Brake disc C36, is it hard to DIY ?
Old May 29, 2012 | 10:05 PM
cassard's Avatar
C36 AMG 1996 black on black
alright, I need to change my disc on my car, I would also do the Pads. But I mainly need them in front.
First question : should I do the 4 in the same time ?
also : is it hard to do by yourself and is there any video's that could help ?
Old May 29, 2012 | 11:37 PM
bagelsjustbagel's Avatar
In search of W222
Not hard to do it yourself. Get a Brake Pad tool (one that pushes the pads apart this way you can put the caliper back on) you will also need an allen wrench.
And probably a rubber mallet. Its also a good time to change your bearings while you have the rotor off Very simple however, just release the caliper first, then take off the rotor, exchange parts, and reverse.
Old May 30, 2012 | 01:44 PM
cassard's Avatar
bearings have been done 2 years ago.
is it ok to do only the 2 in front ? or I have to do all of 4 of them in the same time ?
Old May 30, 2012 | 02:52 PM
DRBC43AMG's Avatar
Why do you need to change the bearings after only two years since the last time? Not unless you have done some MEGA miles
Not necessary to do the rears at the same time. That is a pitta to do and best get done by a pro
Old May 31, 2012 | 11:04 AM
cassard's Avatar
oh, I don't want to the the bearings, I forgot to say that it's not necessary to do them since they were done 2 years ago, sorry xD
Old Jun 5, 2012 | 10:39 AM
cassard's Avatar
I thought about Putting Regular Brembo Front disct and Akenobo Pads. Is it a good combination ? I don't want high performance brakes but still I want go durable ones.
Any other suggestions ? *I don't have infinite budget either*
Old Jun 6, 2012 | 04:08 PM
cassard's Avatar
Bump, Please I really need to be sure it's a good purchase that I'm going to do.
Old Jun 6, 2012 | 08:47 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
I'm using Akebono pads right now and have no complaints
Old Jun 7, 2012 | 04:19 AM
DRBC43AMG's Avatar
I imagine that with Brembo rotors you should not have any problem either. Don't forget that they are a world leader in the brake domain
Old Jun 7, 2012 | 10:35 AM
cassard's Avatar
oh and is there any difference between US and Europeen models ? because I see sometimes written : For EU or US
but as far as I know 1996 C36 are the same everywhere.
Also I saw 2 different Brembo Disc : one with
5 lugs
288 mm disc diameter
25 mm thickness
22.4 mm minimum thickness
46.5 mm height
and the other with :
5 lugs
316 mm disc diameter
28 mm thickness
25.4 mm minimum thickness
46.5 mm height
both fit ?
Old Jun 7, 2012 | 03:40 PM
LawRens's Avatar
43
5 lugs
25 mm thickness
46.5 mm height
5 lugs
28 mm thickness
46.5 mm height
both fit ?
288mm is the rotor size for the rear, 316mm is the rotor size for the front.
