Just getting rears replaced?
I was talking to a mechanic I know relatively well who has worked with Mercedes for as long as I can remember, and told him how I wanted to change the fronts to 245 when the time came, and the rears to 265. He told me that the he would not recommend upping the width on the fronts, just changing the back widths. Basically he told me that thee speedometer/odometer would be off by about 5mph. The rear end would be a couple millimeters higher than the front end, but not noticeable. I just wanted to know what you guys think, and also if you had recommendation for a cheap but decent tire I can temporarily replace my rears with right now, and if I should get a higher width just for the rears as well. Thanks.
I'm sure there will be some haters but bang for the buck I'm pleased.
Tread:540 Traction:A Temp:A
Front:95Y
Rear:94Y
Let the beating begain!
I spoke with Discount Tire today and they said they couldn't align the tires, only mount/install them. They said I would have to get them aligned at the dealership, which wants to charge me an addition $150 to align then...any suggestions?
b) NEVER go to a dealer for alignment, EVER. The best alignments I have ever had done cost about $80 for all four corners (L.A. area). Ask around...
i haven't heard of the problems with going wider on the fronts.
i use 245/40zr18 and 275/35zr18xl N3000
No issues with the fronts. I have noticed a very very little rub going up my driveway. I pulled the wheel and it's touching on the inside of the wheel well about a inch long. It's not hitting the outer fender. No issues under full power or in a corner. My driveway is just a little steep at the bottom where it meets the street. I can live with it. Houston streets are really bad in town and I have had zero issues under normal driving. It only seems to happen in my driveway.
