What did you do to your C36/C43 AMG today?
Old Jul 24, 2017 | 01:29 PM
PJmak's Avatar
There is a thread like this in the W210 AMG section.
It seemed kinda fun and it keeps people engaged. Sorry if created before.
Feel free to post pictures and instructions on what you did.
I replaced my driver door actuator because it had a vacuum leak and I always had to unlock the door manually by opening the rear door first and reaching in and pulling the pin up by hand. This dragged on for a while because I knew these things were a pain to do.
Heads up:
-It is not necessary to remove the window and the window motor to get the actuator out even tho it'll seem like that at first. The window must be in a completely closed position to allow the actuator to come out.
-You have to remove the door handle first and the screw that holds it is hidden behind the rubber door seal.
-Be gentle with these things. The plastic is old and it will crack.
Old Jul 24, 2017 | 06:09 PM
DRBC43AMG's Avatar
Controlled and topped up engine oil level. 0,75 lt of Mobil 1 for close to 10k kms so guess that's good going for an engine with 290k km on the clock
Old Jul 25, 2017 | 11:38 PM
brad_c43's Avatar
'99 C43, '88 560SL
Maybe not today but the other day i hollowed out my air-box and removed the baffles inside. And before that I hollowed out the elbow from the airbox to the intake manifold. I feel like my exhaust has more snaps and crackles now and it definitely surges forward if i let off the gas after heavy acceleration. Overall I love it and its making the car that much more fun to drive!
Old Jul 26, 2017 | 12:16 PM
JohnnyRock's Avatar
1998 C43 AMG
Today? Nothing.
But yesterday, my idler pulley exploded, throwing the serpentine belt at 75mph (115kmph to my euro friends). Left me stranded in 100 degree heat and (seemingly) just as high humidity. Had it towed nearly 40 miles to a shop where she is getting a new pulley today.
But I did buy some new 18" Schmidt wheels for her! (I was enroute home when the mishap occurred).
Old Jul 26, 2017 | 01:04 PM
DRBC43AMG's Avatar
Originally Posted by JohnnyRock
Today? Nothing.
Guess that should be a warning to all 43 owners to check and change (very cheap part) on a preventive basis. At the same time also check the tensioner pulley (that part is a bit more expensive), but at least the front of the engine should be much, much quieter with new parts
Old Jul 26, 2017 | 05:48 PM
JohnnyRock's Avatar
1998 C43 AMG
Couldn't agree more, DRBC43. That's my reason for posting my experience, sort of a, "PSA" (Public Service Announcement).
When the serpentine belt goes, you lose PS, battery, ac, water pump/cooling, etc. The bearings on my pulley seemed to work fine without any warning. Except for the fact that the car is nearly 20 years old and the pulley is probably original to the car.
Old Jul 27, 2017 | 10:45 AM
PJmak's Avatar
Just replaced the MAF on mine (wow what a difference)
Got a new trans mount and seat relay waiting to go in too.
Attached Thumbnails What did you do to your C36/C43 AMG today?-20170725_180712.jpg
Old Jul 30, 2017 | 09:35 AM
speed43's Avatar
1999 C43 Amg
Two days ago I installed my new air box mod. This one has a bell mouth inside the box by the maf entrance. This draws or pulls air much better than without one in there. If the picture uploads it shows what a bell mouth does but in this case with air and not water as the picture shows.
What a difference! This box out performed my personal air box setup that I use. Low end torque has improved greatly. Tires just want to spin, and when down shifting it's just brutal!
Old Jul 30, 2017 | 10:07 AM
brad_c43's Avatar
'99 C43, '88 560SL
With all the improvements we see from this airbox, i wonder how insane our cars would pull with individual throttle bodies?
something like this would look and sound amazing on our cars
Old Jul 31, 2017 | 10:55 AM
PJmak's Avatar
I think someone did that back in the day, not 100%
Btw I just did my oil change, replaced my engine trans mount, installed a new seat relay and replaced my passenger seat belt.
The trans mount was in terrible shape.
Btw, does anyone have info or a diy on replacing 02 sensors? Are they all same part numbers?
Which ones fail first usually?
