View Poll Results: What's Your Preference.
Quaife Limited Slip Differential
50.00%
Kleemann Limited Slip Differential
14.29%
Wavetrac Limited Slip Differential
35.71%
Voters: 14. You may not vote on this poll
Limited Slip Differential Poll
Old Jul 11, 2014 | 11:45 PM
TJMJR's Avatar
1998 BRABUS C 5.8
What's your preference?
Old Jul 12, 2014 | 05:46 AM
raw1879's Avatar
Mercedes C55 AMG
I have a quaife great bit of kit a lot more traction out of corners but be careful in wet I mean really careful
Old Jul 12, 2014 | 08:54 AM
TJMJR's Avatar
1998 BRABUS C 5.8
I voted Wavetrac based on Ausmbtech's experience, but for whatever reason, the Wavetrac seems to operate off the radar as many are not familiar with the unit.
Originally Posted by Ausmbtech
Well I've be using the new (Wavetrac) diff for about a month now, I've got 1 track(circuit) day in too so I can finally give you all an idea how it performs.
I've driven 2 W210 E55's with a Quaife LSD inc 1 at a track day and I've had a Kleeman "LSD" in the C43 for about 2-3yrs. The Wavetrack unit looks very similar to the Quaife unit externally, fitting is the same as a Quaife (still send it to a diff shop).
The Quaife is very unobtrusive in it's operation, the more torque you give the more lock you get. The Wavetrac is a little more obvious that it's there even with low torque. Tight corners with little traction will give a little bit of wheel slip due to the higher lock at low torque, a little like a locked diff. Not enough to be an issue, uncomforatble or much wheel slip, but enough to know it's a tighter diff than the Quaife. Very good traction overall, exactly as expected.
On the track it's given an unexpected benefit, it's reduced understeer. Round the track it makes it feel like you can drive it through a corner a bit more on the throttle to control under/oversteer. A very handy improvement over the Kleemann.
Highly reccomended for anyone who likes spirted driving or has a bit more power over standard. Finally a worthy solution!
Old Jul 13, 2014 | 12:24 PM
benzslo's Avatar
C43 5.4, ML320CDI, Fords
Mercedes OEM.
Old Jul 13, 2014 | 01:01 PM
cm60k's Avatar
Originally Posted by benzslo
Mercedes OEM.
+1,
good choice either...
ZAYED,,
Old Aug 25, 2014 | 10:40 PM
silence's Avatar
sounds like airplane
Can anyone shed some light on which models of cars had interchangeable differentials with ours?
Old Aug 26, 2014 | 12:34 AM
cm60k's Avatar
(01/04) R170 SLK32 AMG..
ZAYED,,
Old Aug 27, 2014 | 12:51 AM
silence's Avatar
That is only one?
Old Aug 27, 2014 | 10:00 AM
cm60k's Avatar
You can find it in some version of U.S W210 E280/W210 E300TD,
i'm using a smaller ASD/LSD pumpkin from W201 190E 2.5 or W124 300CE/D, since 2 years without any issues..
ZAYED,,
Old Aug 28, 2014 | 01:26 AM
silence's Avatar
I may create issues with the tq my car puts out- although I would expect any should be overbuilt enough to be ok.
I'm likely to buy the wavetrac?
