Tranny Fluid?
Cheers
About Fuchs Titan ATF 4134 - Mercedes MB 236.14
Fuchs Titan ATF 4134 is an ultra high performance automatic transmission fluid meeting the Mercedes automatic transmission approval MB 236.14
ATF 4134 has been specially developed to optimise shifting performance of Mercedes automatic transmissions. It is particularly suitable for the new generation of Mercedes NAG2 automatic transmissions but is backwardly compatible with and provides improved performance over MB 236.12 automatic transmission fluids.
ATF 4134 is one of the few ATFs meeting the MB 236.14 approval. Other ATFs meeting this specification are the Mobil ATF 134 and Shell ATF134, but Fuchs TITAN ATF 4134 is factory filled in the latest generation of Mercedes Benz (NAG 2) 7-speed automatic gearboxes (Model designation 722.9), providing the required anti-wear and friction modifier additive systems to ensure proper function during the full lifetime of the gearbox.
TITAN ATF 4134 is backward compatible to products fulfilling the requirements of MB-Approval 236.12 and substitutes them in almost every application (refer to
manufacturer filling instructions or contact us for advice).
TITAN ATF 4134 is specially recommended for 5-speed transmissions with regulated torque converter lockup clutch for vehicles with rear wheel drive (model designation 722.6) for remarkable improvement of shifting quality.
TITAN ATF 4134 is also suitable for Chrysler Crossfire and other cars requiring TITAN ATF 4134 or a product in compliance with MB-Approval
236.14. TITAN ATF 4134 is also specified for the use in Ssang Yong vehicles equipped with Mercedes Benz transmissions.
Whilst ATF 4134 is miscible and compatible with conventional branded ATFs, a complete oil change is recommended when converting to TITAN ATF 4134 in order to exploit the product’s full benefits.
I do the transmission work at my dealer and I have more experience on these transmission than you'd believe. I would only use the mb fluid. Lately on the fluid bottles, they do have the number 134 on the front. So if those fluid listed above are exactly the same as the MB fluid (I don't know this to be true), then I'd say it's ok since it is MB fluid.
These are very good transmissions despite what you read on this website. I can't tell you how many times I get cars in from other trans shops that do more harm than good in their attempt to repair these transmissions.
I also find it very odd how many people on here have had their transmission "replaced". I can't remember the last time I've completely replaced a transmission. Everything is serviceable. I've seen shops recommend a complete replacement for a speed sensor in the trans being bad. I've seen transmissions be replaced from shops for torque converter issues. I could go on and on.
Cheers
That's hard to swallow that price I agree. We have stock piles of the bottles at work so I never have to buy any for myself, I forget about some of those costs at times.
I'd recommend draining the torque converter also if you want to get the most fluid out, there is a drain plug on it, you have to rotate the engine until the drain plug is accessable through the opening at the bottom of the bellhousing. The torque converter holds more than the the pan does. The drain plug is the same size as the pan drain plug, 5mm allen. Use new crush washers on both.
I'd throw a new electric socket in as well if it hasn't been done recently. Even if it's not leaking externally, they can still be leaking internally and into the wire harness. It's only a matter of time before it leaks anyway, and it's right there if you're servicing the trans. I believe it's only $15 or so and only 1 7mm screw. good luck
Cheers
Stick with an OE fluid is better of course,
but sometimes you need a good alternative fluid that has the same OE specification, during to the [[DAMN]]
$$$$ OE fluid......ZAYED,,
If memory serves, it might be difficult to get at the torque converter drain plug with the driver side cat/downpipe still in place.
Mercedes has those 'info spec sheets' that specify which particular fluids by brand and type that satisfy that particular spec. I remember reading it a while ago, if you google or search you should be able to find it. I can't remember the specific sheet number for ATF. There are a lot of good DIYs on the 'other' Benz site, specifically in the 210 chassis section, I think you could find the spec sheet info there.
http://bevo.mercedes-benz.com/bevoli...&language_id=1
Easier to do when the car is cool!
