C450/C43 AMG
NO BOOST!!??!
Old Apr 4, 2025 | 08:39 AM
JYOO's Avatar
W205 C43 AMG
NO BOOST!!??!
I was trying to get a MAP 3 run on my stock with JB4 car on DRAGY. But the last two times i hit it from the light, i am only getting boost in first gear and then almost zero boost till I stop the run at like 70mph. Anyone have any clue why this might be happening? Also I am running about e30 or a little less in the tank right now. Thanks for any help.
Old Apr 4, 2025 | 09:56 AM
W205C43PFL's Avatar
Check the check valve
Old Apr 4, 2025 | 09:58 AM
W205C43PFL's Avatar
https://mbworld.org/forums/w212-amg/...ve-repair.html
Old Apr 4, 2025 | 11:33 AM
JYOO's Avatar
W205 C43 AMG
I thought that might be it. Hopefully its a quick easy fix and its ONLY that. Thanks for your help!
Old Apr 4, 2025 | 11:37 AM
W205C43PFL's Avatar
You're welcome : )
Old Apr 8, 2025 | 01:17 PM
W205C43PFL's Avatar
Following up with you OP, was it the fix? Hopefully it was, enjoy the vehicle.
Old Apr 8, 2025 | 01:50 PM
JYOO's Avatar
W205 C43 AMG
I havent checked the valve yet. I havent pulled off that hose because I am not hearing the noises or anything strange at all. I also just went down to MAP 1 and it seems to be building up boost just fine. Im going to try another full throttle run again asap but its hard here in LA. Did you have to change that valve yet? It might be time, i just hit 56K miles.
Old Apr 8, 2025 | 02:34 PM
JYOO's Avatar
W205 C43 AMG
Amazon Amazon
Which one should i get?
Old Apr 8, 2025 | 02:35 PM
W205C43PFL's Avatar
There are no symptoms other than lack of boost, no check engine light or anything if that thing fails.
Old Apr 8, 2025 | 02:38 PM
W205C43PFL's Avatar
This one, you can always use the oem part just replace the rubber portion: https://klifex.com/membrana-remkompl...volvo-31430964
Old Apr 8, 2025 | 03:03 PM
W205C43PFL's Avatar
If you really want to buy the entire part, you could do so here: https://klifex.com/klapan-vakuumnogo...365-2762300265
Old Apr 8, 2025 | 04:10 PM
JYOO's Avatar
W205 C43 AMG
Thanks for the links! Im going to try to pull off that hose again asap and then order the part if needed.
Old Apr 8, 2025 | 04:16 PM
W205C43PFL's Avatar
You're welcome. It is a tight spot otherwise very simple DIY, just a screw to remove and you just pull it out.
Old Apr 17, 2025 | 10:34 AM
SchneWe's Avatar
MY19 C43
I would recommend testing it before replacing.
Take the hose off the valve and see if any oil blows out. If you see visible puffing, it’s likely oil and means the valve is not doing its job.
If you’ve already ordered the part, test it after install and a few strong pulls because a lot of Chinese valves function initially and come apart instantly soon after.
Old Apr 17, 2025 | 01:48 PM
W205C43PFL's Avatar
Thank you, that is a good way to test it.
Old Apr 17, 2025 | 01:58 PM
JYOO's Avatar
W205 C43 AMG
As soon as I get some time, I will pull that hose. Do you have any links to the right valve to buy? Thanks
Old Apr 17, 2025 | 02:55 PM
W205C43PFL's Avatar
Sounds good OP.
Old Apr 17, 2025 | 09:14 PM
SchneWe's Avatar
MY19 C43
Unfortunately, I don’t. I bought roughly half a dozen Chinese valves for cheap because some people mentioned that roughly one in ten work. I found they all came apart easily and just ended up doing some redneck engineering to make it work.
