C450/C43 AMG
Tire Size Limit
Old Apr 24, 2021 | 01:53 AM
Senid Avdic's Avatar
Mercedes AMG C43 Sedan
Tire Size Limit
It's time for me to purchase some new tires. My wheels specs are 19x8.5 et 30 for the front and 19x9.5 et 42 for the rear. I am currently on stock suspension possibly looking to get sport springs in the future.
My question is which tires size should I get? I believe I have 2 options.
225/40/19 and 255/35/19
or
235/40/19 and 265/35/19
Will the second option work on stock suspension? or will the tire rub on the control arm?
Old Apr 24, 2021 | 07:31 AM
toosteeley's Avatar
Present: 2019 C43 Estate
https://mbworld.org/forums/c450-c43-...ent-guide.html
Old Apr 24, 2021 | 06:19 PM
I spent over an hour on that forum looking forward an answer and couldn’t seem to find it. I saw that it would would on H&R springs but not on stock height.
Old Apr 24, 2021 | 08:58 PM
Hungalow's Avatar
C43 2017
or
I went one up 245 35 19 front and 275 30 19 rear, same widths.... no rub.
btw stock suspension
Old Apr 25, 2021 | 07:45 AM
alexasa's Avatar
c
the difference is minimal - but stock suspension at that offset can look pokey. If you have 5mm of clearance the larger tire size will be fine.
Old Apr 25, 2021 | 09:25 AM
toosteeley's Avatar
Originally Posted by Senid Avdic;[url=tel:8322363
8322363]I spent over an hour on that forum looking forward an answer and couldn’t seem to find it. I saw that it would would on H&R springs but not on stock height.
Why do you think those sizes would work if lowered but not at stock height? Honestly, all of your questions have been answered many times before.
235/40/19 front, 275/35/19 rear to keep the same rolling diameter. 265/35/19 would work for the rear too if you couldn’t find 276 in the tires you want. The fronts may visually poke a bit on stock suspension.
Old Apr 25, 2021 | 10:30 AM
From my understanding lowering the car gives you more clearance does it not? I think it’s about ~5mm of extra clearance which is huge for the front of our cars.
Old Apr 25, 2021 | 02:12 PM
toosteeley's Avatar
^ lowering the car does nothing for clearance of the inner suspension arm, only the fenders. Lowering helps the wheels tuck inside the fenders more, however, if you're not lowered, there's less concern of making contact with the fenders.
Old Apr 25, 2021 | 08:28 PM
Thank you for clarifying that. If I had known that, I would've never asked the question. I appreciate the help my guy!
Old Apr 26, 2021 | 09:50 AM
Star4life's Avatar
2017 C43 AMG
I am the creator of the wheel thread. either of those tire setups willl work. Just read my original post in that thread. it explains everything.
I am actually selling 235/40/19 and 265/35/19 michilin 4s if you are usa based and interested. save you some money.
Old Apr 26, 2021 | 11:49 AM
About to send you a PM. I am interested
