What did I just break? (C36)
Old Mar 14, 2016 | 07:35 PM
mppp's Avatar
1996 Mercedes-Benz C36 AMG
Was changing my plugs and snapped this brittle plastic line. What the hetch is it and is it easily found or replaced?
Thanks in advance!
Old Mar 14, 2016 | 08:20 PM
Jasssc's Avatar
1996 Mercedes C36 AMG
Vacuum line! just did all my most visible and easily accessible ones.
Super cheap, I bought like 10-15 feet off autohauosaz.
c36 are notorious for these lines cracking and breaking, new lines are night and day difference, look and feel wise. New lines are clearish white with flexibility and they get yellow and hardened over time and tend to break
Old Mar 14, 2016 | 10:12 PM
mppp's Avatar
On Autohauz now. Is this what you bought Jasssc?
Cohline 0001581435 - Vacuum Hose/Line; White; 1mm ID x 4mm OD; Bulk
Cross References:
0001588935, 0001589335, 0001589435, 0001589635, W0133-1714718
Thanks again!
Old Mar 14, 2016 | 10:59 PM
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
buy about 6 or 8 feet of it and replace every yellowed, aged vac line under the hood.
Old Mar 15, 2016 | 02:02 AM
DutchC54's Avatar
1998 W202 C43 ///AMG 5.4
just fix it with the black soft rubber piece which u see next to it and u are good to go.
Old Mar 15, 2016 | 07:35 AM
mppp's Avatar
Hello Dutch,
I see the black rubber piece u speak of and assume the vacuum line just sticks in there (and can pull broken off piece out of there). Could you be more descriptive in your response as I may not be following?
Old Mar 15, 2016 | 02:06 PM
Jasssc's Avatar
Yep! remove the old stuff, cut the new piece to the right length using sharp cutters (I used air line cutters) then you should be good to go. I bought (10) pieces of that
Cross References:
Thanks again!
Old Mar 15, 2016 | 05:14 PM
DutchC54's Avatar
Hello Dutch,
correct.
just get that soft rubber coupler and stick in the broken ends. its basicly the same whats on the right. (excuse my ****ty english..) name a lengthener(????) //coupler..
ive used this to fix my pneumatich seats .. in the as the car ges older these piping tends to break.. with the black rubber couplers its not nessecairy to replace the complete hard plastic tube/line.
Old Mar 15, 2016 | 06:19 PM
mppp's Avatar
correct.
Thanks everyone I'm just waiting on lines to come and the rubber pieces seem to be in great shape so hopefully won't need to replace those.
