C450/C43 AMG
12.1@115.2mph with a piggyback
Old Jan 19, 2018 | 02:19 PM
  #126
threefirs's Avatar
2017 C43 AMG Cabriolet Black/Cranberry Red
Originally Posted by Lazz83
On the videos I have seen for Racechip and JB1 they just launch the car from a start no torque breaking to get the C43 below 4 seconds.
Not happening. The car has way too much turbo lag with any tune to launch with no break boost and be sub 4.0 0-60MPH. Whatever is doing that reading is inaccurate.
If you don't break boost the car, you won't even get the car down the quarter at 13.5 lol
Old Jan 19, 2018 | 02:28 PM
  #127
removedCFGaccount's Avatar
Former Member
CLS
With Racechip GTS black, starting from a stop and flooring it, my Dragy gps shows maximum g forces from zero to about thirty-five. Believe whatever you wish.
Old Jan 19, 2018 | 03:04 PM
  #128
Lazz83's Avatar
2017 AMG C43, AWE Touring, BMC Air Filters- 2015 BMW X3 3.5i (JB1 Equipped)
Look at the video that was posted of the C43 Racechip 0-60 run- performed by racechip, It don't seem like he is brake boosting in that video though.
Old Jan 19, 2018 | 03:07 PM
  #129
Former Member
CLS
Which is consistent with my data-max g forces pretty much from zero by just flooring it.
Old Jan 19, 2018 | 07:57 PM
  #130
waisoserious's Avatar
GLC43, X P100D, S P100D, CT200H
He is 100% torque breaking.
1. It doesnt sound like idle
2. They just dont hold the revs at 2000rpm, they release the brake the moment it hits 2000rpm.
While this is not Racechips official video, see 1:54 and look at the tach vs the speedo.
Old Jan 19, 2018 | 08:38 PM
  #131
threefirs's Avatar
Originally Posted by waisoserious
https://www.youtube.com/watch?v=IV_bsv4nBK0
https://www.youtube.com/watch?v=zEzyUxM9csU
Assuming this is in Europe - do cars come without governors there?
Old Jan 20, 2018 | 03:50 AM
  #132
Speed governors? Or RPM Neutral Rev Limiters?
Old Jan 26, 2018 | 06:09 PM
  #133
18bora's Avatar
2020 GLC 63
Sad news
http://www.etownraceway.com/mydocume...estructure.pdf
Old Jan 27, 2018 | 08:05 AM
  #134
Nekko's Avatar
2002 CLK 430
Strange
Originally Posted by 18bora
I wonder why they are only closing the drag part of the facility?
Are costs to keep it going so high that the track can survive and do better without it?
Old Jan 27, 2018 | 11:42 AM
  #135
ClashBandicoot's Avatar
2018 C43 AMG
real depressing. I guess i'm headed to island or atco this year, any takers?
Old Jan 28, 2018 | 03:36 PM
  #136
Narry's Avatar
Former Vendor of MBWorld
C260
Very impressive for just a Stage1 tune!
Old Jan 28, 2018 | 07:23 PM
  #137
18bora's Avatar
2020 GLC 63
It is depressing since Etown is only 11 miles from my house and both Island and Atco about 55 miles of opposite directions.
Old Feb 19, 2018 | 04:12 AM
  #138
Cartman417's Avatar
Range Rover
So with race chip he ran a 3.95 0-62?
so like 3.8 to 60?
Is this the black tune by race chip
Old Feb 19, 2018 | 10:11 AM
  #139
agchenry's Avatar
2018 C43
Bora didn't use a race chip. He used a BMS JB1.
Old Feb 19, 2018 | 04:36 PM
  #140
18bora's Avatar
2020 GLC 63
so like 3.8 to 60?
I don't know much about the race chip, but BMS taps into the same 3 sensors. BMS however has 3 maps, 2 of which are preset (1&2 +3/5psi) and map6 which gives you full control of boost, with a built-in safety.
Old Feb 20, 2018 | 10:08 AM
  #141
Lazz83's Avatar
To bad no one is custom tuning the JB1 for the C43- sounds like it would really push things to another level. especially with 18bora success with tuning.
I am still trying to decide between the Racechip or JB1
Old Feb 20, 2018 | 10:14 AM
  #142
Former Member
CLS
I know nothing of the Burger chip, but my experience with the GTS black has been very rewarding.
Old Feb 20, 2018 | 02:07 PM
  #143
agchenry's Avatar
2018 C43
its not difficult to “self tune” with the JB1. All you are really doing is picking the psi over stock boost at a particular rpm range. For example 3.2 over ecu boost from 1000 -1500 RPM, 3.5 over ecu boost from 1500-2000 Rpm and so on. The ranges are per 500 RPM. The key to “self tuning” is being able to connect to the jb1 with either a BMS cable for a computer or Bluetooth ($140 at bms ) for an iPhone or iPad. Once you have a way to connect to the JB1 you can log,select map, or modify map6 to the boost levels over stock ecu boost. You can change boost over stock in increments of 500RPM. Hope that clears things up a bit.
Old Feb 21, 2018 | 09:19 AM
  #144
Lazz83's Avatar
Yes it does, thanks for the info
Old Feb 21, 2018 | 06:31 PM
  #145
C43Ayemgee's Avatar
2018 C43 AMG
So how much hp do you get from JB1 on 91 octane?
and would you hit mid/high 3's 0-60?
Old Feb 21, 2018 | 08:47 PM
  #146
agchenry's Avatar
2018 C43
I get to 60 before 4 sec all the time (so long as you tourque break)
Old Feb 21, 2018 | 08:57 PM
  #147
Former Member
CLS
Brake or break?
Old Feb 21, 2018 | 09:01 PM
  #148
agchenry's Avatar
2018 C43
Originally Posted by CFG
Brake or break?
he he what you said (brake) lol
Old Feb 22, 2018 | 10:58 AM
  #149
Lazz83's Avatar
Yeah but even with that being said Berger needs to update the JB1 its been several years and that's a lifetime in the electronics world.
I remember the good old days when I flashed my 5.0 Mustang with an SCT Tuner through the OBDII, it came with three flash tunes, 89, 91 & 93 octane and could be put back to stock at any time. The best feature was you could log all data, including A/F ratios under real world, full throttle runs and it would be specific to your car. Then your tuner would custom map a tune based on that data and email it to you. This is what the JB1 sort of seems like but a lot less parameters to adjust. I remember my A/F ratio always needed to be custom tweaked.
Why can't Berger come out with something like this or anyone else?
Old Feb 22, 2018 | 11:25 AM
  #150
Former Member
CLS
My guess, from racetune’s ambiguous site, is they can do this if you want, but I don’t know if they use your data or just wing it.
