C450/C43 AMG
P0302 error, plugs replaced, Coil Pack replaced - still misfiring
Old Jan 26, 2023 | 08:30 PM
Bsc7080mdo's Avatar
2017 c43
Cylinder 2 is misfiring when I hit 3500-4000 rpms. Car goes into limp mode. If I turn car off, and start again, limp mode is gone unless of course I exceed 3500-4000 rpms. I replaced all spark plugs with new NGK iridiums and also replaced the Coil Pack on cylinder 2. I cleared all codes. Problem has not gone away. As soon as I hit the rpm range it throws code and goes into limp mode.
Car is drivable if I drive "sensible" and avoid getting into fun mode.
What other things can I check or replace easily? Or is it time to take it into my local Mercedes shop (not a dealer, still expensive and uses OEM parts but better prices on labor).
2017 C43 Sedan
Old Jan 27, 2023 | 01:53 PM
MatthewJ's Avatar
'15 C400 and '15 ML350
Might try swapping injectors around. They have been known to go bad or leak. (common part # used on a lot of MB motors)
Also are you sure you have cylinder #2 identified correctly? Passenger middle cylinder?
Old Jan 28, 2023 | 11:23 AM
Bsc7080mdo's Avatar
2017 c43
Yes. Passenger side middle. I will look around here and elsewhere for a guide on injectors. I haven't messed with those before. Thank you.
Old Oct 30, 2023 | 06:11 AM
WVM's Avatar
WVM
C43 AMG
Hello ! Exactly same problem here. I also changed the plugs. I delete the error and i might get 100-150 km without issues. Hard driving. And then after a while it just happen again
How did you fixed it please ??? 🙏🙏🙏
Old Oct 31, 2023 | 11:21 AM
WVM's Avatar
WVM
C43 AMG
2017 C43 Sedan
i have the same issue mate, please tell me how you fix this !!!
Old Nov 1, 2023 | 01:04 PM
C43Jay's Avatar
2019 C43 AMG
Misfire codes after replacing the coil and plugs?
Old Feb 15, 2024 | 04:08 PM
BigTurboC4's Avatar
C43. GS-T Spyder. 20th AE GTi.
Anyone get a fix to this? I had P2177 code, swapped in new spark plugs and now have P0302.
Old Feb 16, 2024 | 12:28 PM
BigTurboC4's Avatar
Well I pulled the plug on cylinder 2. The gap was just about .000. Re-gapped and went for a drive. felt much better but I didn't drive far enough to clear the code itself. Cleared the code when I got back. Time will tell if that was the fix. It certainly needed re-gapped either way.
