Low Temp Thermostat
I had a 79*C sitting around so I decided to install it to see how it faired in the hot summer weather. So far so good, normal engine temps came down from 87-95* to 79-83ish. Engine feels like it maintains that peppy-ness long after a cold start.
I like it but I’m wondering if it will cause any accelerated long term wear on internals. Also, I’ve read that engines running below normal operating temperature can cause oil sludge issues. I’m thinking that’s if it’s drastically lower tho.
Here's the part# for the 79*C if you want to give it a try: 100-200-07-15
The lower temp thermostat makes the engine feel more lively and I like it. Nonetheless, I am still a bit skeptical about running this engine at a lower temp than it's supposedly designed for.
thanks for the info, just ordered a thermostat, I’ll have it installed at my next service stop. I would think the reason for the higher temp I has to do with emissions and clean running, at the expense of performance and reliability in the long term. I think any time an engine runs at higher than normal temperatures it will affect the long term reliability.
im going with the 79deg C thermostat..
the optional temps. are (87C) or (80C) or (71C),
I don't think (7C) only will deserve it,,
if you want more opening temp. range, then better to go with (71C)..
-;ZAYED;-
Zayed, are there part numbers available for lower temp thermostats for M113?
"Wahler" makes (87C) & (71C), for all "M112's" & "M113's",,
i have (71C) now, it's way better than OEM (87C), specially in my damn climate..
-;ZAYED;-
many thanks Zayed. And Chita for getting my thoughts churning.
Anyone in US want the low temp for C36 engine? PM me and I’ll forward it to you for postage cost.
first off, apologies for not paying attention to my spell checker, as it hammered your “name” ...;(
Just PM me your address and I’ll send it along when it arrives. I’m a fan of C36s as well, btw.
