C450/C43 AMG
C43 PE flaps lubricating
Old Mar 19, 2025 | 08:22 PM
KristiyanPetrov's Avatar
C43 AMG '17 / Stage II
Hello, does anyone had ever lubricate his exhaust valves, long time ago somewhere i read someone did that with this spray if im not wrong lubricant
Old Mar 20, 2025 | 07:58 PM
W205C43PFL's Avatar
Hmmm, strange, I didn't see this thread pop up in the New Posts section so I missed it. I only saw this thread because you linked it from the oil dipstick pop out thread.
Old Mar 20, 2025 | 08:00 PM
W205C43PFL's Avatar
Oops I was going to attach the file to this thread but made a mistake and posted it in the other thread instead, oh well, here is the direct link to that post: https://mbworld.org/forums/c450-c43-...ml#post9130525
Old Mar 20, 2025 | 08:03 PM
W205C43PFL's Avatar
If the grease doesn't work or if the actuator completely fails, replace it, just get a Ford one if you want to save from the brand upcharge: https://mbworld.org/forums/c63-c63s-...ml#post8475917
Old Mar 26, 2025 | 12:46 AM
jaap74's Avatar
2017 C43 AMG (Tuned)
I Googled "lubrication of flaps" and it didn't point me back to this forum..............
Old Mar 26, 2025 | 09:13 AM
W205C43PFL's Avatar
I just tried it and it pointed me to something aviation related.
Old Mar 26, 2025 | 04:17 PM
correct way is lubrication of exhaust flaps maybe? hahaha
anyway i think i found a way but will report once i try it
check where is the yellow circle below in the image you should see 3 wholes there you should apply the thermo lubricate wax or whatever is the name in english, if someone manage to try before me please post here updates
P.S. i want to do this as preventive maintenance like changing your engine oil but on longer intervals
Old Mar 29, 2025 | 12:49 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Flap harness is a leaker...
harness  waterproofing with RTV
harness waterproofing with RTV (high temp silicone)
Kritiyan, while you're helping prevent this flap from failing... you need to silicone the harness penetration into connector.
These wire seals are not waterproof... rain effectively enter module by capilarity.
Old Mar 29, 2025 | 02:58 PM
Cali.. thanks for joining into this thread is really appreciated it, once i go under the car will check my flaps cables how isolated are they, if they're as in the pic above (i used it from another guy short video) will isolate it
on this topic a lot of flaps are reported to be failed in certain milages, friend of mine who have same year same car his flap is stop functioned as it should, not sure either if this is the issue or something else.. on top of that they're not cheap at all (300$ ish) per unit so x2...
will report here once i go under the car and will took some photos, so this thread might be useful for others as i don't find anywhere this to be discussed or anyone to pay attention until something is wrong with the flap
Old Mar 29, 2025 | 08:27 PM
CANCELLING PREDICTABLE SOAKINGS
yes, get down there and look at both sides of the connector plug for wet oxidation... (then clear scanner fault).
Then RTV every "sealed" connectors you see under your car near front/rear bumpers especially.
The MB. seals are no match for water capilarity.
Water gets into modules: game over! Can not clean oxidized soaked modules.
Preventive is the only way!!
Old Mar 30, 2025 | 03:13 PM
def will check that out but why i should clear fault with scanner, you mean when i clean it might trigger fault or?
Old Mar 30, 2025 | 07:00 PM
yes, when you simply unplug it 90% chance it will register a fault regardless of "power being off"... its really only "low power mode", not "power off".
Old Mar 30, 2025 | 07:06 PM
i know from dyno graph test with faulty flap that the car produce 140hp (or something like that) less, so it's not nice at all..
Old Apr 11, 2025 | 03:23 PM
W205C43PFL's Avatar
OP, I want to bring your attention to this thread: https://mbworld.org/forums/c450-c43-...ml#post9142893
Another reason why forum member CaliBenzDriver's advice to protect the harness is important.
Old Apr 13, 2025 | 12:03 PM
glad i read that because i was thinking for washing my car underneath because of the winter over i will skip this then
Old Apr 13, 2025 | 12:11 PM
W205C43PFL's Avatar
Just get it sealed and you are good to go : )
Old Apr 13, 2025 | 12:12 PM
thanks for bringing this thread here
Old Apr 13, 2025 | 12:21 PM
W205C43PFL's Avatar
You're welcome : )
Old Apr 13, 2025 | 03:20 PM
NO A PROBLEM BUT MANY
there is the TPM module (pass. rear axle) also
and rear bumper side radars and harness connectors plus front bumper and engine area.
and the ISM priceless shifter (tranny side) its bottom connector can really use RTV.
These cars are temporarily "sealed" to dis-like water... water capilarity always wins.
Use high temp RTV engine-grade automotive sealant to fix that !!
Old Apr 13, 2025 | 04:39 PM
W205C43PFL's Avatar
Time to wrap the entire vehicle's underbody Much easier than sealing each individual connector.
Old Apr 24, 2025 | 11:21 AM
pff just now i paid attention to this thread thank you.. they literally discussed what i was digging for..
p.s. should we clean with brake cleaner or something else or just applying the grease?
thanks
Old Apr 24, 2025 | 03:12 PM
W205C43PFL's Avatar
thanks
All good : ) We do get busy with life after all and to answer your question, something else.
Old Apr 24, 2025 | 03:14 PM
well i was multitasking and placed question in wrong thread... hahahaha sorry
Old Apr 24, 2025 | 06:48 PM
W205C43PFL's Avatar
All good and good to be productive with life
