C63 AMG (W204) 2008 - 2015
Suspension Help.
Old Sep 16, 2009 | 08:32 PM
Z99's Avatar
Z99
c63 amg
Suspension Help.
Had dealer install PP struts and coils. Picked up car today and the back looked really high. I thought the PP set up sits a few millimeters lower. I had measured between wheel center and outer edge of wheel well before I dropped the car off for the work. They measured around 14.25 inches in the back. Measured them again after installation and the distance was 15 inches. 3/4 of an inch more. Looks like Starsky and Hutch mobile. Went back to dealer. Wanted to make sure I had not made a mistake originally. So I looked for another C63 on the lot. Could not find one.I measured a c300 though. It too was right around 14.25. AMG suspension can not be higher then a regular C300. I know the coils will settle a little bit. But 3/4 of inch+ seems like too much of a variance. Did they put the wrong coils in the car?? Any other thoughts?
Thanks in advance.
Old Sep 16, 2009 | 09:52 PM
Z99's Avatar
Z99
c63 amg
Looked at work order and the part numbers for struts and coils match. But, I see no buffers replaced. Could that be the problem?
Old Sep 16, 2009 | 10:09 PM
Sincity's Avatar
Perhaps you need to let the springs settle.
Old Sep 16, 2009 | 10:30 PM
lomita's Avatar
C63AMG
Ah, the perfect solution potential now exists. From a trusted source, you can run 245/40 front and 265/35 rear.....assuming you are on the 18 inch rims.
Old Sep 17, 2009 | 07:48 AM
1st amg's Avatar
SLS Irridium silver,2014 GL350 BT Irridium, 2015 White Dodge RAM Hemi Quad
I believe the suspensionhas to settle as SIN stated, it takes a few days of driving.
Old Sep 17, 2009 | 10:57 AM
chino1031's Avatar
2009 Mercedes Benz C63 AMG Arctic White PP
Thanks in advance.
I had that same problem. I fought and fought because they said thats how it is and i proved them wrong and took the car back. Theres a piece that they most likely didnt replace which they have to in order for it to sit properly. That piece needs to be replace with one thats a couple of mm shorter. it goes underneath the rear springs
Old Sep 17, 2009 | 11:19 AM
g.smiley's Avatar
09 c63 blk/blk H&R Springs & 08 e 63 blk/blk
PP sits no lower than non PP. When I had mine, they always looked too high. Now I have the H&R springs. Much better. Lower, and better road feeling.
Old Sep 17, 2009 | 03:20 PM
djcevo's Avatar
C63
Is the ride less choppy and smoother with H&R springs now - basically for the road in the UK the PP suspension is too hard and I want something a little smoother, would H&R springs help do you think??
Old Sep 17, 2009 | 05:02 PM
benyl's Avatar
'10 F150 FX4 SCrew. '14 S212S
Did you replace the struts as well?
Old Sep 17, 2009 | 05:10 PM
g.smiley's Avatar
H&Rs in this case will make the ride more refined. A little bit less jarring but still very stiff. It wont become a smooth car by any means, but if you cant stand the stock springs like me, get them and you may prefer them. I did. Plus, visually they set the car off!!
Old Sep 17, 2009 | 05:11 PM
g.smiley's Avatar
Just the springs.
Old Sep 17, 2009 | 08:35 PM
Z99's Avatar
Z99
c63 amg
Thanks. I will talk to them tomorrow.
Old Sep 17, 2009 | 08:37 PM
Z99's Avatar
Z99
c63 amg
Yes, struts and coils. It is sitting over 3/4 of an inch higher then original set up (non pp). Doubt settling will adjust that much.
Old Sep 18, 2009 | 09:59 PM
Z99's Avatar
Z99
c63 amg
Problem seems to be solved. Change to PP set up requires different chimes in the back. I believe chino1031 was referring to same part. Now 1/2 inch lower. With some settling should be fine. There are two camps on this set up. Those that think it is too hard and those that like it. I am in the like it group. Car feels tighter and ride is fine. It feels just right to me. But, this is just street driving. Will it be faster around the track? Will find out on Friday. Harder suspension usually requires stickier tires to get full benefit. Last time I tracked the carI was using Dunlop Direzzas. Very sticky. I have switched to Hankooks as I am going through tires like underwear. Getting expensive. Hankooks came in 2nd in a Car and driver test and even beat PS2. Hopefully they will work with the suspension set up. $175 for 265 30 19s. I have to change the two left ones after each event. The Pirrelis and Dunlops were too expensive for having to change once a month. Will post and let everyone know if I just wasted money or I actually got faster.
Old Sep 19, 2009 | 02:13 PM
1st amg's Avatar
do you have the part numbers for everything you changed? Thanks
Old Sep 19, 2009 | 09:46 PM
Z99's Avatar
Z99
c63 amg
Yes I do somewhere. There is another thread here that has them. Let me know if a search does not pull them up. I will dig them up. They assumed it was just struts and coils. When I realized suspension was to high, parts department did another search and came up with two chime part numbers. They ordered the other and installed it. $77 for the part. I also talked to Mercedes and they also concluded either bad alignment or wrong chime. The changed the chime and did alignment again. The service manager said that the PP set up has different alignment specs. Not sure correct or not. Still 1/4 inch higher then non PP set up in the back. Hoping it will settle more.
