C63 AMG (W204) 2008 - 2015
Pics of 2 piece rotors installed on my C63
Old Aug 7, 2008 | 08:24 PM
Korn55's Avatar
R231 SL
Installed my two piece rotors today. I saved 6 lbs. per corner. The factory one piece rotor weighs in at 36 lbs. and the new 2 piece weighes in at 30lbs. It's a pretty pricey upgrade, but taking off unsprung weight is always good.
Attached Thumbnails Pics of 2 piece rotors installed on my C63-2-piece-2.jpg   Pics of 2 piece rotors installed on my C63-2-piece-3.jpg   Pics of 2 piece rotors installed on my C63-2-piece-1.jpg
Old Aug 7, 2008 | 08:49 PM
Glock Guru's Avatar
Steel Gray 09' C63 AMG
So is that OEM? The rotors that should have come on the factory PP? Price?
BTW, SWEET>>>>
Old Aug 7, 2008 | 09:03 PM
Korn55's Avatar
R231 SL
BTW, SWEET>>>>
Yes, that is what should have come on the PP. They are factory MBZ rotors and cost about $900 a piece, ouch.
Old Aug 7, 2008 | 09:10 PM
Simon @ evosport's Avatar
PREMIER SPONSOR
Apparently 2-piece rotors are not available yet even on PP cars. The 2-piece rotor is the same one that comes on the CLK63 Black Series, SL55 030, etc.
Here are pics of our 2-piece REAR rotors we just released for the CLK63 Black Series. We will be offering a 2-piece REAR rotor for the C63 as well. We are currently evaluating offering a 2-piece FRONT rotor for the CLK63/C63 which would be much cheaper and most likely lighter than even the factory 2-piece.
Attached Thumbnails Pics of 2 piece rotors installed on my C63-dsc09385.jpg   Pics of 2 piece rotors installed on my C63-dsc09388.jpg   Pics of 2 piece rotors installed on my C63-dsc09396.jpg   Pics of 2 piece rotors installed on my C63-dsc09397.jpg
Old Aug 7, 2008 | 09:18 PM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
Did you install stainless steel brake lines too ?
Old Aug 7, 2008 | 09:37 PM
bigbodybeeenz's Avatar
bike
Do you actually feel any difference in the breaking, or is this simply for reduced weight?
Old Aug 7, 2008 | 10:29 PM
Korn55's Avatar
R231 SL
I haven't driven it hard enough yet with the new rotors to really tell.
Old Aug 7, 2008 | 11:21 PM
gsrjc's Avatar
2011 GLK350, 2010 ML350, 2008 C63 AMG
wow, those look nice. Are they bigger than the stock rotors?
Old Aug 7, 2008 | 11:27 PM
B.E.R.U.A.N.G's Avatar
CLK 500(Gone), C63 FTW!
It wont be, the calliper wont fit if they were diffrent size...I am not really sure though..
Old Aug 7, 2008 | 11:51 PM
Korn55's Avatar
R231 SL
They are the same size as the one piece rotor, 360mmx36mm i believe.
Old Aug 8, 2008 | 10:33 AM
rubensans's Avatar
Brabus K3
Rims look great. I also have this rotors on my car with excelent result.
Best Regards.
Old Aug 8, 2008 | 05:57 PM
scarbrtj's Avatar
AMG C63 S
so where is the best place to get and have installed factory MBZ two piece rotors...
Old Aug 8, 2008 | 07:08 PM
1qikctr's Avatar
Merc power
HRE 841's looks HAwt.
Old Aug 9, 2008 | 03:52 AM
Stuttgart-UT's Avatar
Mercedes
SICK!
Old Aug 9, 2008 | 12:53 PM
Hans Delbruck's Avatar
What I like!
Very nice. Will you be installing a diff on your car?
Old Aug 9, 2008 | 02:37 PM
Korn55's Avatar
R231 SL
It's a possibility. I'm going to wait until I do a few more mods and see what happens.
Old Aug 10, 2008 | 01:41 AM
jackrycheung's Avatar
2009 Fully loaded C63 AMG - black on black and CF trim; 2006 Lexus IS250 AWD;
It looks really like mine from APP pkg, do they have the same function or even better?
Old Aug 28, 2008 | 03:07 AM
yooker's Avatar
a durr
2 piece rotors are less prone to warping as the metal expands and then cools. the 2 piece design allows the rotor and the center mount to expand at different rates from the heat generated by the brakes. single piece rotors will warp into a cone shape over time if they are repeatedly used in heavy braking situations, causing uneven brake pad wear.
they also reduce the unsprung weight at each corner of the vehicle.
Old Aug 28, 2008 | 03:11 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
very nice! $$$ tho...
Old Aug 28, 2008 | 01:31 PM
Derek@DRI's Avatar
2001 Ford Lightning/2003 Mustang Cobra
Looks good, real good.
Old Aug 28, 2008 | 06:19 PM
peet's Avatar
09 C63
$1800 clams for looks? I don't get it (shakes head). Sure they look pretty sweet, but so do the stockers. Braking performance won't improve - it's the same size and type of friction surface. As someone above said, they're less likely to warp is all.
Ouch 1800.
