TIRE ADVICE
I don't want to modify the body if I can avoid it. any help would be appreciated. I will be getting everything done this week and put up some pics.
also unless you have done the 5.4 swap the 10mm wider tire in the rear wont make any difference. the car has more than enough grip in the rear with the 255 especially if you run proper pressures. the front is where we need wider...
Now since you have same offset and your rim is half inch wider, im pretty sure you will get same fitment as me with 255s
As you can see i run 265s in the rear. I also had to pull out the lining from the inside. The only problem with that is the dust shoots up and slightly comes up from between the rear bumper and trunk lid but there is no rubbing at all in the rear even tbo i run lowest pads.
Id have my trunk loaded with groceries and have both of my parents in the car which tucks the rear wheel in by a few inches lol but still no rub
for the H&R springs, did you go with the sport (1.2" drop) or the super sport (2"drop)?
I went with the sports, but it seemed like a huge drop. Now with the #4 17mm pads it seems more practical.
The weird thing is, I was getting a slight rub on the right rear wheel with the stock 245's and the H&R's with the stock shocks and stock pads. It was only on hard left turns. Im thinking that shock was blown, but Im not sure.
Im debating on swapping my euro springs for the H&R sport, but no direct feedback on them being any stiffer than that ones i have.
