MAF and MAP sensor VOLTAGE
Old Aug 23, 2018 | 11:06 PM
g60wall's Avatar
2014 E63s
Does anyone have or can provide a log of the voltage that these sensors put out on your N/A 43 or 55 ME2.0 cars. I would truly appreciate it, I am having a hell of a time tackling my swap and I am focused in on these 4 signals to tune the car, TPS % , MAF , MAP AND O2 SIGNAL voltages. I believe a AEM F/IC 8 piggyback is the only answer, I already have one but before i can even tune or start building the files I need to see what the ECU wants to see in ideal conditions. Currently the car with out the supercharger belt is a dog and I don't believe the data I will build will be proper reference point. I am located in MD
Old Aug 24, 2018 | 01:37 PM
mickey13's Avatar
1999 AMG C43
above my paygrade. would seriously consider contacting someone with a bit of experience when it comes to something like this but thats probably because im simple minded,,, 2+2=4 type mind - dont ask me to multiply or i might cry. what swap did you do?
Old Aug 24, 2018 | 01:57 PM
g60wall's Avatar
2014 E63s
Not really super complicated. Just wondering what these values are even through your odb port and I’ll do the conversions. Would be greatly appreciated
Old Aug 24, 2018 | 02:14 PM
g60wall's Avatar
2014 E63s
M113K swap
Old Aug 24, 2018 | 02:26 PM
mickey13's Avatar
1999 AMG C43
i would but i have check engine codes so probably not the best example to get
Old Aug 26, 2018 | 12:00 PM
DRBC43AMG's Avatar
Have you tried posting perhaps on this page: https://mbworld.org/forums/audio-electronics-38/
Old Aug 26, 2018 | 12:11 PM
g60wall's Avatar
2014 E63s
I’m looking for the outputs of Mass Air Flow sensor and the Mass Air Pressure (MAP) sensor under wide open throttle at different RPM. You can use torque pro , or a few different odb scanners. I will send one to someone if they are willing to help.
Old Aug 26, 2018 | 12:26 PM
cm60k's Avatar
Hey bro.,
Try to contact "blackbenzz", his so professional with this kind of puzzles..
-;ZAYED;-
Old Sep 1, 2018 | 09:55 AM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
I know this isn't the greatest help but I'll be back in Portland in the beginning of November. If you still need help to get the outputs then I'll hook up my C43 and get them for you
