C63 AMG (W204) 2008 - 2015
*** C63 FD540 Power Package ***
Old Aug 10, 2009 | 12:40 AM
Vadim @ FD's Avatar
S600TT, R350
Ladies and Gentlemen:
We are proud to introduce FD540 Power Package for C63.
FD540 features:
1. Powerchip software - tune increases throttle opening to 87% vs. stock 50%, raises TQ limiters, retunes timing and fuel and removes top speed limiter
2. HiFlow Air Filters
3. Underdrive Accessory Pulleys - made from T6061 billet aluminum for half the weight of stock alternator and water pump pulleys. Black anodized for stock appearance.
4. Heat Spacers - insulate intake manifold from heat soak.
5. Intake Temperature Sensor relocation kit - relocates IAT sensor from behind the intake manifold to the front air inlet.
6. Shorty Headers - direct bolt on to factory H-pipe. 1.75'' primaries with 2'' vs. 1.675'' collector flanges.
7. Carbon Fiber Air Boxes - 20% higher volume with killer look.
FD540 adds 79HP and 40-64TQ to the wheels.
Individualy these parts come to $7294, as a part of FD540 Power Package we offer $595 discount for a special price of $6699.
Installation is availble for additional $900.
Original package was installed on MBworld member's 'overbudget' C63 and has been installed and tested on several local C63s as well.
Order can be placed via e-mail - vadim@fedordezyn.com or call 949.584.4446.
Thank you for listening.
Old Aug 11, 2009 | 12:44 AM
Sincity's Avatar
Subscribed. Website still not up? What is the price of the shortys? So the stock exhaust manifold flange is 1.675" mating to a 2" downpipe (H- pipe)?
Old Aug 11, 2009 | 09:20 AM
propain's Avatar
See Sig
I thought the throttle was at 70% stock. Not 50%.
How much HP gain overall?
Old Aug 11, 2009 | 01:18 PM
Vadim @ FD's Avatar
S600TT, R350
Shorties are $2499.
Downpipe is 1.875'' inside. I also have bigger inlets inside with new flanges that can be welded onto stock H-pipe.
Old Aug 11, 2009 | 01:21 PM
Vadim @ FD's Avatar
S600TT, R350
At WOT TBs open 60% than close down to 50% after a second.
Overall gain close to 90HP.
Old Aug 11, 2009 | 01:47 PM
Sincity's Avatar
Originally Posted by Vadim @ FD
Shorties are $2499.
So the new flanges replace the OEM flanges and they taper down? I know the shorties do not put the power of the LTs and I like the idea you can swap back and forth with the OEM log. What is the power gain of the shorties by themselves with or without the tune?
I do not understand why the throttle cannot open 100%? Is it because of the stock exhaust restricting the additional airflow?
Old Aug 11, 2009 | 04:52 PM
Vadim @ FD's Avatar
S600TT, R350
Here are the pixs of 2.5'' cat inlets. BTW, they fit all MBs/AMGs and and shorty from other tuners as well.
Long tubes are about 15-20HP more than shorties. But with major install and higher sound level.
I have seen from 15RWHP to 24RWHP. Depending on other mods. With 2.5'' cat inlet IMHO it will be an additional 7-10RWHP.
87% is max on the factory map. It is pretty much wide open. Remember there are two 74 mm TBs.
C63 is limited to 50% to lower the power down to 451HP.
Old Aug 11, 2009 | 05:07 PM
Sincity's Avatar
Tks Vadim!
Old Aug 14, 2009 | 03:08 PM
Vadim @ FD's Avatar
S600TT, R350
Parts are also available individually.
Old Aug 15, 2009 | 01:18 PM
Hans Delbruck's Avatar
What I like!
Nice work Vadim & thanks for all the info
Old Aug 15, 2009 | 01:57 PM
OverBudget's Avatar
2009 C63 AMG
That's my car!
Yes, I have this, plus I also had the secondary CAT's removed, the resonator removed, and an x-pipe installed. It's sick.
Vadim will take care of you if you go with this.
James
Old Aug 18, 2009 | 10:27 AM
B512M's Avatar
C63
Vadim, does the headers and downpipe fit a RHD C63 ? Thanks
Old Aug 19, 2009 | 04:50 PM
Vadim @ FD's Avatar
S600TT, R350
Headers should fit RH as well.
Old Nov 1, 2009 | 08:49 PM
Sincity's Avatar
I hope Vadim pulls out of this mess and start producing products again.
Old Nov 1, 2009 | 10:18 PM
OverBudget's Avatar
2009 C63 AMG
what mess?
Old Nov 1, 2009 | 10:42 PM
Sincity's Avatar
Member "bodyguard" has posts in several forums about his issues with Vadim and others chiming in about undelivered product.
Old Nov 2, 2009 | 03:58 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
Old Nov 2, 2009 | 04:39 PM
bushburninc63's Avatar
2009 c63, 2010 E63
Old Nov 2, 2009 | 06:55 PM
bigbodybeeenz's Avatar
bike
Originally Posted by OverBudget
what mess?
Here:
https://mbworld.org/forums/c32-amg-c...und-vadim.html
And here:
https://mbworld.org/forums/performan...must-read.html
Old Nov 3, 2009 | 09:01 PM
mkonei's Avatar
05 C55
those welds look like elmers paste
