EIS removal and repair
Old Mar 2, 2017 | 04:31 AM
W202AMG's Avatar
W202 C43 1999
Hi all,
None of my keys work. Seems my EIS my have failed.
Firstly, tried to start car after fueling up, just cranked, two time outs, pulled key and re-inserted, key doesnt turn, ESL doesnt unlock.
How do i get the EIS out of the dash?
Has anyone ever opened one up and repaired one?
Im 600klms from any Mercedes Dealer, and kinda stuck here.
Cheers all
Old Mar 2, 2017 | 04:40 AM
cm60k's Avatar
Did you try to diagnose the car, codes may helps..!?!
-;ZAYED;-
Old Mar 2, 2017 | 04:52 AM
W202AMG's Avatar
W202 C43 1999
Cant, no OBD2 port!
Old Mar 2, 2017 | 07:02 AM
W202AMG's Avatar
W202 C43 1999
Does the K40 relay have any impact on the key not turning at all??
Is there a chance my K40 could stop my key turning?
Old Mar 3, 2017 | 05:02 AM
DRBC43AMG's Avatar
Looked around on a UK forum and came up with this thread. OK it's a w204 but it might help...
http://www.mbclub.co.uk/forums/elect...ion-issue.html
and also this:
http://www.pelicanparts.com/techarti...eplacement.htm
Old Mar 3, 2017 | 08:21 AM
W202AMG's Avatar
W202 C43 1999
Thanks mate, will have a ganda
Old Mar 14, 2017 | 09:21 AM
W202AMG's Avatar
W202 C43 1999
After diagnostics at the dealer, the issue was not the EIS, but the ESL had locked out after 400 starts. I have paid another dealer $170 to program that ESL, and according to the dealer the car is with now, it was never done.
The reason the car failed to start a few times was cam position sensor, which i had replaced very recently with a genuine Bosch part, and it has failed prematurely.
So the most expensive part of the job was the transporting of the car, hundreds of klms to the nearest dealer....
Old Mar 14, 2017 | 09:33 AM
DRBC43AMG's Avatar
Damnation! Try at least getting a refund on the cam sensor. Definitely should not have died so early in life, specially for a Bosch item
Old Mar 14, 2017 | 09:37 AM
W202AMG's Avatar
W202 C43 1999
Have contacted parts supplier about that.
Am aiming for a refund on the lazy Merc dealer programming of the ESL that did not get down correctly too.
Old Mar 14, 2017 | 04:46 PM
KJI3jflarryfe93's Avatar
what ist ESL?
with my original 1999 factory key car starts everytime, with my new chrome key car will start maybe 4 out of 6 times, removing chrome key from ignition then re-inserting key will start the car.
stealership told me ignition is kaputt, coud it be cam position sensor?
this cam position sensor is a cheap part to replace than buying a new EIS for several hundred bux
Old Mar 14, 2017 | 04:57 PM
mickey13's Avatar
1999 AMG C43
Electronic Steering Lock
Old Mar 14, 2017 | 05:08 PM
DRBC43AMG's Avatar
Except the cam position sensor needs you to pull off the intake manifold as the little critter lives under there...
Old Mar 14, 2017 | 05:22 PM
better get the coeds first b4 doing stupid parts changes
Old Mar 14, 2017 | 05:27 PM
mickey13's Avatar
1999 AMG C43
Does bad cam sensor give a code? My last adventure with crank position sensor did not have a code on SDS.
Old Mar 14, 2017 | 06:01 PM
well i don't know why my ignition dislikes my chrome key on random start ups?
anyone experiance this with the new chrome keys?
my old key from 1999 works 100% everytime, the new chrome key works random on start ups!!
when i try to start i hear a clicking from ingnition then i have to remove key from ignition to re-insert key and then my car wil start with chrome key.
why is this happenin?
Old Mar 14, 2017 | 06:02 PM
DRBC43AMG's Avatar
Found these OBDII codes:
Cam sensor codes:
P0340 Camshaft Position Sensor Circuit Malfunction
P0341 Camshaft Position Sensor Circuit Range/Performance
P0342 Camshaft Position Sensor Circuit Low Input
P0343 Camshaft Position Sensor Circuit High Input
P0344 Camshaft Position Sensor Circuit Intermittent
Crankshaft position sensor:
P0335 Crankshaft Position Sensor A Circuit Malfunction (L5)
P0336 Crankshaft Position Sensor A Circuit Range/Performance
P0337 Crankshaft Position Sensor A Circuit Low Input
P0338 Crankshaft Position Sensor A Circuit High Input
P0339 Crankshaft Position Sensor A Circuit Intermittent
MB technical codes acronymes
CKP – Crankshaft Position
CMP – Camshaft Position
Old Mar 14, 2017 | 06:05 PM
mickey13's Avatar
1999 AMG C43
My chrome key works every time, maybe better than my black key.
Old Mar 14, 2017 | 06:14 PM
well sumthin' ain't right!?
i will have to do a B-service this year when i take her out from her beauty sleep
i will have to get the error coeds
Old Mar 14, 2017 | 06:56 PM
W202AMG's Avatar
W202 C43 1999
what ist ESL?
No, nothing to do with cam position sensor in your case. In my case it was a coincidence that both played up around the same time
Old Mar 14, 2017 | 06:58 PM
W202AMG's Avatar
W202 C43 1999
No it doesnt. It is in the front of the right hand head and takes 2 minutes to swap out, removal of one retaining screw is all you need.
Old Mar 15, 2017 | 03:06 AM
DRBC43AMG's Avatar
Aggrrrrrrr my fault, I mixed up with the knock sensor. It was past my normal bed time when I posted that
Old Mar 15, 2017 | 04:34 AM
W202AMG's Avatar
W202 C43 1999
No worries mate. Never heard of a faulty knock sensor on an M113 yet.
