Tire pressure
i'm on 20's, cast wheels, h&r springs, 245/30f 275/30r continental dws, in CA. I found the best pressures for me are 38f/36r (cold). Haven't cracked a rim yet (thank god). None of my passengers have complained about the ride. And still very responsive taking corners. The highest that its gone this summer is 42f 39r, after driving around. This works for me, but i'm sure under normal circumstances it won't vary much, maybe just a pound or two.
Hope this helps.
Hope this helps.
Think it's perfect and so far the tires are wearing really nice.
I'd go for 40 (hot) all around and adjust to your liking from there.
this is on non run flat summer tires.
running the p-zero run flats on 19s - i'm doing 36 cold, which gets to 39/40 hot. wonder if i should bump em up a bit?
actually think it was about right for that set-up.
BTW - gas cap is not always authoritative. Always good to check inside the driver's door frame.
