C63 Oil Change w/ Mityvac :: Write-up and Photos
I think my dealer charges $100 for an oil change...up to you if its worth the extra $30 to do it yourself. Probably kind of a "fun" job actually if you're used to working on cars, this will be one of those nice 15 minute accomplishments on a sunday morning that gets your day going
Good writeup OP!
Can't wait to read your Evosport rotor write-up!
Like I mentioned earlier, I was a bit low on oil to begin with. I evacuated approx. 7.5 liters of old oil. The old oil filled the Mityvac in-between the 7 and 8 liter line.
I filled it back up with the required 9-quarts.
The old filter comes out connected to the cap. The shaft remained attached to the bottom of the housing assembly.
I guess I'm just not that kind of guy to change oil by myself.
I turned my garage into a bar and I have 4 cars in my family.
If I were to have a free minute I would hang with my wife, kid, dogs, friends etc but not with an oil sucker.
Please don't find this rude it is just my 0.02
When I insert the vac line into the dipstick tube it certainly hits bottom.
I went back and measured again. I marked the vac line with a Sharpie, even with the top of the dipstick tube when fully inserted. Then I measured that portion of the vac line against the dipstick. The vac line goes in 1.5" deeper. I edited my previous comment. Thanks for pointing this out.
Here some quick pics. The vac line is pretty firm/coiled so I had to tie it to the dipstick so you could see the length/depth comparison.
I'm not going to argue with you.
All of the members are different "kind of guys" and all have their own "0.02 cents" and that is why we share our thoughts here on a public forum.
I wasn't saying anything bad about superlubricity's approach and I was not accusing him in anything and I'm NOT trying to make him feel "lame" for changing his oil. His write up is very informative and clear.
All I did was - share my thoughts.
-michael-, aren't you supposed to be hanging with your wife, kid, dogs and friends? Get off the forums, you are wasting quality time!
There's always www.bobistheoilguy.com if anyone wants to search....my laziness outweighs my curiosity on this topic
In my C63 I checked the oil before using my Mityvac to drain the oil. The dipstick showed it was 1.0 qt low. I removed 8.0 qts from the engine. I then filled the engine with 9.0 qts. Checked the dipstick again, and it was exactly at the "full" mark. So all of the oil was removed from the engine, based both on how much oil was removed and how much oil was in the engine after adding the correct amount.
I have used the Mityvac with M271 and M112 engines on my other cars, and the results are the same. On all of these cars, I have jacked the car up a bit in the front to see if I would get oil to drain to the rear of the engine, where the dipstick tube is - in each case I got all of an extra 0.05 qts of oil. So, the Mityvac removes all oil - you don't need to waste your time removing the drain plug.
I was once a skeptic, too -- when I first had my C230K I compared the amount of oil removed via the drain plug vs. the Mityac. There was no difference. Since then I am completely comfortable using the Mityvac.
