Swap flexdisc
when the driveshaft is taken apart, is it wise to also change the driveshaft bearing?
i don't have any vibrations from this bearing yet at 108000km.
bearing, is it a longlife part?
http://www.autohausaz.com/search/pro...port%20Bearing
everything is age related, i assume that i have dry rubber discs with possible cracks on them?
i haven't noticed any vibrations or other things from my transmission.
my car is only approx 108000km on the clock for 16 years of use.
i have replaced all the other suspension parts on front and rear axle.
the transmission support bushing was giving me some click noise in Reverse if i was unsmooth on accelerator, i had it replaced and now everything is smooth again.
only thing to replace are my engine mounts and flexdiscs.
when i do the flexdisc replacement i will get a new bearing for driveshaft when the shaft is already down.
should i also get new driveshaft center support?
http://www.autohausaz.com/search/pro...nter%20Support
and the center support bushing?
http://www.autohausaz.com/search/pro...port%20Bushing
thanks
