Motor Swap
Any comments ?
Any comments ?
put C43 snorkel into Clk55 pump, will do the job,
or modified the tube to inward directional,,
it's kinda optional, isn't..?..
-;ZAYED;-
*"113 180 26 01", only snorkel need to be changed.
*"113 180 28 01", modified the oil cir. tube.
-;ZAYED;-
all these #s are factory base line #s,,
the new #s are "113 180 26 01" & "113 180 28 01"..
-;ZAYED;-
I thought this was solely dependent on the ecu tune the car is running???
A custom tune will easily get my 350hp ml55 motor to those numbers
For all you know, that motor will make less when hooked up to the stock c43 ecu...
good question for the w208/w209 forums. i asked it a while back and nobody could seem to answer if i remember correctly. both engines have the same displacement (volume) so they should have the same power output. cams, and valves can change the profile of the engine but not the volumetric displacement. amg tends to beef up hp/torque with intake/exhaust. i believe that the ev engine shifts the powerband. i brought it up before here: https://mbworld.org/forums/c36-amg-c...ml#post6990565
Ausmbtech was familiar with the evo design and gave a pretty clear explanation in that thread as well.
