Calipers for sale
Old Jul 29, 2012 | 11:15 AM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
Calipers for sale
I posted this in the classified section:
https://mbworld.org/forums/suspensio...ml#post5301151
Old Jul 29, 2012 | 05:33 PM
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
Calipers for the w208 clk55 are 4 piston.
Old Jul 30, 2012 | 06:43 AM
dearlove's Avatar
190e & c36
and so are the c43's
Old Jul 30, 2012 | 08:43 AM
ProjectC55's Avatar
What year c43 are you referring to because my c43 only has dual piston calipers. I believe your info is totally incorrect.
Old Jul 30, 2012 | 12:05 PM
dearlove's Avatar
190e & c36
ok, well im presuming they didnt down grade form the c36, thats all
Old Jul 30, 2012 | 12:30 PM
cm60k's Avatar
As i know: W202 C43/C43 Wagon & W210 E50/E55/E55 Wagon & W208 CLK55, all those models equipped with "4-piston Fronts & 2-piston Rears",,
*Front Calipers #s
L: "HWA 210 420 01 83" or "HWA 210 421 01 98"
R: "HWA 210 420 02 83" or "HWA 210 421 02 98"
*Rear Calipers #s
L: "001 420 37 83"
R: "001 420 38 83"
ZAYED,,
Old Jul 30, 2012 | 02:26 PM
ECTurboGSX's Avatar
98 C43, 15 Alfa 4C LE, 18 Tesla Model 3 DM Perf, 08 Duc S1000, 02 Duc 998, 98 Duc 748, 01 Miata
Nah, C43, W210 E55, and W208 CLK55 all use sliding 2 piston calipers on the front. Here is a link and the attachment has a picture of a 2002 CLK55 front caliper. You can all walk out to your garage and verify that the C43 has a two piston sliding front caliper. And hopefully you can just take my word for it on the E55. The 4 piston fixed caliper front brakes accompanied the arrival of the C32 and W209 CLK55.
http://www.benzworld.org/forums/w208...rotor-diy.html
PS: Yes, the C36 has four piston fixed as well. They are different between the C36 and C43.
Old Jul 30, 2012 | 02:29 PM
DRBC43AMG's Avatar
You are perfectly right Two piston sliding calliper
Old Jul 30, 2012 | 03:18 PM
LawRens's Avatar
43
Right on the money.
Old Jul 30, 2012 | 03:19 PM
cm60k's Avatar
That’s strange...??!!,, im my C43, I got "4" Pistons if front Calipers...!!,
are they original or someone changed them.......!!>!!?>!!?!!
ZAYED,,
Old Jul 30, 2012 | 03:25 PM
KJI3jflarryfe93's Avatar
ZAYED,,
habibi dude, take a picture of your calipers and show us
Old Jul 30, 2012 | 03:27 PM
LawRens's Avatar
43
ZAYED,,
As in, four pistons on the side that faces you? Or are you assuming that there are two pistons on each side of the brake caliper?
Old Jul 30, 2012 | 03:35 PM
cm60k's Avatar
Yes, maybe the side view shows "2" pistons in each sides,, i well check them & see.....!!
ZAYED,,
Old Jul 30, 2012 | 04:21 PM
LawRens's Avatar
43
ZAYED,,
This isn't a c43 brake setup, but the design is pretty much the same. If you look closely at the caliper, there are only two pistons, which are on the inside section of the caliper. The same should run true for the c43. What you see on the outside (between the rotor and you) is just the brake pad and the caliper holding the pad in place. The actual pistons that apply the pressure onto the brake pads are on the inside (between the rotor and the suspension), which you cannot see unless you pull the brakes apart, which is conveniently shown here..
p.s. 503, you must be loving the free bumps
Old Jul 30, 2012 | 04:37 PM
cm60k's Avatar
Thankss for the Pic., i well see closely what i got & let you know......!!
ZAYED,,
Old Jul 30, 2012 | 08:02 PM
W202, W208, and W210 all use same calipers as most have posted above. I checked the WIS before I posted to make sure I wasn't posting erroneous info...
I wonder what makes ProjectC55 think otherwise
Old Jul 30, 2012 | 08:14 PM
ProjectC55's Avatar
The 96 to 97 C36 have two piston calipers while the 95 has 4 caliper pistons. Wierd thing is I've seen some CLK430's with 4 caliper pistons as well. I thought theree were some CLK55's with them but now I wonder if it was an option. I've seen alot of pics with CLK55 W208's with the 2 piston calipers. I was just checking it out.
I guess I was wrong about the w208 clk55 but the CLK430's w208 I have seen with the 4piston calipers so I guess I assumed the 55 was the same.
Old Jul 31, 2012 | 07:52 AM
DRBC43AMG's Avatar
Check the photos here:
https://mbworld.org/forums/5199881-post61.html
Defo 2 pistons and sliding calliper
Old Jul 31, 2012 | 04:11 PM
ProjectC55's Avatar
Since the 2k car was a little different than the 98 and 99 C43 , meaning Rims and tranny ,I wonder if that was the only C43 with 4 pistons if in fact it had 4 piston calipers that year only?
Old Aug 7, 2012 | 10:34 PM
winks911's Avatar
2006 C55 RENNtech
The 2000s had the same 2 piston up front and weighs a ton.
Old Feb 9, 2013 | 05:10 AM
dearlove's Avatar
190e & c36
i know this is an old thread, but my '96 has 4 pistons front calipers, just for anyone who happens to read this thread...
Old Feb 10, 2013 | 05:14 AM
DRBC43AMG's Avatar
I believe the earlier (?) c36's where different than the 43 in the brake area with smaller 4 piston calipers, but I stand to be corrected.
