C63 AMG (W204) 2008 - 2015
what gas to use?
Old Jun 11, 2008 | 07:21 PM
iku's Avatar
iku
slk32(gone), 08 c63.
what gas to use?
hey guys, i'm taking delivery tomorrow, and i'm just wondering what type of gas you guys all use. i'm located in vancouver b.c. therefore i think there are different gas companies here. thanks for all the inputs
Old Jun 11, 2008 | 07:32 PM
Last Emperor's Avatar
'08 BMW 650ci
super and only super
Old Jun 11, 2008 | 08:00 PM
Flame3g's Avatar
CLK500 SPORT
yeah look inside your filler door and you will see "Only the best". I use Cheveron myself 91 octane
Old Jun 11, 2008 | 08:07 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
All 63 models are tuned for a minimum of 93 octane, so whenever possible, try to use 93 octane or slightly higher. Chevron and Shell are the top two brands, but you can always select any of the following companies:
http://www.toptiergas.com/retailers.html
93 octane is abudant almost in every state except California . Most gas stations around here offer up to 91 except for very few that offer 100 octane, so I end up mixing 4 gallons of 100 with 91 to get around 93 octane.
Old Jun 11, 2008 | 10:37 PM
BoBcanada's Avatar
AMG
Dunno I also checked it out, on the lid it says 93! But in Toronto we have 87,89,and 91... We also have 94 sunoco gas... but i'm not sure if its better or not... because if they boost it from 91 with addictive it can be bad for some engine parts or so i heard. Anyone can elaborate on that?
Old Jun 11, 2008 | 11:41 PM
iku's Avatar
iku
i'm pretty sure cheveron has 94, but not too sure about shell. i'll just stick to cheveron then..
here comes 1.60/liter gas..
Old Jun 12, 2008 | 12:04 AM
power-fade's Avatar
"One Man. One Engine."
I have been an owner of performance vehicles for over 20 years and it is ONLY Chevron Supreme 92 or Chevron Supreme Plus 94 (depending on the vehicle application).
Old Jun 12, 2008 | 12:23 AM
01SL500's Avatar
2001 SL500
I don't know what you guys are talking about but mine runs fine on bio wiesel.
Old Jun 12, 2008 | 04:35 AM
Untertürkheim's Avatar
The Sunoco 94 should be fine, there is no reason it should foul any engine parts since it is made specifically for cars that require more than 91.
Old Jun 13, 2008 | 05:31 PM
QQQ's Avatar
QQQ
MY2001 C320
Vancouver doesn't have the extensive hghways like Toronto so regular gas to detune the engine for city traffic.
Old Jun 13, 2008 | 07:59 PM
micropower99's Avatar
2008 Mercedes C300 4Matic
Vancouver doesn't have gas above 91 octane except for chevron which has 91 and 94. I use the chevron 94 for my C300.
P.s. Don't even think about using regular on a car that requires min 91.
I filled my tank with Chevron 94 last night for 1.50/lit. It'll only cost you 4 or 5 bucks more than 91 octane not even per tank full.
Old Jun 13, 2008 | 08:08 PM
russian_lawlz's Avatar
2008 Obsidian Black C63
I live in South Florida and only fill with 93
Old Jun 14, 2008 | 12:28 AM
iku's Avatar
iku
bad news...
2nd day, and i already had to add 56 dollars worth of gas (filled up at half way). chevron 94 at 158 today..
but good news is..
the engine sound will magically put a grin on your face afterwards
Old Jun 14, 2008 | 09:28 PM
MFC997's Avatar
'08 C63 AMG
bad news...
but good news is..
Cost of doin' business my friend. That exhaust note is worth it
Old Jun 15, 2008 | 03:44 AM
974AGK's Avatar
M5 Jahre Edition S, KTM 1290R Super Duke ,C63 AMG 2011[Gone],A45 AMG 2013, MV Agusta 750 [2000]
Here in the UK we have V power from Shell , its about $0.20 ppl dearer, but much more noticable than regular fuel.
AMGBeleza's Avatar
09 C63
I did research and came up with 91 Octane. I did not see 93 for the stock configuration anywhere. If you want my reference let me know.
Old Jun 17, 2008 | 03:40 AM
974AGK's Avatar
Shell V power here in the Uk is rated at 99 octane! Current cost is £1.22ppl/$2.41ppl conversion to gallon 4.55litres[UK]
Latest Shell Tanker strike today caused prices to go to £1.99ppl/$3.94ppl Pure Greed by forecourt owners!
Old Jun 17, 2008 | 11:18 AM
F_Porsche's Avatar
i like to ride my bike
u do know that v power is only a marketing scheme!? it has been tested and found not to be better than normal premium! but i guess someone has to buy it
Old Jun 17, 2008 | 11:31 AM
974AGK's Avatar
I was advised by MB dealer to use the Vpower that Shell Use, although reckon car will run the same on regular unleaded fuel . Will double check with MB UK!
Old Jun 17, 2008 | 12:03 PM
AMGBeleza's Avatar
09 C63
Premium Fuel is required. 91 Octane or higher, i.e. super.
Old Jun 17, 2008 | 12:12 PM
974AGK's Avatar
After normal leadedn brand in the UK,we have no option but V power with Shell anyway , so god knows what the was all about?
Old Jun 17, 2008 | 01:26 PM
JohnEnglish's Avatar
A black car
No it wouldn't. I assume it has a knock sensor and will retard the timing if you do try and run it on regular gas but under heavy acceleration you will get SEVERE knocking/pinging which will end up destroying your engine.
Old Jun 17, 2008 | 11:34 PM
GGM's Avatar
GGM
2008 E350
Octane ratings are calculated differently in UK and US. Check your owner's manual or the filler door for the correct octane rating for your car.
Old Jun 17, 2008 | 11:37 PM
GGM's Avatar
GGM
2008 E350
I have only seen 93 octane sold as premium in Florida. It startled me the first time I saw 91 octane being sold as premium in other states.
Old Jun 18, 2008 | 12:32 AM
shaker's Avatar
2009 C63
Don't forget to take into consideration altitude and climate and make necessary adjustments!! LOL
Excerpt from Porcshe Club of America (PCA)
"The rule of thumb for octane sensitivity in relation to altitude is as follows:
"The octane requirement (octane appetite) of an engine is reduced by one octane number for every 1000 feet increase in altitude.
"So, going from a sea level location to Denver [or in your case, Albuquerque] will reduce the engine octane requirement by approximately five numbers. This is for normally aspirated engines only. Turbo engines can be different depending on whether there is boost control.
"The octane versus elevation information is from Tim Wusz, Tosco/Union 76."
However, you also have a warm climate, which will cause the engine computer to back off the power. It will retard the ignition timing when the intake air temperature is very warm. This is for engine safety, and it also reduces power. Unfortunately this process begins at 25 C / 77 F, and the timing is reduced further depending on how hot the intake air becomes. This is because warmer air will increase the tendency to knock, and therefore, the octane requirement.
