c43 O2 fault? Check Engine Light, Going Bad??
Old Dec 11, 2012 | 07:44 PM
vlad957's Avatar
1998 C43 Amg
Recently I noticed my check engine light went off. So I plugged in the Scanner into the obd2 computer and it showed me an oxygen sensor fault. The first thing that came to my mind. Is that it might be the secondary's that I deleted. Or I need to do a tune. Or the oxygen sensors are going bad. Does anyone know where I can order oxygen sensors for a good price? And if there are Oem ones that I can order. And has anyone ever had this problem. Im not sure what the Error code was but it said something like 02 sensor and some number like p09---.
Old Dec 11, 2012 | 09:57 PM
mkoons's Avatar
1999 C43
I have replaced O2 sensors 2 times, $700. a crack at the dealership.
Here in Calif we can't do our required bi-annual smog cert with a engine alert light on, which is usually the CO2 sensor, a real failure prone item in these cars.
Old Dec 12, 2012 | 11:05 PM
MarcusF's Avatar
2002 CLK430
Bosch makes three O2 sensors for your car – universal fit, direct fit, and the OE part. I've personally had all three. If I were you, I'd buy a pair of direct fit sensors from Rock Auto dot com. Your's are $75 for the left side and $80 for the right.
Before installing them, you may want to make sure they plug directly into the wiring harness. If they do, you’re set. If they don’t Rock Auto has a fantastic return policy. How is it that I've had all three? Well . . . . . . . . lets just say I found out about their return policy about that time.
But that was 2 years ago and the catalogs have been updated.
Old Dec 18, 2012 | 05:13 AM
vlad957's Avatar
1998 C43 Amg
I found some on this websitehttp://www.partsgeek.com/catalog/1998/mercedes/c43_amg/fuel_injection/oxygen_sensor.html Do you know if there any good?
Old Dec 20, 2012 | 07:22 PM
svt ricco's Avatar
1999 C43 AMG
Bought all 4 from this site, $297.50 shipped. Installed it last week, passed smog this morning!
Old Dec 25, 2012 | 12:20 AM
vlad957's Avatar
1998 C43 Amg
Why do I need 4 I thought theres only 2. A left and a right?
Old Dec 25, 2012 | 01:09 AM
nd4spd13's Avatar
1995 C36 AMG, 1998 C43 AMG
Two on each bank (side), one pre-primary cat and one post
Old Dec 25, 2012 | 05:46 AM
KJI3jflarryfe93's Avatar
lucky me, I only have two o2 sensors.
this is a cheaper solution for me
Old Dec 25, 2012 | 06:04 AM
DRBC43AMG's Avatar
N. American versions come with 4 o2 sensers, while European versions have two on the primary cats only
Old Dec 25, 2012 | 09:51 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
Can anyone confirm these are the correct part #'s for the o² sensors?
Bosch 15088 Upstream left
Bosch 15090 Upstream right
Bosch 15092 Downstream right
Bosch 15094 Downstream left
Old Dec 26, 2012 | 02:17 AM
svt ricco's Avatar
1999 C43 AMG
easier if you have access to a lift, the one under the passenger side is a pain to get to. i rented an o2 sensor tool, still wasn't able to take it off, ended up bringing it to a muffler shop.
Old Dec 27, 2012 | 04:30 AM
vlad957's Avatar
1998 C43 Amg
So how can I tell if there going bad? I had a check engine light go on. And I checked what it was it said the 02 sensors but then it went away and havent come back since. Or if my car doesnt pass smog then I can tell too. So Parts geek is a good website to order from? And are the bosh ones close to the orginal ones?
Old Dec 27, 2012 | 04:38 AM
vlad957's Avatar
1998 C43 Amg
Hey 503, I think these are the ones that fit on our cars
http://www.partsgeek.com/catalog/199...en_sensor.html
Old Dec 27, 2012 | 04:56 AM
DRBC43AMG's Avatar
Reading the specific code recorded in the ECU will point you to which one is bad or going out
