C63 AMG (W204) 2008 - 2015
No more LADA style door pins
Old May 28, 2009 | 05:35 PM
id64's Avatar
AMG C63, Merc C230, Audi A3
Wink No more LADA style door pins
Front just screwed in. Rear - drilled out, shortened and epoxied. Piece a cake
Front open:
Rear open:
Front closed:
Rear closed:
Old May 28, 2009 | 08:38 PM
GHAZAN's Avatar
MBUSA
How did you drill out the rears exactly?
Old May 29, 2009 | 05:43 AM
-michael-'s Avatar
2009 MB C63 2007 MB ML63 2006 MB CLS 500 (wife)
LADA hahaha I remember those. They looked like screws (with screw hat and a cross screwdriver fitment)
FYI LADA is a Russian made car, the doors can be easily open with a fork
Old May 29, 2009 | 08:51 AM
id64's Avatar
Take the pin. Get a piece of semi-hard rubber. Wrap around the pin. Place it in the vise. Get a drill bit one size bigger that thread inside. Drill out threads. Get even bigger drill bit. Repeat. Now it should fit the plastic peg that's sticking out. But it sticks out too far. Get a hack saw and cut off about 1 cm of the bottom (it depends how long the pins are and I guess it's vary, so it's better measure it yourself.) After all is measured get a 5 min epoxy. Mix it. Fill the pins with it. Wait a bit until it no longer flows, epoxy that is. Insert pins. DO NOT SMEAR EPOXY ON YOUR HANDS, DOORS, GLASS, ETC. Wait for 2 hours. DONE. IF you do drop epoxy on something IMMEDIATELY use a microfiber soaked with Isopropyl 70% to clean it up. If you are afraid to use Epoxy I guess silicone glue will work as well, just need more time to dry out.
Old May 29, 2009 | 10:10 PM
PatSC23's Avatar
2009 C63
which ones were these? ebay?
Old May 29, 2009 | 11:15 PM
id64's Avatar
Yes,
http://cgi.ebay.com/ebaymotors/MERCE...ht_1584wt_1223
But some of them are too thick for some reason.
https://mbworld.org/forums/c63-amg-w...ml#post3548091
Old May 30, 2009 | 01:41 PM
willc55's Avatar
2009 Mini Cooper Clubman S
This might be a stupid question, but is there any scenario where you could be trapped in your car with these pins? I'm assuming that when you pull the inside door handle when the car is locked, the door is unlocked mechanically. However, if the door is unlocked electronically I wouldn't like to have pins in my doors that I can't physically unlock if need be.
Old May 30, 2009 | 02:17 PM
soldier2304's Avatar
C63 AMG(sold), 2009 CL550, 2010 S550 Majestic Black, 2010 ML550, 2006 C230, 2009 Venza
I bet noone ever thought about that before. My guess wud be in that right moment your basically ****ed.
Old May 30, 2009 | 03:18 PM
id64's Avatar
I thought about it. But then I've looked at my Audi A3 doors and there NO DOOR PINS at all!
Old May 30, 2009 | 05:50 PM
Azn_C300's Avatar
Mercedes C300 Sport, BMW 745Li, VW Mk6 Golf TDI
For emergencies.
Old May 31, 2009 | 06:37 PM
PatSC23's Avatar
2009 C63
i cant recall if the pins pop open wen you pull the door handle - it does on bmw's since you cant physically pull them up
