Air-box yearly maintenance
Old Sep 7, 2018 | 06:40 AM
DRBC43AMG's Avatar
AMG specific #ID on the air-box filter cover
Dirty green filter with around 10k km since last clean
As I needed to pull off the air-box to get a better visual to the engine, I decided to proceed with the yearly maintenance. This includes a good clean of the panel filters (you'll notice some crud trapped on the outer side of the filters) and a general clean of the outer side of the special enlarged (thanks George) air-box.
When removing the panel holding the filters in place, I saw something I had never noticed before, the cover has a specific AMG #part ID. Didn't think this part was an AMG special.
Old Sep 7, 2018 | 09:37 AM
silverc4s's Avatar
99 C43, 73 911 targa
Interesting find. Too bad they didn’t have George’s expertise on hand. They might have made the inlet system less restrictive from the start��
Old Sep 8, 2018 | 06:26 AM
speed43's Avatar
1999 C43 Amg
1130900101 is the number is use to search eBay for these boxes. The type of plastic is PA6-GF30,. It's a tough plastic that will last pretty much forever.
Old Sep 11, 2018 | 11:48 AM
DRBC43AMG's Avatar
While waiting for the ordered parts to arrive (tomorrow Wednesday), I used my spare time to thoroughly clean the air-box and filters. After using a vacuum cleaner and brush to remove the visible debris, I let the two filters soak in a tub of warm soapy water. That way the smaller particles fall to the bottom of the tub. After a long clean on both sides with as old dish washing brush, I rinsed the filters in clear water and let them dry in the sun. Used compressed air to blow in all the grooves until everything is perfectly clean and dry. A good look at each filter up into the sun, I could see that each was spanking like new clean. After having disinfected both filters (read next paragraph to understand...) placed the filters in the air-box and screwed the bottom part back together using a cross tightening pattern.
I had noticed when removing the air-filter a weird smell coming from the engine bay. I wondered if this was not due to the pigeon strike at around 120km/h some time back which obliterated the bird, but also destroyed my CF look front radiator grille. When cleaning the filters I noticed the smell was particularly strong there. Could it have been some pigeon bits which got sucked into the air-box and rotted in there? Or else a mouse other small rodent that managed to climb into one of the air intakes and got lost in the box and couldn't get out again. The mystery remains and hopefully the smell will disappear over time.
Next step after having replaced the broken engine support bracket and assembled new rubber engine aka E55K, I'll get down to insulating the bottom of the air-box with some spare gold sheeting I am using to insulate the rear engine body clip in my Ultima build.
Green cotton filters I have used since 2012, with no issues at all. My secret to avoid MAF problems? No oil anywhere on the surfaces but more regular cleaning of the filters
Old Sep 11, 2018 | 12:08 PM
Bahnstormer's Avatar
2010 E63 AMG, 2003 E500
I also use the Green filters in my E500 and am very happy with them.
Old Sep 11, 2018 | 01:26 PM
DRBC43AMG's Avatar
Good to know
Old Sep 12, 2018 | 06:24 AM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
I use AFE Pro Dry S filters in both my AMG's. I will never use an oiled filter, you are just asking for MAF issues.
Old Sep 12, 2018 | 08:43 AM
Green filters supposedly have less oil than the K & Ns.
I've used them on all three of my Mercedes with great success.
Old Sep 12, 2018 | 09:36 AM
cm60k's Avatar
Professionally said & fully agreeeee..
-;ZAYED;-
Old Sep 13, 2018 | 04:19 AM
jensl76's Avatar
W202 C55 AMG, W202 230K T-Modell, Corvette Stingray C3,
Hi DRBC43AMG,
can you tell me where to buy these green filters?
Thank you!
Regards
Jens
Old Sep 13, 2018 | 10:51 AM
DRBC43AMG's Avatar
Hi Jens,
I purchased them second hand in the UK from another C43 owner, but they are available I imagine from the parent company http://www.green-filter.com/enterprise/ using the id#2295.
Certain people prefer http://www.bmcairfilters.com/
Check out this one: http://www.bmcairfilters.com/eng/car...fb103-01/4/art
Old Sep 14, 2018 | 12:55 AM
jensl76's Avatar
Thumbs up
Originally Posted by DRBC43AMG
Hi Jens,
Hi DRBC43AMG,
thank you very much! :-)
Regards
Jens
Old Sep 14, 2018 | 03:27 AM
DRBC43AMG's Avatar
No probs bro
