C63 AMG (W204) 2008 - 2015
Vredestein Ultrac Sessanta
Old Jan 29, 2010 | 01:39 AM
qship5's Avatar
M5, C63, 335Ci
Has anyone run Vredestein Ultrac Sessantas on their C63 in 245/35/19 and 275/30/19 sizes? I ordered some 19"x8.5" and 19"x10" wheels and am thinking about these tires, but have read on some forums that the tires run wide and want to avoid rubbing.
TIA,
Mike
Old Jan 29, 2010 | 10:03 AM
Jay9722's Avatar
Big and Heavy 03 CL
TIA,
Mike
I don't know if this will help you or not but I am running on 285/30/20 on my CL and I have found that the footprint of the Vreds is actually a little bit smaller than other tires in that same size. The sidewall actually angles in a little bit to afford a larger tire in the wheel well. My Vreds rub LESS than the Pirelli tires I had on before. The tires are amazing.
Old Jan 29, 2010 | 12:54 PM
qship5's Avatar
M5, C63, 335Ci
Thanks for the info. Sounds like I'll be OK going with the listed sizes.
Old Feb 4, 2010 | 01:03 AM
Vegas_AMG_C63's Avatar
AMG C63
Haven't tried them with these sizes on the C63 but have used them before and they tend to run a size smaller. Please update the forum when you get them mounted. I have a set of wheels coming in the same size and were considering them!
Old Feb 4, 2010 | 01:29 AM
superlubricity's Avatar
Super Moderator Alumni
2011 GLK 350, 2013 GT-R, & 2013 RAM 1500
qship5 / Vegas_AMG_C63, are you guys both getting Forgestar F14s?
What color wheel/cars?
I'm eager to see the pics.
Old Feb 4, 2010 | 01:31 AM
BerBer63's Avatar
2009 C63
Got 275s in the trunk for installation Friday, not lowered though.
Old Feb 4, 2010 | 09:20 AM
qship5's Avatar
M5, C63, 335Ci
I am getting the F14s (Gunmetal on a black C63)
Old Feb 4, 2010 | 10:19 AM
chief63's Avatar
2021 Taycan Turbo, 2018 Radical SR3, 2021 Lincoln Aviator
I have mine here, getting them installed this April (matte black on Obsidian black c63). Pics coming soon =)
Old Feb 4, 2010 | 11:53 AM
Even Money's Avatar
'15 VW GTI
Pls post asap. That's what im thinking of getting. Btwn matte black and gunmetal.
Old Feb 4, 2010 | 02:04 PM
chief63's Avatar
The wheels look awesome in person (19"). I am also installing a KW V3 suspension at the same time. Tires will be Bridgestone Potenza RE11. Pics coming the day I get all this installed!
Old Feb 4, 2010 | 04:07 PM
NORTH 44 C63's Avatar
EuroCharged 2012 C63 BS Coupè
Did you find any RE 11's in 245.35 19F and 275.30 19R?? Sold out in Toronto until mid March. Have mine on order...
Old Feb 4, 2010 | 09:16 PM
qship5's Avatar
M5, C63, 335Ci
That will be a bad a** setup! The V3s are the bomb on this car and with wider wheels and sticky tires should make for a wonderful drive!!! I'm going to give the Vreds a shot and see how they do. As fast as I go through tires, if they don't perform I won't need to live with them for long!! If they do perform, then I've found a good tire at a great price point!
Old Feb 4, 2010 | 09:36 PM
Phin's Avatar
06' BMW M3
TIA,
Mike
..OP,I put a set of these(F225/R255/19's) on my M3 less then a month ago. I realize my ///M is approx.500lbs lighter then your 63,but I like the way they feel so far(street).I haven't had her on the track yet,but hope to this month,so I can't speak on that.Btw the week I had them installed SoCal was hit with all those rain storms and I was pleasantly surprised by how well they "stuck" in all that wet weather.
Old Feb 4, 2010 | 10:09 PM
Awesome.
Can one of you weigh the wheels and list the offsets you went with?
Thanks!
Old Feb 4, 2010 | 11:04 PM
qship5's Avatar
M5, C63, 335Ci
Awesome.
Thanks!
I'll weigh them before mounting on the car. Offsets are as follows (Front 19x8.5 ET 32 Rear 19x10 ET50)
Old Feb 4, 2010 | 11:09 PM
Cool. Thank you!
Are you sure on the front offset? That seems WAY too aggressive. The outside edge of the wheel will stick out an extra 19mm vs. stock (8" ET45)
Old Feb 5, 2010 | 01:15 AM
AMG C63
Black w/ GunMetal F14's also. Still debating on the tires. I've used Vredesteins in the past. Fantastic in the rain... so much so that if you live in a rainy area, it's probably your best bet. However being that Vegas doesn't get much rain... I'm really trying to find something that sticks and lasts for dry performance. I'm also out at the track a fair bit, so something that doesn't burn up in a day would be great!
Old Feb 5, 2010 | 10:38 AM
chief63's Avatar
Hi,
Mine are not ordered yet and I am getting my car mid march so I guess I'll put them on preorder with my guy ASAP if they are hard to find.
Also my wheels are at work so I'll try to weigh them for you. They feel very light, especially the front ones.
Old Feb 5, 2010 | 10:42 AM
chief63's Avatar
BTW my offset is 26 in the front (19X8.5) and 20 in the back (19X10) as written on the forgestar boxes.
Why is my offset so different than yours?
This is the offset Forgestar suggested considering my car and suspension.
Old Feb 5, 2010 | 11:23 AM
If those offsets on the box are what is inside, they won't work on a C63.
Stock Offsets: Front 8" ET45, Rear 9" ET54
Handy tool here -> http://1010tires.com/WheelOffsetCalculator.asp
Old Feb 5, 2010 | 11:28 AM
chief63's Avatar
If those offsets are correct, they won't work on a C63.
I just measured the offset on the front wheel and here is my math:
Total front wheel width ( 9.5" or 241mm - actually 8.5" in wheel width standards)
If I measure the distance from the front of the wheel (excluding the 0.5" side), the base of the hub is 63.5 mm from the outside. Taking into account the center point of the wheel (0mm offset) would be a distance of 108mm from each side, the current offset is actually 44.5mm (probably 45mm since my measuring tape is not that accurate), which is the stock offset (and correct).
So the ET 26 they show on the box is not accurate at all. I'll see with them what's that number.
Old Feb 5, 2010 | 03:18 PM
chief63's Avatar
Here is the reply from Forgestar that will clear things up about the offset written on the box for the front wheels:
"Do not pay any attention to the offset on the box that is for us when
they send the wheels and it starts at a +26 offset. We cut off material so
it comes out to a +45 offset."
Also I have nothing but good things to say about their customer service so far. Can't wait to install them!
Old Feb 5, 2010 | 04:33 PM
Even Money's Avatar
'15 VW GTI
How long was the wait?
Old Feb 5, 2010 | 05:07 PM
chief63's Avatar
I ordered them on the 26th of November and got them delivered here in Canada on the 20th of January. I'd say about 8 weeks total for the entire process. If you want some for spring order ASAP!
Old Feb 5, 2010 | 09:56 PM
Good to hear.
Note, offset and width ultimately determine how the wheel fits. An 8" ET45 wheel will fit differently than 8.5" ET45 wheel.
The 8.5" ET45 wheel will be 6mm more aggressive (I.e. it will stick out further) than the 8" ET45. That's going to look great in the front wheel well!
Can't wait to see pics. If you can, throw them on a scale. I'd love to know the actual weights of the wheels.
