C450/C43 AMG
Noise on start up
Old Jul 5, 2025 | 10:45 AM
Darrington's Avatar
2015 C400
Noise on start up
Starting a new thread for my ride. Posting 3 videos of start up:
0 - cold start,
1 - restart, but still cold,
2 - somewhat cold start, about an hour after restart,
Zero driving done between 0, 1 and 2. Based on fellow forum members input, does sound like a cam adjuster.
I have a JB4, scanned the codes. No codes. The car does seem to lag on building boost initially (sometimes). I replaced the vacuum pump diaphragm last year. Haven’t rechecked it.
For the cam adjusters, appears you can replace without removing the cams (assuming the cam plate hasn’t shifted). Looks like they make a tool to lock the adjuster gears, to be able to remove them. Adjusters (non-MB) and tool available on Amazon.
Thoughts? Thanks in advance for your input…
Old Jul 5, 2025 | 09:18 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
TEST STEPS
Your 3 videos sound rather nicely SMOOTH cold start.
#3 has just a few knocks at the beginning (Bk2 intake VVT Gear?)
> TEST if you are concerned...
  1. Inspect Positions of timing marks through CPS openings
  2. Inspect CPS connections for oil leaking into harness
  3. Test VVT Gear lock pins stay locked when spinning crank 2xTurns.
Old Jul 6, 2025 | 08:33 PM
Darrington's Avatar
2015 C400
Thanks, that’s a potential positive, and appreciate the diagnostic guidance. Saw the posts in the parallel thread, maybe I’ll do the oil pump mod, and an oil change too.
Old Jul 6, 2025 | 08:59 PM
EARLY DIAGNOSTICS COUNT
That can help going forward but what's done is done.
Truth being told: I think you have a very mild case so far - You're catching this early instead of ignoring it until camshaft-reluctors are shifted: max repairs.
You've got the right end of this bargain.
Old Aug 2, 2025 | 05:45 PM
Darrington's Avatar
2015 C400
Ok, I’m back. I decided to purchase the tensioners, cam sensor extensions and Motul 5W-40.
I’ll tell ya, I found it very hard to find clear procedures for these tasks. A lot of videos, but details are spotty!
So, for timing marks, at 53 degrees, I believe you’re supposed to see half the cam adjuster? That seemed to be the case for 3 of 4. Bank 1 (passenger side?) exhaust looked different than the others. Rotated the crank several times (by the way, getting the intercooler out of the way was a PITA, thanks @TwoC400s for your video!). None of the cam adjusters snapped/shifted, so I kept moving forward.
Rotated the crank to 40 degrees. I replaced the passenger side tensioner, seemed to go just fine.
On to the driver side, removed the tensioner bolts, it got jammed in the gears when it popped. Finally got it out. However, trying to put the new one in, the arm that the tensioner pushes against is way to the left, making it impossible to fit the tensioner. Thinking that was the reason it was hard to remove the old one.
Thoughts here? I believe the timing should be at 40 degrees for the drivers side too? I’m afraid to rotate it without the tensioner. Thanks!
Old Aug 3, 2025 | 08:20 PM
Darrington's Avatar
2015 C400
Just to follow up. I found a few articles that indicate you can rotate it with the tensioner out. So, rotated 360 degrees. It dropped right in! Rotated it a few more times, all the timing marks seem to line up. Covers back on, just need to remount the intercooler and add oil, and should be all set. Fingers crossed!
I also did the oil solenoid mod, so hopefully I’m good to go for a while.
Old Aug 3, 2025 | 08:24 PM
Darrington's Avatar
2015 C400
I did find this work instruction helpful: https://mbworld.org/forums/attachmen...2d1747211765dl
Old Aug 4, 2025 | 08:00 AM
MatthewJ's Avatar
'15 C400 and '15 ML350
Thanks for sharing updates. Just to confirm my understanding. You did not have any timing off and did the tensions update, upon restart was the noise gone?
Old Aug 4, 2025 | 10:57 PM
Darrington's Avatar
2015 C400
Hey Matt. I let the sealant cure overnight, so first start was tonight. Very loud rattle on start up, then cleared up. Restarted a few mins later, no noise. I plan to start in the am. I think that will be the true test. New Motul 5W-40 oil and MB filter. Also did the oil solenoid mod.
I did take pics of each of the cam positions while the crank was at 53 degrees…they all look good, maybe the passenger side exhaust is slightly off. Was hard to get a straight on pic.
Here’s the pics, starting from passenger side exhaust, intake, drivers intake, exhaust. I’ll post the videos too.
Old Aug 4, 2025 | 11:01 PM
Darrington's Avatar
2015 C400
Old Aug 15, 2025 | 08:12 AM
MatthewJ's Avatar
@Darrington Hows it doing now that you replaced those parts? Any more clatter on cold starts?
