C63 AMG (W204) 2008 - 2015
The best reason to go 20" (tire life)
Old Nov 18, 2009 | 08:06 PM
OverBudget's Avatar
2009 C63 AMG
My first set of stock tires (in the rear) were gone at about 6,000 miles (no burnouts). I then bought a cheap set of Sumitomo rear's which lasted until the car was at 12,500. I then went to 20's and I am approaching 20,000 miles on the car. I'd say the rear tires aren't even to 50% yet.
So upgrading to 20" wheels and tires, more than doubles the life of your tires. I am told by a shop that the 20" tires live longer because they are wider than stock, sit "flatter" than stock, and are generally "harder" because they are 25 series in the back as opposed to 40 series which flex more.
Old Nov 18, 2009 | 08:36 PM
emericr's Avatar
2021 Porsche TTS
First time I hear you can fit 20s on a C63. Got any pics and specs of tires and wheels?
Old Nov 18, 2009 | 08:42 PM
Boost Gomez's Avatar
C63 AMG
You can easily fit 20 inch wheels on a C63 if the tires have the proper ratios. For example, 245/30/20 front 285/25/20 rear would be perfect.
Old Nov 18, 2009 | 08:44 PM
Ludatwix70's Avatar
Volvo C30 R-design, CL63 AMG
mhm ^ is right
https://mbworld.org/forums/c63-amg-w...rts-4sale.html
this is another users old c63 wit 20in
https://mbworld.org/forums/c63-amg-w...month-old.html
and his new c63 wit different 20in
Old Nov 18, 2009 | 09:03 PM
UGOTMOPPED's Avatar
11' R8 - 11' RR Sport
Those are both my cars! The white one ended up being a lemon. I had Pirelli's on there with 285x25...the silver HRE's are Invo's with the new 275x25...just wanted to try it out.
Originally Posted by Ludatwix70
mhm ^ is right
Old Nov 18, 2009 | 11:14 PM
OverBudget's Avatar
2009 C63 AMG
Those tire sizes listed above are EXACTLY what I am running. Goodyear Eagle's.
Old Nov 18, 2009 | 11:31 PM
Even Money's Avatar
'15 VW GTI
How do you get the 285 to fit without rubbing? I thought 19s might be pushing it a bit...wow..
Old Nov 18, 2009 | 11:44 PM
transferred's Avatar
08 S65, 06 M3 CS(stick), 02 BMW X5 4.6iS, 07 R1 Raven, 08 F-450 4x4, 08 CooperS JCW
Tire diameter doesn't change as you have less sidewall unless your order the wrong ones. 285 is the width not the height.
FWIW, 20s have too little rubber-- rough ride, lack of control. 19s as big as I'd go on a small sedan...
-Rob
Old Nov 19, 2009 | 02:29 AM
sjhugh's Avatar
C63 AMG, BMW 135i
Here's mine with HRE Comp93.
20x10 and 20x8.5
285/25/20 and 245/30/20
The ride is ok, I’ve had a lot worse.
Old Nov 19, 2009 | 04:51 AM
DTMCLK's Avatar
GF
good old Palm Beach..
Old Nov 19, 2009 | 05:40 AM
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
20" last longer because the availble performance is lower. You have to be more carefull as well.
The 18s will take you around a road track faster than the 20s. The 20s do not have any compliance.
Old Nov 20, 2009 | 12:46 AM
Sincity's Avatar
Says he is in Sydney.
Overbudget: We haven't seen your car since the VRP kit installation.
