c43 side skirt fasteners
Old Mar 24, 2020 | 11:35 PM
Killahbee's Avatar
AMG
Anyone know the part number or where to find the fastener clips for the side skirt that fasten the front of the side skirts to the front fender?
Old Mar 25, 2020 | 01:35 AM
khomer2's Avatar
02w163ML500 / 97w210E50AMG / 99w202C230k / 95w124500e-wip
[QUOTE=Killahbee;8015689]Anyone know the part number or where to find the fastener clips for the side skirt that fasten the front of the side skirts to the front fender?[/QUOTE]
Point to/ Indicate what you are looking for....
Old Mar 25, 2020 | 09:50 AM
The_mabman_20's Avatar
Red 1995 C36
I’m going to take advantage of this myself. I have a C36 which appears to use double sided tape to hold the rockers in place. However parts 375 and 385 appear to be an evolution on the c43. What are those MB part numbers and doesn’t anyone know if that will work with the c36 rockers?
sorry to highjack, since I’m asking basically the same info but on the c36, the answer can be helpful to more than just me.
Old Mar 25, 2020 | 10:11 AM
khomer2's Avatar
vin#?
EDIT:
On this photo only, 375 and 385 are not double sided tape, they are the rubber seal pieces between the top edge of rocker panel cover, at the front and the rear end.
It will may possibly be a different reference # for the C36, C43, but essentially the same seal.
Old Mar 25, 2020 | 10:27 AM
DRBC43AMG's Avatar
Checked the Daimler parts info on-line for US C36. Does this help?
C36 N. America
Old Mar 25, 2020 | 10:29 AM
DRBC43AMG's Avatar
Or this??
C36 N. America
Old Mar 25, 2020 | 10:43 AM
Red 1995 C36
Originally Posted by DRBC43AMG
Or this??
C36 N. America
This is the correct diagram for my car. What is 194 and 221? Is the only mechanical fastening the screws on the top and bottom (203/209 and 197/200)?
Old Mar 25, 2020 | 01:20 PM
DRBC43AMG's Avatar
I'll check a little bit later...
Old Mar 25, 2020 | 01:41 PM
Red 1995 C36
much appreciated!
Old Mar 25, 2020 | 07:41 PM
Killahbee's Avatar
AMG
I believe it's part 480 or 470. It's a clip like this https://www.ebay.com/itm/5X-MERCEDES...72.m2749.l2649 ,but for the front.
Old Mar 25, 2020 | 07:51 PM
khomer2's Avatar
vin#?
194 is part #A 201 698 02 14 - it's the hanging strap for the jack hole cover on the rocker panel cover.
221 is part #HWA2026900214 - BRACKET PARTS KIT,ADHESIVE VERSION,LEFT SIDE SKIRT ATTACHMENT AMG &
part #HWA2026900314 - BRACKET PARTS KIT,ADHESIVE VERSION,RIGHT SIDE SKIRT ATTACHMENT AMG
EDIT:
203/209 are the fasteners that hold the top side of the rocker panel cover to the rocker panel/ 203 part #HWA2029880281 fastener button amg / 209 part# N000000000529 scew /
197/200 are the fasteners that hold the underside of the rocker panel to the rocker panel/ 197 part #197 A 000 990 46 92 expansion rivet amg / part #200 HWA2029880181 washer amg
There may be interchangeable parts for these - photos of where they will be used helps.
Old Mar 25, 2020 | 07:54 PM
khomer2's Avatar
"A clip like this" doesnt help.
Post photos - photos are worth a thousand words.
Old Mar 25, 2020 | 08:16 PM
Killahbee's Avatar
AMG
Alright, you see the 3 clip holes that run across the bottom of the front fender? (in the picture i caught 2) These need a clip that fastens the side skirt to the fender. They sit inside the weather seal that goes across this area. I don't know what MB calls it. What you think?
Old Mar 25, 2020 | 08:17 PM
PJmak's Avatar
Yes. The frnts are two piece clips
Old Mar 25, 2020 | 08:18 PM
PJmak's Avatar
Top pic is the rear clips and bottom pic is front clips
Old Mar 25, 2020 | 08:21 PM
PJmak's Avatar
Old Mar 25, 2020 | 08:23 PM
khomer2's Avatar
part68?
You are referring to the bumper trim fastener. (Need to describe it better)
A 202 880 07 93
maybe 65... A 202 880 02 93
Old Mar 25, 2020 | 08:37 PM
Killahbee's Avatar
AMG
I see, PJmak has it exact. I have the rear ones. Thanks Khomer2, not bumper trim, c43 doesn't have bumper trim.
Old Sep 18, 2021 | 04:53 PM
drewrobinson92@'s Avatar
2007 c230
[QUOTE=khomer2;8015714]
Any one know part numbers for 410, 420, 430 thanks.
Old Sep 20, 2021 | 01:12 AM
khomer2's Avatar
Learn to use it.
Old Sep 20, 2021 | 05:15 AM
DRBC43AMG's Avatar
Sorry I didn't get back to you sooner and I realize that my attachment didn't contain the list of the part #s. So here goes with apologies for the lateness, but guess better late than never.... BTW the pdf file contains a blank 1st page but all the info is on the following ones
File Type: pdf
