C43 project
Old Dec 31, 2024 | 10:42 AM
PJmak's Avatar
Originally Posted by mbdreamr
Manual swap 5.4 C43 would be a fun car. Would
be a good race against the e39 M5.
The c43 that my friend is swapping toa a 5.4 is also getting a six speed manual.
Old Dec 31, 2024 | 11:16 AM
mbdreamr's Avatar
1987 190e 2.3-16 sold and missed, 1966 220s, 2016 GL550, 1999 C43, 2006 CLS 55
@PJmak they really are putting the money and love into that car. I’ve read some threads of manual swap. I think the biggest challenge would be the driveshaft.
Old Dec 31, 2024 | 11:24 AM
PJmak's Avatar
Ive seen plenty manual swapped m113s, Clk55, w203 with a 5.4 swap and a six speed which i also soon getting a m113k kompressor adden on top and a limited slip.
Also a c36 six speed. These are all local to me.
Old Dec 31, 2024 | 10:21 PM
mbdreamr's Avatar
do you still have your c55?
Old Dec 31, 2024 | 10:24 PM
mbdreamr's Avatar
I had arranged to have the car picked up by a tow company at 4pm and they flaked on me. Didn’t bother to call or text. Luckily someone else we knew was able to come tow it at 7pm for a short 2 mile distance.
So the the car is finally at a buddy’s shop on the hoist. Tomorrow the work will begin and the engine will be removed.
I’ll have to swap over some parts like the intake, harness, engine mounts then back into the car.
had to remove the front bumper for the tow.
Old Dec 31, 2024 | 10:55 PM
mbdreamr's Avatar
I’d be interested to do the manual swap. I think the most challenging piece may be the driveshaft.
Old Jan 1, 2025 | 01:37 PM
  #32
PJmak's Avatar
my friend can do it for you. He does top quality work and is pretty resonable compared to big shops.
Hes swapped many m113 cars to manua). Do you have instagram bro?
Old Jan 1, 2025 | 01:38 PM
  #33
PJmak's Avatar
Still have the c55 and my red c43..hoping I can have the c43 repainted this year.
Old Jan 1, 2025 | 10:58 PM
  #34
mbdreamr's Avatar
That’s nice. I was thinking of doing it myself. But that’s something I’ll consider down the road
Old Jan 2, 2025 | 11:50 AM
  #35
edhu's Avatar
'98 C43
any info on your friend who can do the swap?
Or parts needed? Maybe I can source some myself as well.
Old Jan 2, 2025 | 12:37 PM
  #36
PJmak's Avatar
I can either give you his number or instagram. Send me a PM with your phone number.
He can also source parts for you Im sure
Old Jan 2, 2025 | 06:26 PM
  #37
ECTurboGSX's Avatar
98 C43, 15 Alfa 4C LE, 18 Tesla Model 3 DM Perf, 08 Duc S1000, 02 Duc 998, 98 Duc 748, 01 Miata
What kind of quotes were you getting for a full respray? Im thinkigng by summer Ill be respraying my red c43
I didn't have them quote anything on the C43. It was some stuff on my Eurovan, but not a full respray on that either. My friend had taken a JCW front and rear fascia in for them to paint and paid a couple hundred. Granted, they just had to prep and spray it, no masking or body work.
Old Jan 3, 2025 | 08:47 PM
  #38
mbdreamr's Avatar
I ran into a problem guys. Installed the motor, running good. My battery was bad so the car was in neutral with the battery disconnected I removed the key after putting the car in park.
upon installing a new battery the key won’t turn in the ignition.
hoping it’s not the EIS.
any advice?
Old Jan 4, 2025 | 06:48 AM
  #39
speed43's Avatar
1999 C43 Amg
any advice?
I had this problem in my first c43 after a dead battery. I had to leave the key in the ignition over night. That worked for ME, worth a try. You can also try this before leaving the key on the ignition over night. Disconnect the negative cable on the battery and wait 10 minutes. Try key again….
Old Jan 4, 2025 | 06:58 AM
  #40
speed43's Avatar
1999 C43 Amg
Also found this you can try if you haven’t already. Some say has nothing to do with the problem others say different, worth a try. There are two main scenarios that could cause your key to be unable to turn in the ignition. These are:
  1. Your key fob battery is low or empty. This prevents the Electronic Ignition System (EIS) from functioning.
  2. The Driver Authorization System (DAS) is not functioning, and thus failing to verify the key properly when inserted into the ignition.
Old Jan 4, 2025 | 11:01 AM
  #41
mbdreamr's Avatar
fortunately I left the key in the ignition over night. So I’m hoping and praying that it worked and the car cycled and recognized the key.
I appreciate your advice my friend.
Old Jan 4, 2025 | 11:02 AM
  #42
mbdreamr's Avatar
Thanks my friend! Hoping the car recognized the key. Otherwise I will try changing the key fob battery. It does lock and unlock the car.
keeping my fingers crossed.
Old Jan 4, 2025 | 05:22 PM
  #43
mbdreamr's Avatar
No luck unfortunately. Guessing the EIS is affected. I saw a few places that rebuild. But I’ll have to do some
More research to understand the problem
what a crap out.
Old Jan 5, 2025 | 04:10 AM
  #44
DRBC43AMG's Avatar
Do you have another key fob for the car?
Old Jan 5, 2025 | 11:44 AM
  #45
mbdreamr's Avatar
Unfortunately I do not. I was doing some research that it might have fried the key. But then again the key functions to lock and unlock the doors and trunk. I need to have the car scanned with Star or Xentry to see if it’s the key or EIS.
Dealer sure rips off for key too. I think it’s like $500 now.
Old Jan 5, 2025 | 05:37 PM
  #46
speed43's Avatar
1999 C43 Amg
what a crap out.
Sorry to hear that , weird that the EIS got messed up.
Hopefully you got that c43 at a great price.
Old Jan 6, 2025 | 01:14 AM
  #47
mbdreamr's Avatar
I did get the car for a good deal. Still trying to figure out the issue. Will be contacting some people tomorrow and try to get the car scanned.
Wish me luck
Old Jan 6, 2025 | 10:49 AM
  #48
PJmak's Avatar
Key is probably dead. I wouldnt jump to conclusions with the ignition switch. WHen my key died, it wouldnt start the car but it was lockingad unlocking things too.
If you have a valet key, try starting the car with that.
Old Jan 6, 2025 | 12:19 PM
  #49
mbdreamr's Avatar
I only have one key for the car
Old Jan 6, 2025 | 04:09 PM
  #50
ECTurboGSX's Avatar
Yeah, I had similar issues and ended up buying a new key from the dealer. It wasn't cheap, but it fixed the issue. I did have a valet key, which helped confirm that the issue was with the key and not the car.
