C63 AMG (W204) 2008 - 2015
oil change ?
Old Jan 3, 2009 | 11:20 AM
bazi 007's Avatar
c63 amg
oil change ?
hi everyone; just got my new 09 c63 amg; after the 1k break in period do u guys rec a oil change to get rid of any crud from the engine breaking in? also the manual states keep in the C mode during this time, is this correct? and lastly can u connect the i phone to the ipod connector; thanks in advance!
Old Jan 3, 2009 | 11:55 AM
taylorcoleman's Avatar
2009 C63 AMG
Now it's time to have fun--congrats.
I did an oil change at 2k miles for good measure (just yesterday).
Regarding the iphone...plug it in and see if it works
Old Jan 3, 2009 | 01:41 PM
norb's Avatar
2009 C63 AMG
You can connect the iphone to the ipod connector but it won't recognize it until you buy an adapter. I bought the Scosche PassPort...
http://www.scosche.com/products/productID/1667
Old Jan 3, 2009 | 11:57 PM
bazi 007's Avatar
c63 amg
i have the 1st gen iphone not the 2nd gen 3g one;will this work with this accessory?
Old Jan 3, 2009 | 11:58 PM
bazi 007's Avatar
c63 amg
thanks its a awesome car; i traded in my 2004 c4 cab and i have no regrets
Old Jan 4, 2009 | 01:07 AM
qship5's Avatar
M5, C63, 335Ci
I changed my oil at 1000 miles, but that's just me being ****. I've always done this with my cars and will continue till I die. Can't help you on the iPhone, but I've always subscribed to the clener oil is a good thing philosophy. (Doing my own oil changes helps keep the cost low.)
qship
Old Jan 5, 2009 | 11:47 AM
blownS's Avatar
'12 CTS-V
Question
How many quarts/liters does our car take? (I bought 7 just in case).
Old Jan 7, 2009 | 11:29 PM
qship5's Avatar
M5, C63, 335Ci
The C63 takes 8 quarts of oil.
Old Jan 7, 2009 | 11:31 PM
GBlansten's Avatar
2017 BMW X5M DG/AB
I'm getting my oil change when the computer recommends it around 10K miles. I did add around 1.6 quarts recently when it read low.
Old Jan 7, 2009 | 11:33 PM
Eurosport's Avatar
monowiper
qship
+1 if you plan to keep it do it as much as you like, i wouldn't let it go over 1k w/out an oil/filter change for sure
Old Jan 7, 2009 | 11:34 PM
Eurosport's Avatar
monowiper
you leasing?
Old Jan 9, 2009 | 10:14 AM
blownS's Avatar
'12 CTS-V
Thx. Does anyone know of a DIY oil change thread for our car? Is the filter pretty easy to remove & change?
In my M3, the filter is in a metal cylinder and u just unscrew the top, remove the filter and drop in the new one. VERY easy.
EDIT: Nevermind. Found the filter, and it's pretty much just like the M3. Gosh I love German engineering!
Old Jan 9, 2009 | 12:45 PM
2009 C63 AMG
Thanks for the pic and link. My iphone 3g plays just find with the integrated ipod link, however, it just does not charge. Is this adapter useful just to allow the iphone to charge when it's connected to the integrated ipod link?
Old Jan 9, 2009 | 06:10 PM
GBlansten's Avatar
2017 BMW X5M DG/AB
Originally Posted by Eurosport
you leasing?
Yes
Old Jan 9, 2009 | 07:53 PM
hhughes1's Avatar
2013 Chevy 427 Torch Red
For as many years as I can remember, BMW scheduled the first oil change (free) at 1500 miles in order to flush out any mechanical debris that could accumulate within the motor as it was broken in. A few years ago this service was no longer scheduled and you have to wonder why?
Old Jan 9, 2009 | 11:34 PM
bazi 007's Avatar
c63 amg
my service manager told me it does not need a oil change until 10 k miles; at 2k miles the 09 needs a rear diff fluid replaced per maint schedule; that schedule doesnt mention anything about a oil change before 10 k
Old Jan 10, 2009 | 08:42 PM
2009 C63 AMG
The rear diff fluid change is only for the performance package (w/ LSD).
