous times here. I'm assuming this islike the Bentley manual for BMW's? The maintenance guide for all things Benz?
Old Feb 17, 2012 | 06:02 PM
I had changed the center support bearing a little over a year ago and it was fine. I questioned if the smoothness came from the flex discs as well but the front disc looked almost new and the rear had 2 small cracks in it, only conclusion I could come to was the diff fluid was old and burned up
Old Feb 17, 2012 | 06:06 PM
WIS = Werkstatt informations system (workshop informations system)
It is the electronic guide for all benz vehicles that was created by MB for MB dealers and mechanics
Basically tells me everything about any MB vehicles
Old Feb 17, 2012 | 09:04 PM
Super B's Avatar
'97 c36
Right on, either way good thing you did it. Did you run a magnet through the old oil to check for any metal? As well as you take care of her, your 43 is going to last you forever.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
