Vogtland suspension "kit"
Old Jul 23, 2012 | 10:06 PM
Dziner82's Avatar
99 C43 AMG, 2001 CLK55 AMG
hey guys,
have done a fair amount of shock/spring research on here and found some discussion between the bilstein part #'s and various springs, but i haven't seen anyone mention this shock/spring kit from vogtland:
http://www.vogtland-na.com/sportsuspension.asp
is there a reason that no one seems to be running this setup?
thanks for any feedback.
Old Jul 23, 2012 | 10:10 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
Originally Posted by Dziner82
hey guys,
I have never seen that kit before...
Old Jul 23, 2012 | 10:30 PM
nkctb7's Avatar
2006 E55 AMG/1996 C36 AMG/1999 C43/55 AMG/2021 Toyota Tundra Crew Max TRD Sport Premium
hey guys,
If you look into the right kit for the C43 it is a non adjustable kit and paired with Bilstein shocks. The adjustable kit that is offered is paired with Koni shocks but is not for the C43. It varies by vehicle make and model. The Billy's are black and the Koni's are yellow. The junior and cup kit applications for the C43 are both non adjustable. Hope that helps.
Cheers
Old Jul 24, 2012 | 12:04 AM
nd4spd13's Avatar
1995 C36 AMG, 1998 C43 AMG
Cheers
The Bilsteins in the kit are black? Pretty sure that would mean they are B4s or B6s, so not the B8 sports, and not meant for springs that lower the car >1" from stock height. odd.
Old Jul 24, 2012 | 03:17 AM
nkctb7's Avatar
Both Bilstein and Koni must make specially designed and specifically tuned shocks to run in conjunction with the Vogtland kits. The Vogtland name is then stamped on them. Just like the stock Billy's have the Mercedes logo on them. It's really the best of all worlds for the shock and spring manufacturers as their sales increase across the board.
Old Jul 24, 2012 | 04:20 AM
DRBC43AMG's Avatar
B6's and B8's are BOTH yellows in official Bilstein catalogue
Old Jul 24, 2012 | 09:25 AM
Dziner82's Avatar
Thanks for the feedback, I thought that maybe they were actual vogtland shocks. So it seems like this would be a good kit? From what I've read on the forum vogtland is a trusted name and would not be using shocks that don't perform well with their springs.
I can always give them a call when I'm closer to purchasing.
Old Jul 24, 2012 | 08:43 PM
nkctb7's Avatar
It is like the generic products in a grocery store that are made by leading brand name suppliers. Vogtland has deals in place with both Bilstein and Koni to supply the shocks for their kits and put the Vogtland name on them. IMHO, Vogtland coils are the BEST that you can buy. There is a reason that many H&R and Eibach users are switching to Vogtland. In short, Vogtland springs will NOT sag over time like H&R's and they have the closest to stock ride feel, unlike the extremely harsh ride of Eibach's. Best of all, they vastly improve the handling and looks by offering a raked and aggressive stance.
I purchased my first set of Vogtlands long before many even heard of them. I was extremely impressed with the quality and ride. You will not find a better coil PERIOD.
Cheers
Old Jul 31, 2012 | 04:27 PM
mkoons's Avatar
1999 C43
Hi NKCTB
I need to replace my shocks & will do springs also. Since you are very pleased with the Vogtlands tell me how much drop you got & what shocks did you go with. The Billy Sports seem to be the most popular. I don't want to go with a harsher ride than what I have now.
Old Jul 31, 2012 | 11:51 PM
Originally Posted by mkoons
Hi NKCTB
Vogtlands claim a 1.4" drop but I believe that to be based off of the Euro springs which are already lower than the U.S springs, I dropped close to 1.4" with the largest spring pads possible. I have the bilstein sports and couldn't be happier with the performance
The ride is very firm
Old Aug 5, 2012 | 10:32 PM
nkctb7's Avatar
Hi NKCTB
I ended up with just under a 3" drop in the front and 2.5" in the rear. My mistake was going with #1 pads all around as it was far too low for everyday driving. I was running Koni yellow sport adjustables and was completely happy with the ride but it was a little too low. Also, I was running that setup on my former '99 Kompressor.
I just purchased #5 pads for the front and #4 pads for the rear to run with Vogtland sport springs for my '99 C43. I am still debating on the shocks but am leaning towards the Koni's again as I like the adjustable option of changing the firmness of the ride. I also know what to expect with Koni's as I keep hearing that the Billy's are pretty firm. Like yourself, I wanted to avoid having a harsh ride and I'm positive that you will like the Vogtland/Koni setup just as I do. I can't say enough of just how impressive that combo is. Hope this helps you make your decision.
Cheers
Old Aug 6, 2012 | 02:06 PM
mkoons's Avatar
1999 C43
Thanks for all the info---
Been searching for the Koni adjustables, not finding anything for c43. Are you using a clk application? Where can you buy the sports and do you have parts numbers?
Thanks again.
Old Aug 6, 2012 | 07:07 PM
nkctb7's Avatar
Thanks again.
There is no application for the C43 but they are available for the C36. Here's the link for the best prices.
http://www.tirerack.com/suspension/S...7&autoModClar=
Cheers
Old Aug 6, 2012 | 07:45 PM
nd4spd13's Avatar
Cheers
Not this time! Usually tirerack is best, but AJUSA has much better prices for the Konis.
Old Aug 10, 2012 | 07:13 PM
mkoons's Avatar
1999 C43
Which Koni are you using, at Tire Rack I see a twin-tube for $163. or a mono-tube for $116. What's the difference, I believe the less expensive one is not adjustabe.
Old May 12, 2013 | 05:07 PM
FlyWFO's Avatar
1999 C43
Converting into layman's terms, the black bilsteins are the same as the Touring model on tire rack(?)
Old May 12, 2013 | 05:27 PM
FlyWFO's Avatar
1999 C43
Cheers
Do/did u have the Vogtland shocks? Or were u leaning toward koni to replace konis u already had? Wondering if the Vogtland shocks are too stiff..
Old May 13, 2013 | 01:10 AM
Super B's Avatar
'97 c36
wow pricing stuff out its not to bad but mb arts camber arms... Wow.. Seems like a lot for some spherical ends on a threaded tube. They sure are pretty but...spendy.
So looks like after adding it up about 1,450 dollars in parts for vogtland springs, koni sports, mb arts rear, kmac front and alignment shop.
Old May 13, 2013 | 02:47 PM
nd4spd13's Avatar
If I were you I would throw on the springs and shocks and then see how bad camber is. I've put probably about 6k miles on my summer tires so far and the inside corner is still as fresh as the outside