Yes, it does not "need" an oil change, but for ~$100 for piece of mind (if you own) why not?
Old Jan 11, 2009 | 09:32 PM
hawtheric1's Avatar
2009 C63 AMG
If the car doesn't need it, how are you buying peace of mind? I'm just saying.
Old Jan 11, 2009 | 10:17 PM
2009 C63 AMG
My "need" in quotes was a bit cryptic. What I mean is that one is likely not in immanent danger of engine failure if the oil is not changed until 10K miles. I also came from an '08 E90 M3 where the oil was changed after 1,200 miles per BMWUSA's regular service guide.
Although I have no reference to back the following statistics, the following reasoning helped me spend the ~$120 for the oil change at 2K miles:
* Cost of new engine and replacement ~ $30,000
* Chance of engine either losing power or poor reliability that would cause engine replacement if waiting to change oil until 10K miles ~ .004
* Therefore, worth <$120 to change oil at 2K miles
If one thinks the odds are less than 4 cars per 1000, than save your $, time, & worry and have it done at 10k miles.
Old Jan 11, 2009 | 10:56 PM
bazi 007's Avatar
c63 amg
why would the engine fail? i would think mb would want to make money off a oil change earlier than 10 k; my porsche did not require such a early oil change either;to be honest the cost of a oil change is not a issue as much as taking time out to do it; i just dont want the mechanics to fool around with my car unless they have to; if the engine failed then mb would have to replace it under warranty anyways; i do thank you for the comments in advance
Old Jan 11, 2009 | 10:59 PM
GBlansten's Avatar
2017 BMW X5M DG/AB
Here is what I wonder. I don't discount that MB is trying to save money but maybe they've learned that going with synthetics plus the higher machining quality of engines has made the early oil change pointless.
I too did the 2K change with my 06 SLK 350 and wondered about the C63. Who knows. It would be cool to get some inside info on this.
Old Jan 12, 2009 | 10:37 AM
hawtheric1's Avatar
2009 C63 AMG
I also heard, not sure if it's true, that the engine oil they put in at the factory is a special blend designed for break in. It's not the same oil that we are adding when we are a quart low or after the 10k mark and you get the oil change.
Old Jan 12, 2009 | 11:10 AM
201mph's Avatar
C63, GL450, Panamera S, lots of little British leakers
I also heard that the engine oil they put in at the factory is a special blend designed for break in. It's not the same oil that we are adding when we are a quart low or after the 10k mark and you get the oil change.
That was true when manufacturers said to change your oil after the first 1000 miles. My Mobil contact says that MB's get straight Mobil 1 at the factory, just like you buy off the shelf.
I still like to change the oil after the first 1000-1500 miles. Costs little, extends engine life, and if it keeps some small bits from causing a later problem that leaves me sitting by the side of the road, then definitely worth it.
I use Valvoline synthetics or Mobil 1 in all our modern road and race cars, and Joe Gibbs Performance Oil (for its high ZDDP content) in our vintage cars.
Old Jan 12, 2009 | 11:46 AM
hawtheric1's Avatar
2009 C63 AMG
Cool. Thank you for clarifying. I'm having trouble finding the 5W-40 from Mobil 1. I found it but the only one I can find is designed for diesel egnines. That can't be the one we use for the C63 is it? I'm going to visit the dealer today to confirm but thought I'd post here first. I found the 0W-40 but my dealer said they are using 5W this time of year in AZ. I checked AutoZone and Checker. THey both have the diesel version.
Old Jan 12, 2009 | 08:13 PM
EROD's Avatar
2009 Iridium Silver C63
For those of you who do your own oil changes, where do you buy the filter at? My nearest MB dealer is a 80 mile round trip away so I think I'll be doing oil changes myself to spare the trip and save a few pennies along the way. Also, some what related question: What's better, vacuum or drain?
