C450/C43 AMG
C450/C43 Wheel Fitment Guide
Rating: Thread Rating: 3 votes, 5.00 average.
Old 08-16-2019, 11:37 AM
  #426
alexasa's Avatar
c
Originally Posted by viperx100
So pardon the ignorance (not questioning you, just want to make sure that I understand.)
With your suggested 42mm upfront, it looks like the inner rim will be 21.7mm closer to the suspension strut). The 12mm spacer will fix that?
The 48 in the rear looks a lot closer to stock with 8.7mm closer to the suspension strut. I am guessing that's not an issue because there's no huge caliper/control arm to clear like in the front?
Thanks!
et42 - 12 = 30 - effective offset is et30. 19x8.5et30 is aggressi​​​​​​​ve on stock suspensi​​​​​​​on but wi​​​​​​​ll 100% clear i​​​​​​​nner.
rear can fi​​​​​​​t up to 10.5 w/ a 305 but that wouldn't make sense from a practi​​​​​​​cal dri​​​​​​​vi​​​​​​​ng experi​​​​​​​ence because the car exhi​​​​​​​bi​​​​​​​ts understeer and needs more front ti​​​​​​​re not more rear to make i​​​​​​​t more neutral i​​​​​​​n the corners (and i​​​​​​​t si​​​​​​​mply doesn't put enough power down to justi​​​​​​​fy anythi​​​​​​​ng over a 275 i​​​​​​​f not upgradi​​​​​​​ng turbos (wi​​​​​​​th a proper UHP ti​​​​​​​re)).
Old 08-16-2019, 01:04 PM
  #427
TModelle's Avatar
C190
I forgot if anyone has asked this before, but has anyone used a 245 front successfully before?
Old 08-16-2019, 01:09 PM
  #428
alexasa's Avatar
c
i ran a 245 - the main problem here i​​​​​​​s getti​​​​​​​ng the aspect rati​​​​​​​o correct for the di​​​​​​​ameter. you ei​​​​​​​ther have to downsi​​​​​​​ze or upsi​​​​​​​ze and nei​​​​​​​ther i​​​​​​​s i​​​​​​​n an i​​​​​​​deal range.
gotta step up to a 255 - only one user i​​​​​​​s doi​​​​​​​ng thi​​​​​​​s wi​​​​​​​thi​​​​​​​n the fenders correctly
Old 08-16-2019, 01:11 PM
  #429
alexasa's Avatar
c
repost
Originally Posted by mo11
Recently switched from 20’s to 19’s. My previous setup were 20x8.5 +32 offset with 245/35 front, and 20x10 +55 offset rear. The tire diameter was getting too tall it was affecting how quick i could take off from a stop.
After doing some calculations on tire diameters and the lust to get wider tires without risking the 4matic f/r ratio. I decided to switch to 19x8.5 +30 offset front, and 19x10 +55 rear. Matched it with 255/35 and 295/30 Michelin Pilot Sport 4s, respectively. I knew the diameter would fit since my 20’s were taller. I’m still on H&R springs and as usual the concern was the suspension up front and the wheel well in the rear.
When I first saw the tires for the rear, I really thought there was no way it would fit in the back. Even the guys in the shop were crossing their fingers, hahaha!
So, to those who dare to drive with these tolerances, I’ll be attaching pics and how the car looks. I do have very slight rubbing on “C” mode on dips, but who ever drives on “C”, anyways, hahaha! Sport+ is preferred mode but still slight rubbing on big dips, and only the fender liners. Nothing touches the chassis and paint. I can say, the tire widths outweighs the slight rubbing.... very negligible.
Wheels: VSForged VS-06, forged monoblock, brushed aluminum.
Fender gap front,
Fender gap rear,
Fender clearance: front,
Rear,
Now to the gnarly part...
suspension clearance: right front,
Left front,
Rear inner fender clearance,
I’m very happy with the results!
I know it’s not for everyone, but I hope this helps anyone willing to go this route...
Thanks to everyone who posted their specs and pics on this thread. I know it helped me a whole lot!
Old 08-16-2019, 02:28 PM
  #430
viperx100's Avatar
2013 BMW 335is, 2019 Mercedes Benz C43 AMG
Originally Posted by alexasa
et42 - 12 = 30 - effective offset is et30. 19x8.5et30 is aggressive on stock suspensi​​​​​​​on but wi​​​​​​​ll 100% clear i​​​​​​​nner.
But I am also able to get a 10mm spacer for the front, making it et42-10 = et32 which is very close to the stock et33. Wouldn't that be the closest fit? Or did you recommend the 12mm because of the 8.5" rim?
Old 08-16-2019, 02:31 PM
  #431
alexasa's Avatar
c
I recommended a 12mm because it's the only size that fits over the OEM hub in a traditional spacer design (OP has more info in this thread more specific to the issues fitting a 10mm spacer).
Old 08-16-2019, 02:37 PM
  #432
viperx100's Avatar
That makes sense. Thanks a lot. I'll post some pics once I get everything on the car. You've been a huge help. Thanks for being patient.
Old 08-16-2019, 02:49 PM
  #433
Mbmhyu's Avatar
C43 amg sedan 2018 4 door
Most aggressive but fitment guaranteed with no rub
For my c43
Front 9x9.5
Rears 9x8.5
What the max size tires i can run if i want them aggressive and flush but no rub or compromising preformance??? Someone please share some insights
Will 225/40r19 255/35r19 work or can i go more aggressive i want forsure fitment and clearance because i have to order online and its final sale any informantion thats not just specalation would be appreciate... i want as big and flush with fenders and at a aggressive stance without a risk of not fitting
Old 08-19-2019, 06:54 PM
  #434
Synarchist's Avatar
2017 C43 W205
Rear
19 x 9.5
ET 38
Front
19 x 8.5
ET35
With stock tire size , what would I need to make them fit if I go with this set up? Thank you!
