Performance & handling mod wish list.
Mine are:
Downpipe- CKS or Weistec Maybe
Ultra Racing F & R lower strut bars
H&R lowering Springs ( and camber kit to maintain OEM camber )
19" Forged HRE wheels & upsize tyres to 235 / 265 section F & R
( I already have a Eurocharged map) .
Mine are:
Besides a great tune (piggyback or ECU)
Can also add in
C450/C43 Turbo upgrade (Turbokits.com or Weistec),
Forged JE pistons
Total Seal piston rings
Forged 4340 Pauter Rods
Weistec 722.9 Transmission pan
...Ultimate “Xmas” wish list, but may not be realistic at this time with the market support of our model, but you did say “wish list” would be Weistec upgraded transmission, upgraded fuel rail, injectors and fuel pump 😁
Can also add in
Forged JE pistons
There's still not even a decent CAI for this car yet ffs! At this stage, as its reached facelift, I can't see one being made either.
The BMS and MST are both flawed and yet to see anyone with objective proven gains on them.
BMW and Audi for example have countless CAIs available tough for most of their M / S / RS models.
They even have a mid chassis strut.
A stiffer chassis is always better for both ride and handling.
The stiffer the chassis the more precisely the suspension can control the wheel travel, and less chassis flex means less creaking actually.
Given that the subframe are connected with rubber bushes, a stiffer connection will improve handling. Obviously there maybe be some extra NVH, but wouldn't any different to a stiffer C63 or E63.
Stiffening the chassis with braces, will reduce chassis flex.
Less chassis flex will allow the suspension to better control wheel travel, as wheel deflections will result in less flex of the chassis. Whenever the chassis flexes it takes the forces away from the suspension.
Therefore in your example on acceleration and braking, longitudinal weight transfer would be better with a stiffer chassis, not worse.
Is the former, how much beefier does it feel than the OEM ones?
