c43 draining battery
Old Dec 28, 2021 | 12:39 PM
PJmak's Avatar
I always suspected my battery was being drained in this car and I can confirm now that I got a new battery.
After a few days of sitting, the car would not start and needed to be jumped.
What are some common areas where this problem could be occurring? Ill do the proper battery drain test using the meter but if I can single out some common problems, it would be more efficient to start with those.
Old Dec 28, 2021 | 04:30 PM
cm60k's Avatar
Have to check the battery voltage range with ON & OFF..?, also the condition of the alternator & alternator regulator!,,
That will help to figure out if there's any other Elec. components work when the car is off..!!
-;-ZAYED-;-
Old Dec 29, 2021 | 12:48 PM
99CEEFOURTHREE's Avatar
99 c43,90 mustang gt supercharged convertible,07 acura tl type s, Hummer H3t pickup
Had this issue on mine when the car is in the garage: for a few months at a time without starting.Ate a few batteries when i learned that if you turn off the anti theft ie switch on dash with tow hook icon,it solved my issue.
Old Dec 29, 2021 | 01:58 PM
PJmak's Avatar
This guy?
Just start the car, flick it to off and turn the car off and thats it?
Old Dec 29, 2021 | 01:59 PM
PJmak's Avatar
-;-ZAYED-;-
Thanks man.
Is it worth buying the alternator regulator by it self and swapping it?
Old Dec 29, 2021 | 05:31 PM
cm60k's Avatar
Yes bro, why not!,
regulator has a contact brushes, they fade away after long period, it gives new life to stator & Electrode Rotor,,
i replace it many times..
-;-ZAYED-;-
Old Dec 30, 2021 | 04:16 PM
scuderiazane's Avatar
1999 Mercedes C43, 03 SL500, BMW 540i/6. Alfa Spider
I've been having the same issue with battery drain. A one year old battery and after sitting two weeks, battery is completely flat ( not even dash lights). I'll give this a try.
Old Dec 31, 2021 | 05:33 PM
This guy?
Correct
Old Jan 8, 2022 | 07:14 PM
PJmak's Avatar
I dont have that button
Old Jan 10, 2022 | 05:48 AM
DRBC43AMG's Avatar
Was it an option then? Didn't think so but seems it was. Perhaps in N. America only?
Old Jan 10, 2022 | 10:40 AM
PJmak's Avatar
This shows on the my VIN data card
551 ANTI-THEFT/ANTI-BREAK-IN WARNING SYSTEM
I heard 98 models alarm system is completely different vs the one in the 99
Old Jan 10, 2022 | 12:25 PM
MattCordell's Avatar
C43 AMG with a tune up
On 98 NA cars don't have this option from factory only 99 cars have it stock.
Buy a new C43 without power drain, you can afford it as you have several AMG's!
Adding another one won't hurt your budget will it?
Old Jan 11, 2022 | 05:46 AM
DRBC43AMG's Avatar
Old Jan 11, 2022 | 02:42 PM
cm60k's Avatar
This anti-theft & towing system can be found "as optional" with these following models:-
*97-00 "W202", with code: (552/882)
*98-02 "W208", with code: (F882)
*96-02 "W210", with code: (K552/882)
*98-04 "R170", with code: (551/882D)
-;-ZAYED-;-
Old Jan 12, 2022 | 06:27 PM
Sentinel83's Avatar
W202s, W209s, W204
Have you tried testing each fuse to see what the current draw is when the car is off?
Test the fuse/fuses that power the tow/anti-theft features when the car is turned off. If current draw is minimal then the problem may be with a different module or accessory.
I suspect that the current draw would be 50 to 150 mA (just a rough estimate).
My W209 CLK had the same problem. The seat module ended up being defective and would drain the battery within 24 hours.
Old Jan 14, 2022 | 11:47 AM
brad_c43's Avatar
'99 C43, '88 560SL
biggest thing for me was my radio i sat in my car off once for 30 minutes and the radio flicked on for a couple seconds and turned off. turned out the radio wasnt fully turning off when the car was off. a work around i found was to actually turn the radio off before i turned the car off and the drain stopped
Old Jan 14, 2022 | 02:51 PM
PJmak's Avatar
So some things in my car aren't connected yet since I'm still sort of working n the car. Passenger seat wires are disconnected and a few things behind the center console where the radio and ac are. Would this cause battery drain?
Old Jan 14, 2022 | 08:30 PM
Sentinel83's Avatar
W202s, W209s, W204
It's possible that not having some modules connected could cause a battery drain.
For example, if a W202 is driven with the climate control module disconnected, then the auxiliary fan will be constantly on while driving...even if the engine is cold and A/C is not turned on.
I would suggest connecting everything back to stock configuration and then see if the problem persists.
If it does, remove each fuse and use a multi-meter to measure the current draw between the fuse's terminals.
Cheers,
Sentinel55
