What's the fuse number #??
Old Dec 11, 2016 | 03:34 PM
KJI3jflarryfe93's Avatar
In Spring 2017 when I take my car out from winter sleep first time I'm going to crank my car to make the oil flow in the engine, I want to do this without starting my car.
What is the fuse number i shuud pull out for fuel pump?
my fuse chart is in French, I can't parlevoo French.
Is it enuff to crank the starter a few seconds to make the oil flow inside engine, I have never done this before?
All previous years I only start my car, on idling I carefully revved the engine with accelerator maybe 5 minutes before I took off the first time after winter sleep.
what is the best thing to do?
Old Dec 11, 2016 | 05:37 PM
mickey13's Avatar
1999 AMG C43
fuel pump fuse, don't know if ours is the same. i can look on WIS if you don't know which
Old Dec 12, 2016 | 05:11 AM
please do and I hope any eüropean member will check theirs to compare the fuse #
thanx
Old Dec 12, 2016 | 07:14 AM
DRBC43AMG's Avatar
Have you checked the language by turning the sheet? Mine is in 2 languages....
Old Dec 12, 2016 | 02:56 PM
really, i didn't know dat
so, you didn't look up the fuel pump fuse number for me while you were at it?
i went to see my car earlier today, she was very sad and lonely in the dark, getting her battery juiced up with a trickle charger she was happy to see me.
Old Dec 12, 2016 | 03:50 PM
cm60k's Avatar
I think you should to have fuel pump relay not fuse, isn't..?!?
"ZAYED"
Old Dec 12, 2016 | 04:49 PM
DRBC43AMG's Avatar
"ZAYED"
As Zayed says, it's a relay. Check the two PDF files I extracted from the EPC. The relay is identified as #65. It also does several other things: head lights wiper washer, etc.
File Type: pdf
File Type: pdf
Old Dec 12, 2016 | 05:03 PM
cm60k's Avatar
Good "PDF's" Daniel..
"ZAYED"
Old Dec 12, 2016 | 05:10 PM
DRBC43AMG's Avatar
Glad to help
Old Dec 12, 2016 | 05:25 PM
Glad to help
thanx for your help Danijel.
I thought it was a fuse to pull out not the relay.
is it only to pull the relay out same way pulling the fuses?
fuel pump relay what color does it have?
relays comes in various colors.
thanks again
Old Dec 12, 2016 | 05:31 PM
DRBC43AMG's Avatar
The relay pulls out of the socket. Just be careful not to force it out sideways, etc. I'll check the colour tomorrow. T-Rex is parked outside in -5°c and is still used every day but for how much longer? Roads are still bone dry for the moment thanks to brilliant sunny weather. Unfortunately all the snow in the mountains has practically disappeared, so Christmas skiing will probably be impossible again this year....
Old Dec 12, 2016 | 05:44 PM
I will pull out the relay upwards not wiggling it sideways
thanx
Old Dec 12, 2016 | 06:29 PM
cm60k's Avatar
It should be "Black" one,,
in the trunk, under the mat, at the back, right side..
"ZAYED"
Old Dec 12, 2016 | 06:54 PM
"ZAYED"
thought relay was in the engine bay inside large fuse box?
Old Dec 13, 2016 | 07:18 PM
mickey13's Avatar
1999 AMG C43
i checked mine, the card is in two languages too. english and german. i'm going to just flip it to german to mess with anyone who tries to read it.
Old Dec 14, 2016 | 11:47 AM
you lill rascal
Old Dec 15, 2016 | 10:03 AM
DRBC43AMG's Avatar
Kowalski better answer your question and light up your bride, I went out and made some photos of the fuse box and relay box behind (not those in the trunk).
First of all open the engine hood all the way up vertically. It will greatly help you get to the back of the fuse box.
Remove the fuse box lid (I imagine you know how to do that...). Check the fuse card identifying all the fuses etc.
Fully unscrew the 6 cross head screws holding down the surround without removing them from the surround. This is to ensure they are not dropped in the engine bay and lost.
Pull gently forward the surround. It is a bit fiddly but it comes out without any other surgery. You then have access to the relays behind the fuse box.
Reassembly is the reverse and should not be problematic. All told the whole operation took about 10 minutes including taking photos.
Hope that helps
Attached Thumbnails What's the fuse number #??-2016-12-15-15.41.04-769-dsc_1394.jpg   What's the fuse number #??-2016-12-15-15.39.03-892-dsc_1392.jpg   What's the fuse number #??-2016-12-15-15.37.41-800-dsc_1391.jpg   What's the fuse number #??-2016-12-15-15.37.27-615-dsc_1390.jpg
Old Dec 15, 2016 | 01:34 PM
you did all this for me?
thank you very much
so we have a black relay in the front fuse compartment, there are also some relays in the trunk.
relay for fuel pump is located in the trunk area?
Old Dec 15, 2016 | 04:53 PM
DRBC43AMG's Avatar
As Zayed says the relay is on the back. I'm confused