Old Aug 24, 2025 | 03:37 PM
Darrington's Avatar
2015 C400
Hey, sorry, missed your posted! Unfortunately, still getting some intermittent rattle on start up. Not every day, but still happening. I need to snap another video to share.
I keep checking the JB4 for codes, but no codes. Not sure if the JB4 can see all codes, or just some. I also posted some logs on their forum, they said everything looks good.
I wish it wasn’t such a pain to access the crank, so I could get the pulley at 53 degrees, check the timing marks and rotate to see if lock pins are working.
More to come soon, just haven’t had a chance to troubleshoot more…
Old Aug 24, 2025 | 06:02 PM
Ok let's try a short cut to save your time ....
Old Aug 24, 2025 | 06:04 PM
that is clear evidence a full serving of startup rattles...
Old Aug 24, 2025 | 06:05 PM
QUICK TROUBLESHOOTING SHORTCUT
I double checked this pics....
I see passenger/Bk1 EXH is messed up
I see driver side /Bk2 is all spot on time.
The shortcut is to look at positioning live while engine is at 650.Rpm idle and 1k. Rpm...
Let's try to spot a wobbly VVT gear position using your scanner on ECU data.
Typically BK2-INT is the leading bad VVT
the comes BK1-INT comes in 2nd worst
then EXH adjusters.
Worned out VVT lock pins are caused by low oil pressure around 1200.Rpm
Old Aug 24, 2025 | 10:26 PM
Darrington's Avatar
2015 C400
Thanks, appreciate the analysis and recommendation (as always). So an Autozone type scanner will get the job done, or should I grab one off Amazon?
Doesn’t seem like this is something the JB4 can do…however to be honest, I haven’t gone further than to simply have it try to ‘read codes’ in the JB4 app.
Old Aug 24, 2025 | 11:32 PM
ECU LIVE DATA
I don't know JB4 tool... if it can read ECU data then there's a chance it can read each camshaft correction factors to see which one ends up in the weeds while oil pressure is still marginal.
On AMZ... lookup "LAUNCH CREADER ELITE MB" fairly good deal, likely overnight delivery. Cheaper in CN mart.
Ignoring the VVT rattling is what shifts the reluctor plates off their spot to cause correlation faults -- Not what makes these engine hum
Old Aug 25, 2025 | 07:52 AM
MatthewJ's Avatar
JB4 can scan and read codes, it cant give sensor data, and most if not all of the autozone ones would be in the same boat.
You would need a MB specific scanner that can see other modules and read live sensor data.
I too have an occasional startup knock and rattle. Started about a month ago, im at 99k miles. Only does it when the oil is hot and can drain down, and i restart. Not normally in the mornings.
I just did an oil change last night since i was at 4600 miles, it was about due anyway. Hoping that will help.
@Darrington did you add the oil restrictors/check valve to the tensioners as well or does our year already have them?
Old Aug 25, 2025 | 03:34 PM
Oil specs can help or hurt the VVT phasers. Even in good condition engine can rattle.
I remember my second MB schedule oil change was late by a month and my low mileage VVT rattled with hot oil restart.
Hot thin oil bleeds right out of perfectly ok VVT + Tensioners. Preserving lock-pins from wear is a reason for more effective oiling.
Old Aug 25, 2025 | 06:47 PM
Darrington's Avatar
2015 C400
Good intel, thanks Matthew. Looks like I’ll take the plunge on a scanner off Amazon. I need to do some research, ratings don’t seem great on a few models.
I think our C400s have the restrictors? I think I checked the engine number. Here’s a pic as well.
Old Aug 25, 2025 | 07:37 PM
CHECK VALVES ON-BOARD
installed already
installed already
All good factory check-valves + recent tensioners
Old Aug 25, 2025 | 08:20 PM
DEFECTIVE VVT SIGN
oil rushing out
oil rushing out
Oil forced out of a defective VVT Phaser is a telltale sign of it having a bad lock pin.
-- the first time VVT is manually rotated clockwise oil gets forced out (pic.)
-- the second time you can hear a straight snap because no VVT oil is now empty.
The forward motion is applied by the camshaft force driven by valves.
Old Aug 25, 2025 | 08:51 PM
Darrington's Avatar
2015 C400
Interesting. So that’s driver side intake. Wish I took the same pic on the passenger side. Pass exhaust is the one where the timing mark is off in the peephole.
oil rushing out
oil rushing out
Old Aug 26, 2025 | 01:13 AM
Yes, a picture would have been helpful.
Now you can look at live timing data to assess the situation without intake disassembly. Saves real time.
If it rattles... data are going to evidence it with your scanner!
Old Aug 26, 2025 | 09:33 AM
Darrington's Avatar
2015 C400
Scanner ordered! 2025 LAUNCH Creader Elite V2.0 fit for Mercedes-Benz
