C450/C43 AMG
C450/C43 Wheel Fitment Guide
Old Jul 30, 2019 | 11:08 AM
  #401
djalali59's Avatar
'17 AMG C43
Checking back in regarding my 18 inch wheel upgrade...
Wow. What a difference. I went from considering an SUV for my next car due to the ride quality, to falling back in love with my car. It actually rides like a Mercedes now! Plus I think it looks even better, seems to squat more.
I had success with Niche Missano MR117, 18x8 ET30.
I mounted Continental DWS06, 225/45 all around.
Minor note: handling sharpness is slightly less, I’m assuming due to higher profile tires. But I’m willing to give this up for the ride comfort every effing day of the week.
pics:
Old Jul 30, 2019 | 12:52 PM
  #402
alexasa's Avatar
c
Originally Posted by TModelle
Does anyone know if a 20x9 would ever fit in the front?
maybe w/ 3 degrees of camber and and a stretched tire
Old Jul 30, 2019 | 07:29 PM
  #403
TModelle's Avatar
C190
That bad, huh? Ok. Just exploring.
Old Aug 6, 2019 | 03:12 PM
  #404
alexasa's Avatar
c
might try these out myself - need hub rings but otherwise would bolt up (somewhat conservative fitment for lowered cars but perfect for stock height)
Old Aug 7, 2019 | 02:07 AM
  #405
silentj's Avatar
SQ5
Nice find. Planning on running something like these on unlowered. Would the main concern be that the fronts don't clear the brakes, requiring spacers, and in turn resulting in excessive poke?
Ben.
Old Aug 7, 2019 | 03:10 PM
  #406
mo11's Avatar
2017 C43
Hey Alexasa, have you looked into VsForged? I’ve been really happy with mine! Might be worth the +/-$1200/set difference... you can get them in 19x8.0f and 19x9.5r or whichever widths you prefer with the exact offsets you really want. Fully forged, monoblocks... no more spacers no more rings. You can even request it in ball seat. Anyways, just a suggestion...
These look good in my opinion...
here’s their website.
http://vsforged.com/vs08/
or you can also look at it at getyourwheels.com, I’m sure you already know that website.
Old Aug 7, 2019 | 03:26 PM
  #407
alexasa's Avatar
c
How much are they for a set?
Typically I've known BC Forged to be the cheapest forged wheels at around 3500/set
Old Aug 7, 2019 | 05:04 PM
  #408
mo11's Avatar
2017 C43
I have a good relationship with my tire guy here in southern ca. I don’t have the exact amount but, I’m sure I didn’t pay more than $2400/set out the door, for 19x8.5f and 19x10r. Getyourwheels website is around $2500/set. Not sure about tax and s&h to your area. You might wanna go through the shop you use and see if they can get you a good deal as a dealer.
Old Aug 8, 2019 | 03:34 PM
  #409
Synarchist's Avatar
2017 C43 W205
19 x 8.5 +35 with OEM tire size
19 x 9.5 +35 with OEM tire size
Will I be needing spacers with these set up? Thank you!
Old Aug 8, 2019 | 03:38 PM
  #410
djrabbi's Avatar
EQS AMG, E53 AMG, GLE63s
Fronts yes. Rears no
Old Aug 8, 2019 | 04:07 PM
  #411
alexasa's Avatar
c
rear is too aggressive and front needs ~5mm (less if lowered)
Old Aug 10, 2019 | 08:37 AM
  #412
Mbmhyu's Avatar
C43 amg sedan 2018 4 door
C43 wheel fitment
So verdict whats the wides and safest size for front and back without ruin geometry and having more preformance gains instead of just looks and negative preformance gains please summarize it please ! Got lost on the threat
Old Aug 10, 2019 | 02:44 PM
  #413
silentj's Avatar
SQ5
Just wondering whether there's any risk in the following rims not fitting. I don't have any where local that I can test fit the rims so basically have to order online and prey they fit. Rims will be going on an unlowered wagon.
19x8.5 +32 front
19x9.5 +45 rear
I'll most likely go with 235/40 and 265/35 tyres.
Ben.
Old Aug 10, 2019 | 07:02 PM
  #414
JasonGinWV's Avatar
'19 C43 and TBSS
What do you think of the 19x8.5 32 for use as a square set for winters/all seasons on stock height?
Thanks!
Jason
Old Aug 13, 2019 | 03:52 PM
  #415
viperx100's Avatar
2013 BMW 335is, 2019 Mercedes Benz C43 AMG
Man, so much awesome info in this thread for a newbie. Many thanks to all that contributed! I have a question about fitment on possible wheel purchase for my 2019 C43 coupe.
