Was playing my Cd's yesterday and it played fine. I went to eject the magazine later on and it would not eject. Tried several times nothing. I look at the radio and it says E-06 when you put it on cd. Cd's wont play and magazine wont eject. What does the E-06 error code mean?
try to remove the cd cartridge with a rular if possible?
it happens that the deck loses connection with cd-changer, you get an error in display.
happen to me a few times
my powerloom connector was oxidised once I checked, didn't get any good connection when hooked onto the changer.
remove connector from cd clean connector with CRC electronic spray
OK I will give it a shot. But how did you get a ruler in there?There is not much room if I remember!Originally Posted by kowalski
try to remove the cd cartridge with a rular if possible?it happens that the deck loses connection with cd-changer, you get an error in display.
My changer did not work at all before. I disconnected and reconnected the wire from the changer and it worked fine afterwards. I think in my case, it needed to reset.
I red on another forum, a guy had his cartridge stuck, he carefully used the rular to reliese the cartridge.
did you insert the cartridge correct with the arrow pointing down?
correct insert is when you see the white label ontop of the cartridge.
knock on wood, haven't had this problem yet
Yes sir like I posted my Cd's were playing until I went back there to eject the magazine.Originally Posted by kowalski
I red on another forum, a guy had his cartridge stuck, he carefully used the rular to reliese the cartridge.did you insert the cartridge correct with the arrow pointing down?
Quote:
I had the same problem a while ago, I searched around and found some videos on youtube that showed how to manually eject the magazine. I can't remember how but search and you can find it.Originally Posted by ProjectC55
I wound up tearing that piece of crap out...
LOL! thanks!Originally Posted by 503C43 ////AMG
I had the same problem a while ago, I searched around and found some videos on youtube that showed how to manually eject the magazine. I can't remember how but search and you can find it.I wound up tearing that piece of crap out...
ExploreQuote:
Call Cory at Kleemann Originally Posted by ProjectC55
LOL! thanks!
Were you listening to burned CD's?? They are thicker and could cause the magazine to jam.
Your best bet is to take the CD player apart (it's easy) and remove the magazine.
This thread details how to take the CD changer apart.
https://mbworld.org/forums/c-class-w...azine-fix.html
yes I said to call Cory so I don't understand this comment! He may have a fix by now for the CEL's for the 98's go ask him!!!Quote:
When I asked for help you gave me no info and gave me the one liner "call cory at Kleemann"Originally Posted by ProjectC55
When I comment and tell you that I can't remember where the info is but it is out there you give me a snide "LOL thanks
Cory can't do anything as we are running the EGS51, must have EGS52 to turn ready state monitor off. I have a '99 not '98
I hope you solve your problem.
REALLY! So you can read people's minds through a computer! That's a great God given gift if thats the case and if that is how you took my resonse.Originally Posted by 503C43 ////AMG
When I asked for help you gave me no info and gave me the one liner "call cory at Kleemann"When I comment and tell you that I can't remember where the info is but it is out there you give me a snide "LOL thanks
I was not trying to give you a snide remark,and it would be wrong for me to assume that you are a delicate person. My engine check light is still on and I never followed up with Cory to find out if they dicovered how to turn it off yet on my computer hence me telling you to call Cory. If I had an answer to your question I certainly would have provided you with the info as I have done for others whenever I have done upgrades on my car. Apparently there was some miscommunication for you to assume what my response was. Sorry that you took it that way which was not my intent.
Yes I fixed my CD player and thanks again for the info.
In your response to my question you neglected to mention the fact that your CEL light is still on. Had you of mentioned that it would have made more sense why you were telling me to ask Cory. Your one liner gave me the impression that you didn't have the time to answer my trivial question. I apologize if I mistook your answer, the internet leaves much to perception which is why it helps to be very specific.Originally Posted by ProjectC55
I am glad you fixed your CD player problem
How did you fix it? Just curious.
Quote:
I pulled out the unit,took off the cover and sort of moved or freed up whatever was not moving inside.Originally Posted by m a x i m u s
Quote:
does it work well now?Originally Posted by ProjectC55
what did you exactly do fixing cd changer?
any problems with cd-playback after this quick fix?
None whatsover, like I said I just took it out moved some of the mechanisms,plugged her back in and she started working!Originally Posted by kowalski
does it work well now?what did you exactly do fixing cd changer?
DRBC43AMG
close
- Join DateMar 2010
- LocationLand of mountains, cheese, chocolate and watches
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drive12' W204 C63 AMG coupe "T-Rex", 12' W451 Smart Fortwo Pulse (99' W202 C43 AMG + Ultima Can-Am sold)
Liked:323 Times in 268 Posts
Perhaps signs of an "old age" syndrome...