Old 08-19-2019, 09:30 PM
  #435
TModelle's Avatar
C190
repost
Thanks for the repost. Very useful information if I decide to go for a 255 Front in the future.
  #436
TModelle's Avatar
C190
Originally Posted by Synarchist
Rear
19 x 9.5
ET 38
Front
19 x 8.5
ET35
I don’t think that rear is going to fit.
Old 08-25-2019, 03:29 AM
  #437
Synarchist's Avatar
2017 C43 W205
If I were to lower my car on H&R sports springs using the 19" OEM AMG wheels , what size of spacers would you recommend to use to have a flush stance? Thank you!
Old 08-25-2019, 10:33 AM
  #438
alexasa's Avatar
c
12/15 or even 12/20 will be good
use 15mm up front at your own risk
Old 08-25-2019, 01:46 PM
  #439
Synarchist's Avatar
2017 C43 W205
Thank you for the info!!!
Old 08-25-2019, 02:21 PM
  #440
miztahsparklez's Avatar
2019 C43
15/20
Stock height 12/15
Old 08-31-2019, 03:36 PM
  #441
viperx100's Avatar
Many thanks to this thread and especially to alexasa and NYCSoil for their fitment help. Finally, put on new wheels/tires yesterday and I am very happy with how everything turned out. Niche M204 19" wheels 19x8.5 +42 front, 19x9.5 +48 rear. Tires are Michelin AS3+ 225/40/19 front and 265/35/19 rear. Supreme Power 12mm spacer in the front and none in the rear. The rears are just a tiny bit more tucked in than the fronts, but I don't think that I'll bother with a spacer. Haven't had too much time to hoon, but so far I can say that I love the look and there's no rubbing at all when turning and the new tires are night/day difference from the awful Contisport5s.
The following 2 users liked this post by viperx100:
Mojorodt-23 (02-20-2020), Travis_MB (09-27-2019)
Old 09-01-2019, 12:21 AM
  #442
TModelle's Avatar
C190
Looks great! Very nice!
viperx100 (09-01-2019)
Old 09-04-2019, 09:57 AM
  #443
TModelle's Avatar
C190
Just got these forged AMG reps fitted. 20x8 ET30 and 20x9 ET42 on 235/35 and 265/30. The wheels weigh 26.5lbs and 28.5lbs respectively.
Interestingly, the ride is more comfortable than the stock 19” wheels and non-run-flats. I attribute this to the increase in overall diameter.
The following 4 users liked this post by TModelle:
Dieseldan9 (09-04-2019), MarsRedCLK (10-19-2019), Travis_MB (09-27-2019), viperx100 (09-04-2019)
Old 09-04-2019, 09:59 AM
  #444
RichardCranium3's Avatar
'19 CLS450
Looks great!
Old 09-26-2019, 09:11 AM
  #445
bhcubed's Avatar
2016 C450 AMG
I'm considering the following wheel & tire combo for my C450:
BBS SX
Front: 18x8 et35 225/45ZR18
Rear: 18x8 et35 245/40ZR18
Tires are Michelin Pilot Sport A/S3+. I'm at stock height. Tire rack says the wheels come with 4 Required centering ring , 4 Required centering ring clip. Tire rack says guaranteed fitment and hub rings are from BBS. Anyone see any issues with this fitment? Total price shipped for the package is around $2k on tirerack. I'm hesitant to go up to 19" wheels due to lower ride quality and all the issues I've had with my stock AMG 5 spoke 18" wheels, albeit, most likely caused by the run flats. I'm looking at aftermarket wheels due to the wheel issues and I currently have one cracked (repaired) wheel and probably at least 1-2 bent wheels. I know BBS has a pretty good reputation, but are the wheels any stronger or less prone to bends and cracks then the stock AMG wheels? I don't want to fork out the several thousands of dollars for fully forged wheels either.
TIA - Bill
Old 09-26-2019, 09:16 AM
  #446
alexasa's Avatar
c
BBS SX
TIA - Bill
set-up doesn't really make sense. gonna be goofy with that really square tire out rear and slight stretch on the front. et35 will also be way too close to front inner suspension to recommend. i slightly rubbed w/ at et30 w/ a slightly wider tire
no reason not to go with a square set-up at that pace.
Old 09-26-2019, 12:49 PM
  #447
Star4life's Avatar
2017 C43 AMG
BBS SX
TIA - Bill
run 245 40 around square. that off set it should work. plus the tire stretch will be even then.
Old 09-26-2019, 02:35 PM
  #448
bhcubed's Avatar
2016 C450 AMG
what square set up would you recommend? Are there any disadvantages? One obvious advantage is being able to rotate the tires.
You think an 8" wheel with 245 and +35 offset will clear in the front?
thanks, Bill
Old 09-26-2019, 02:40 PM
  #449
alexasa's Avatar
c
thanks, Bill
it won't clear - need to go more aggressive or less tire
Old 09-26-2019, 03:48 PM
  #450
Star4life's Avatar
2017 C43 AMG
it will be close.
i ran et 33 with a thick 235. about 6mm of clearance.
he may need a 2mm spacer to clear.
235/40/19 would be a better square setup probably if thats what he would want but you would be burning the rears for days.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
Quick Reply: C450/C43 Wheel Fitment Guide
