SRS light is on in my C43
Old Mar 9, 2014 | 10:46 AM
88260EEE's Avatar
1998 C43, 05 Mini Cooper s
Ran the code an it said:
P0021 [0021] status current
033 Front passanger side airbag communication (A54)
Anyone know we're this sensor is located, it would not clear?
Old Mar 9, 2014 | 02:18 PM
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
Have you done any interior work inside the car? Underneath the seats?
Old Mar 9, 2014 | 08:50 PM
88260EEE's Avatar
Just picked it up last week.
Old Mar 10, 2014 | 05:35 AM
cm60k's Avatar
There is an SRS sensor in passenger side, located behind the door panel, that may get damaged, or wiring connection issue...!
Name:  Airbag sensor.JPG
ZAYED,,
Old Mar 10, 2014 | 08:14 AM
Sulaco's Avatar
Have same problem in my 98 C43. Haven't been able to afford parts lately so I'm ignoring it for now...
Old Mar 14, 2014 | 09:44 AM
88260EEE's Avatar
Pulled the door panel did not see a sensor there, so next I'm going to pull the seat and check the impact sensor on the inner rocker!
Old Mar 14, 2014 | 10:17 AM
cm60k's Avatar
Depend to your C43 spec.,
some W202 versions got that sensor including driver side & steering, and other got driver side & steering only..
ZAYED,,
Old Mar 23, 2014 | 11:14 PM
88260EEE's Avatar
Airbag impact sensor under the carpet under the seat, looked like something spilled down there. $500 at the dealer, but I found a used one on ebay for $40 different car but same part number worked fine!
Old Mar 23, 2014 | 11:42 PM
vlad957's Avatar
1998 C43 Amg
I have the same problem my Srs light is always one. It would of been nice if you posted some pictures while you did the job. I would want to replace mines too. Do you have to take out the whole seat?
Old Mar 24, 2014 | 12:10 AM
88260EEE's Avatar
Yup, the whole seat comes out I will post some pics, when I get a chance. Easy, seat all the way back remove two torx in front then power the seat forward and remove the two torx in the back then power the seat all the way back. Under the seat in front is a bunch of plugs, and a vacuume hose. Disconnect the battery for safety unplug all the connectors and vac hose, then remove the seat from the car. Under the rug is a airbag sensor can't miss it, it says airbag sensor! Remove and replace clean connector while your in there, put the seat back, reconnect the battery start the car and good to go!!!
Old Mar 24, 2014 | 12:11 AM
88260EEE's Avatar
Anyone know an easy way to post pics from an ipad?
Old Mar 24, 2014 | 09:44 AM
eFifty5AMG's Avatar
2004 E55
I browse & post to MBWorld using the IB Automotive Group app. Go to settings>Forum Posting Options and use PNG format in Ultra Resolution for the best way to post pictures.
Old Mar 25, 2014 | 03:13 PM
vlad957's Avatar
1998 C43 Amg
Oh wow its sounds kind of easy except for the connection and hose disconnection part. I wouldn't want to mess anything up. Thank you for explaining the whole process to me. I also was wondering if you knew the part number for the SRS light?
Old Mar 26, 2014 | 09:59 AM
88260EEE's Avatar
Old Mar 26, 2014 | 10:00 AM
88260EEE's Avatar
Old Mar 26, 2014 | 10:01 AM
88260EEE's Avatar
Old Mar 26, 2014 | 10:02 AM
88260EEE's Avatar
Old Mar 26, 2014 | 10:03 AM
88260EEE's Avatar
Rugs are in pretty good shape for a quick vacuume
Old Mar 26, 2014 | 10:07 AM
88260EEE's Avatar
Unplugging the connections is easy big black one is like and ECU type, you need to slide the plastic piece over to release the connection. There all pretty easy and the vac hose you need like a pick to pry the hose out without damaging it.
Old Mar 29, 2014 | 10:58 PM
vlad957's Avatar
1998 C43 Amg
Wow thank you so much man. I really appreciate it that you took the time to post pictures up. It lookes like its probably going to take me a good 1-2 hours for the whole procces. But when Im ready ill replace my srs too.
