C450/C43 AMG
KN Filters or BMC?
Old Jan 23, 2019 | 01:53 PM
djrabbi's Avatar
EQS AMG, E53 AMG, GLE63s
KN Filters or BMC?
I know neither probably won't give power but if one had to choose, which would it be and why?
Old Jan 23, 2019 | 04:10 PM
Dieseldan9's Avatar
2018 C43 AMG Brilliant Blue Metallic
Bmc they look better.... U know red makes 10hp easy!!
Also look into burger intakes those make power and increase sound.
I will be getting a jb4 and intakes when weather breaks
Old Jan 23, 2019 | 05:51 PM
ShakyTom's Avatar
C43 AMG Coupe
BMC.
Old Jan 23, 2019 | 07:02 PM
djrabbi's Avatar
I looked at it but doesn't it seem it will be just sucking in the heat from the engine? Unless there is a heat shield I am not aware of?
Old Jan 24, 2019 | 06:50 AM
Dieseldan9's Avatar
Yes you are correct the intake temps need to be looked at but according to BMS that is the only way of making them fit.
There is a heatshield underneath the intakes ,,,tho I am not sure how much it helps.
BMS did some dyno runs on a C63 with intakes that are similar and saw 10 or so plus HP just from intakes.
I know that is not our car but with the increase noise and throttle response plus 10 to 15 HP I am going to give them a try.
We are close so if you don't grab them we can meet up after the weather breaks.
Old Jan 24, 2019 | 04:13 PM
st33zy's Avatar
2018 C43
I'm waiting on v2 when they provide smaller filters.
Old Jan 24, 2019 | 05:09 PM
DVision44's Avatar
c43 Amg coupe
This^^^ . I'd just be patient..
Old Jan 24, 2019 | 09:04 PM
Dieseldan9's Avatar
I did not know they where changing design
Y r they changing filters?
What would be the advantages of V2?
Old Jan 24, 2019 | 10:00 PM
b6tbfmp's Avatar
Mercedes and BMW
Current sized filters are hitting the underside of hood insulation therefore they are going with smaller filters. No advantages.
Old Jan 25, 2019 | 03:32 AM
Dieseldan9's Avatar
Thanx for heads up
Old Jan 25, 2019 | 10:05 AM
st33zy's Avatar
2018 C43
guys, it's not confirmed. They commented on Facebook that they MAY change the design to smaller filters IF they receive enough complaints about the current clearance issues.
So far, almost everyone's complained so hopefully the complaints continue to roll in forcing a re-design. I want the intake as much as the next person but I'm not going to make the plunge till it's more ideal.
Old Jan 25, 2019 | 01:07 PM
Dieseldan9's Avatar
Same here I put it off also mostly because of weather but also because it was there first stab at the design
Old Jan 29, 2019 | 07:38 PM
djrabbi's Avatar
Who is coming out with V2? KN or BMC? I just picked up BMC filters on Amazon for $80 since I think it was a pricing error?
Old Jan 29, 2019 | 07:55 PM
Dieseldan9's Avatar
Burger but not confirmed
Old Jan 31, 2019 | 02:32 PM
COOPERDB's Avatar
NB8 PARACHUTE
Several years ago I purchased a set of BMC filters on Amazon for $85 shipped -
I thought it was a pricing error but the order went thru -
The filters "looked" like BMC's but they were knock-offs
and the vendor was extremely slow in refunding -
I called BMC to let them know and was told that
BMC has a problem with fake BMC filters being
sold cheap on Amazon -
He said that ECS sells the real BMC filters as BMC
ships to ECS every week -
https://www.ecstuning.com/
Thank-You
D.B.
