Slotted/drilled rotors...
Old Feb 21, 2016 | 09:36 AM
99CEEFOURTHREE's Avatar
99 c43,90 mustang gt supercharged convertible,07 acura tl type s, Hummer H3t pickup
Smile Slotted/drilled rotors...
Need front pads on my 43 so im considering doing all four rotors also.My rotors are fine but I love the new clean look they provide.Can anyone suggest a reasonable slotted/drilled rotor that bolts up and performs well...thanks in advance.Links appreciated
Old Feb 21, 2016 | 09:55 AM
cm60k's Avatar
If you need OEM drilled bolt-on Rotors, you can go with (330x32) "W211/W220 4-matic Rotors, and less $$$$ compared to stock Rotors..!
they will bolt-on, just retaining screw won't fit (which is NOT necessary),,
i sed them in my previous silver C43 for about "2" years, they performs great..
ZAYED,,
Old Feb 21, 2016 | 11:00 AM
ZAYED,,
thanks! what did they run you?
Old Feb 21, 2016 | 11:30 AM
cm60k's Avatar
Sorry, do you mean run by "Time" or "$$$$"..??
ZAYED,,
Old Feb 21, 2016 | 11:36 AM
$$$$$ lol...
Old Feb 21, 2016 | 11:47 AM
cm60k's Avatar
They around, (AED880) = ($240) for a pair..
ZAYED,,
Old Feb 22, 2016 | 04:22 AM
cm60k's Avatar
Also, you have another good option as well,
(DRT/Zimmermann) got a unique F/R "drilled/slotted" Rotors, they're little bit more pricey & limited quantity:-
http://www.ebay.com/itm/Fits-C43-E55-CLK55-AMG-Drilled-Slotted-Rotors-Front-Pair-Made-In-Germany/291682821138?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D35558%26meid%3D6a31810074654a9abf181c41019ca99f%26pid%3D100005%26rk%3D1%26rkt%3D3%26sd%3D291682820271
http://www.ebay.com/itm/Fits-C43-E55-CLK55-AMG-Drilled-Slotted-Rotors-Rear-Pair-Made-In-Germany/291682820271?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D35558%26meid%3D3474e5e7b81d414db1bcb503336329ab%26pid%3D100005%26rk%3D1%26rkt%3D2%26sd%3D291682821138
ZAYED,,
Old Feb 22, 2016 | 09:49 AM
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
I have a really good set on my 99 but NO markings on them to let me know who made them!
Old Feb 23, 2016 | 08:03 PM
NICE....Thanks
Old Feb 25, 2016 | 10:13 PM
svt ricco's Avatar
1999 C43 AMG
W203 C230k sport will fit too
Old Feb 26, 2016 | 07:42 AM
cm60k's Avatar
Yes, they will fit, but you will sacrifice (4mm) of the Rotor thickness..!
(28mm vs 32mm)
ZAYED,,