Old Jul 31, 2017 | 11:00 AM
PJmak's Avatar
Originally Posted by speed43
This is about an hour from me, I went there recently
Old Aug 1, 2017 | 10:51 AM
JohnnyRock's Avatar
1998 C43 AMG
PJmak, what caused you to replace the MAF and trans mount?
Was the MAF plug n play? Feel a difference in driving with the trans mount?
Old Aug 1, 2017 | 10:53 AM
JohnnyRock's Avatar
1998 C43 AMG
Speed,have you got a pic of your actual mod? Are you going to be offering this new box for sale?
Old Aug 1, 2017 | 11:29 AM
PJmak's Avatar
I had this MAF on my car for well over 100k and recently got a cel code for a bad maf.
The car drives way better with the new maf.
Trans mount sort of the same thing. Its never been done on my car so I thought Id just go ahead and do it.
Surprisingly it didn't make much change even though the original one was torn bad.
Old Aug 1, 2017 | 01:31 PM
DRBC43AMG's Avatar
Preventive maintenance
Old Aug 2, 2017 | 05:23 AM
speed43's Avatar
1999 C43 Amg
I will post pics in a different thread some time this week. I ended up making my own Bell mouth because the ones I bought weren't wide enough. The one i made is just as wide as the maf housing which is perfect. I will be starting a new thread soon with more details. And yes I will be offering this box, awesome throttle response and power with the BM.
Old Aug 2, 2017 | 11:58 PM
brad_c43's Avatar
'99 C43, '88 560SL
woah, do you have any info at all on this guy or the car?
Old Aug 3, 2017 | 10:35 AM
PJmak's Avatar
Im not 100% sure how far they got but it was talked about.
Look up speedybenz
He had a track ready c43 with 5.4 swap
Old Aug 5, 2017 | 11:13 PM
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
it's been done. speedybenz did it in his 55 swapped C43. that, plus intake/exhaust and he claims he was outrunning M156 C63's...
I emphasize "claims" in that sentence, but he's not one to make stuff up
Old Aug 5, 2017 | 11:17 PM
Sulaco's Avatar
finally got around to fitting bumper number 4... number 3 that was shipped all the way to me from the U.A.E courtesy of fellow member cm60k just wasn't fitting right on the ends. but I didn't fit it, the body shop did when I sent it in for painting.
anyway long story short I figured out the problem. someone, at some point, cut my freakin bumper hangers by 2 inches! no wonder the sides were way off and would not fit into the brackets! now i have yet another bumper that needs painting, but oh well at least I figured it out
my friend totalled his white C43 so I'm scavenging it for parts. thinking about finally removing the hitch receiver on the tail and stealing his bumper to replace mine. mine is fine except the hitch receiver caused a permanent warp in it in the center of the bottom
why are the cables that go to the fog lights so impossible to find!?!?
Old Aug 5, 2017 | 11:52 PM
brad_c43's Avatar
'99 C43, '88 560SL
I know, I've been trying so hard to find out more about speedybenzs work but every photo is no longer available and he never said what the stacks were tuned for so I have to start from scratch
Old Aug 6, 2017 | 04:29 AM
DRBC43AMG's Avatar
Why not try getting in contact with him. I purchased some of his camber arms for the rear (never installed) and I still have his mail. Let me know by PM if you want it
Just checked the members directory on this forum and it seems his last post was July 1st 2015, so it seems he is not very active here
Old Aug 6, 2017 | 10:38 AM
speed43's Avatar
1999 C43 Amg
I tried finding more info too. Like you said all pics are gone. If I can see at least one pic I should be able to do one. Hope someone will post pics if they have any.
Old Aug 6, 2017 | 10:43 AM
brad_c43's Avatar
'99 C43, '88 560SL
I can do the Math, I love a good challenge if i knew how he tuned his i know i can replicate it
i think i might send him an email but in all my searching i saw a lot of people were unhappy with how unresponsive and how long he took to reply to people so i don't know how well that will work out for me.
Old Aug 6, 2017 | 10:59 AM
eFifty5AMG's Avatar
2004 E55
Might as well give it a shot. I offered him $9k for his 43 back when he was selling it.. never responded
