C63 AMG (W204) 2008 - 2015
Bridgestone Potenza RE760
Old Jan 29, 2010 | 04:04 PM
vitamink's Avatar
2009 C63
Both of my rear tires are done at 6500 miles.. I decide to go with Bridgestone Potenza RE760 with information I searched here. I know sflgator have these tires.. My question is 255 vs 265? Any particular reason for 265 since a lot of members recommend that size? Thanks!
Old Jan 29, 2010 | 04:31 PM
Boost Gomez's Avatar
C63 AMG
The stock 255 is simply too narrow for the amount of HP and TQ our cars have. 265 or 275 would be good.
Old Jan 29, 2010 | 04:53 PM
c63canada's Avatar
c63 amg
Amen.
Can't wait to get 265 on my rear.
Old Jan 30, 2010 | 05:38 PM
jfo53's Avatar
Bridgestones Are Fine But 265s Are Not
I replaced the rears with Bridgestone RE760s based on the Car & Driver article that ranked them as good as the Michelin PS2 Sport Pilots, which are considered the gold standard. My concern was that the Bridgestones would not stick as well as the PZeros in the front causing oversteer during high speed cornering since the Pirellis wear so quickly. This should be because of a stickier compound and thus the low 220 DOT Treadware Rating If I experienced oversteer, then I would replace the half worn front PZeros with the RE760s. But it turns out not to be the case. The car is nicely neutral proving the RE760s stick as well as the PZeros and cost much less. The DOT Treadwear Rating for the RE760 is 340, so they should last much longer. However, note that their 90Y load rating is less than the PZero's 95Y, which only becomes a factor if you are carrying four 350 lb. football players plus 150lbs of concrete in the trunk. By the way, think again about going to a 265 width over the stock 255 on the rears. This will increase the rolling circumference of the rear wheels and upset the ABS which is sensing the number of tire revolutions of each wheel. If you change the rolling circumference on the rears, you have to do it on the fronts also.
Old Jan 30, 2010 | 09:06 PM
sflgator's Avatar
'09 C63 AMG
RE760's are great tires, but still only got ~ 8k mi. out of them on the rear (265's), even w/ the 340 tread wear rating. Now I have the Michelin Pilot A/S Plus (all seasons w/ a 500 tread wear rating and a 45k mi. warranty ) on the rear.
Old Jan 30, 2010 | 10:56 PM
vitamink's Avatar
2009 C63
Thanks! I just put 265 on the rear and 245 on the front. I don't need to replace the front tires yet, but I got a decent deal ( at least I think) totally $725....so I changed all of them and keep old front tires in case I want to use them again..
Old Jan 31, 2010 | 05:34 PM
C63 AMG
You've resorted to an all-season tire in S. Florida?
Old Jan 31, 2010 | 10:18 PM
sflgator's Avatar
'09 C63 AMG
Hey, if they grip as well as the summer high perf., do well in the heavy rain, get at least 12k-15k mi. wear with their 500 tread wear rating AND carry a 45k mi. mileage warranty, then hell yeah, I'll ride on these Michelin Ultra-High Performance All Season tires!
I drive > 25k mi./year, so it gets really old (and expensive) having to change rear tires 3x-4x/year.
Old Jan 31, 2010 | 10:34 PM
jjb03's Avatar
c63 AMG, BMW 335 conv
This is total crap.
It does not upset the ABS at all.
I have gone to 275 rears as many others have done, no problems.
Old Feb 1, 2010 | 01:30 AM
BerBer63's Avatar
2009 C63
Just picked up some Vreds 275/30 out back.
Old Feb 4, 2010 | 01:19 AM
Vegas_AMG_C63's Avatar
AMG C63
How did they fit up? Usually Vreds are a bit narrow compared to other brands. Could you have fit a larger size?