Alexasa mentioned
"If I had to choose a set-up again, I would run (this will be flush with the fenders):
19x8 et25 on 235/40/19 front
19x9 et 40 on 265/35/19 rear"
I am interested in Zito ZF05 wheels which are available in 19x9 front and 19x10 rear. I was told that some people are running these wheels with the following setup: 19x9 et 25 front and 19x10 et 45 rear. Would that work on stock suspension setup with 225/40/19 and 255/35/19 stock sized tires? Would going up to 235/40/19 front and 265/35/19 rear also work with the stock suspension and those wheels sizes? This way the fronts wouldn't deal with the minor stretch of a 19x8 rim (plus these Zito wheels aren't available in that size). Has anyone run these wheels on their C43 coupes?
Your guidance is appreciated. Thanks in advance!
Old Aug 13, 2019 | 04:07 PM
  #416
alexasa's Avatar
c
Alexasa mentioned
19x9 upfront will poke to clear front suspension
Old Aug 15, 2019 | 11:58 AM
  #417
viperx100's Avatar
Thanks, Alexasa and NYCSoil
Question, I am pretty set on 19" Niche M116 Misano gunmetal wheels and NYCSoil ran the following setup with flush fitment:
"Niche:19x8.5+34 (3mm spacer) 225/40 19x9.5+50 (no spacer) 265/35"
Since a lot of you are running 235 / 265 for front and rears, I was wondering how I would need to adjust the front spacer size to make sure that I am also flush with
235/40/19 in the front (what spacer size would I need instead of 3mm or would that be just fine?)
Thanks.
Old Aug 16, 2019 | 02:16 AM
  #418
silentj's Avatar
SQ5
Just looking for an opinion on some wheels im looking to purchase.
Fronts are available in 19x8 +35
Rears are available in 19x9 +38 or +48
I'll be going with 235/265 tyres. At this point, i'll be leaving it unlowered
Is 19x9 +38 in the rear, un lowered, too aggressive? Im thinking +48 might be a safer bet.
Old Aug 16, 2019 | 09:26 AM
  #419
TModelle's Avatar
C190
I think 48 would be perfect in the rear if you’re going for 35 in the front.
Old Aug 16, 2019 | 09:55 AM
  #420
alexasa's Avatar
c
lowered? or stock?
can't guarantee that 19x8 +35 will clear inner suspension - would recommend a 5mm spacer
stock height 19x9 +38 is really aggressive - but +48 is conservative
Old Aug 16, 2019 | 09:58 AM
  #421
alexasa's Avatar
c
Thanks.
would recommend a spacer for the rear for a more level aggressiveness front and rear - that front spec is borderline poke territory at stock height and the rear is super conservative and sunk in a bit.
Old Aug 16, 2019 | 10:00 AM
  #422
alexasa's Avatar
c
Alexasa mentioned
no it would not work
19x9 basically doesn't work unless going hella stance boi status (without poking, poke fitment does not = fitting IMO).
Old Aug 16, 2019 | 10:56 AM
  #423
viperx100's Avatar
Good to know. How about the possibility of a setup if the only possible option for a wheel are
19x8.5 (+ 42 or + 25)
19x9.5 (+ 48 or +38)
Can either of the offsets work and if so, with what size spacers needed?
Also, I know that many of you are running 235/40/19 and 265/35/19 tires but if I want AS3+ (and I do), those do not come in 235/40/19 size, so I would stick with 225/40/19 stock fronts and 265/35/19 rears. Is there anything negative about this setup?
Thank you.
Old Aug 16, 2019 | 11:06 AM
  #424
alexasa's Avatar
c
Thank you.
not the worst - stock - the front tires are a smedge taller than the rear and you'll basically be reversing that given the spec you provided. The front wheel gap will look bigger because of it however.
i'd go 42 w/ a 12mm up front and 48 in the rear (you can also have a machine shop mill the back spacing off the et25)
Old Aug 16, 2019 | 11:27 AM
  #425
viperx100's Avatar
So pardon the ignorance (not questioning you, just want to make sure that I understand.)
With your suggested 42mm upfront, it looks like the inner rim will be 21.7mm closer to the suspension strut). The 12mm spacer will fix that?
The 48 in the rear looks a lot closer to stock with 8.7mm closer to the suspension strut. I am guessing that's not an issue because there's no huge caliper/control arm to clear like in the front?
Thanks!
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
