C63 AMG (W204) 2008 - 2015
C63 Oil Change w/ Mityvac :: Write-up and Photos
Old Mar 3, 2010 | 11:17 AM
  #51
racetested's Avatar
08 MB
This post might have made me a believer.
After so many years I am pretty sick of sliding under cars, having oil splash on me when the drain plug first drops, and having to store cardboard so oil doesn't splash on my garage floor.
Makes perfect sense to me to try one of these things out. Like others I have always heard mixed reviews but maybe the negatives were by people not doing it right.
Old Mar 3, 2010 | 10:30 PM
  #52
superlubricity's Avatar
Super Moderator Alumni
2011 GLK 350, 2013 GT-R, & 2013 RAM 1500
I found a great socket for the oil filter cap. I just test fitted it today and it fits like a glove!
It is 32mm and works with any 3/8 wrench. Only $6.99.
http://www.amazon.com/Lisle-14700-Fi.../dp/B0009OMYAQ
Old Mar 3, 2010 | 10:49 PM
  #53
MACHC5's Avatar
Veteran: Army
CLK63 Black, E350 Wagon, Supercharged Denali, Lotus Elise, Tesla Model 3 Dual-Motor.
Originally Posted by superlubricity
- Shaft appears to stay in place. Mercedes doesn't show/list the shaft as a separate item in the illustration below. (14 = Cap, 13 = O-ring, 12 = Filter, 10 = Housing/Base)
- I got the vac tube to go all the way down. I marked it with my hand and compared to the dipstick. They vac line goes about 1.5" deeper than the dipstick.
- I was about 1 quart low. Topped the Mityvac up to about 7.5 liters.
- 9-quarts got it back to full.
There are (2) oil pans, one front #6 & one rear #7 pan to drain on the 63's
Old Mar 4, 2010 | 12:25 AM
  #54
Sincity's Avatar
Good find. Now I need to find a few more items to hit $25 and get free shipping.
Old Mar 4, 2010 | 03:22 AM
  #55
blindfold's Avatar
C63
so is #7 pan lower than #6 pan, thus the mityvac is able to drain all the fluid? someone please confirm, thanks.
Old Mar 4, 2010 | 06:10 AM
  #56
avengerboater's Avatar
C63 AMG
Superlube, why is it that everything you purchase is off of Amazon? I'm just curious.
Old Mar 4, 2010 | 11:13 AM
  #57
matt55's Avatar
09 c63 10 c300 Nissan truck
As you can see on part #9 the dip stick tube angles off at the end. This is the spot where the vinyl tube hits resistance before going deeper. I cut a 45 angle at the end of the vinyl tube and it went easier. Super is right that the tube goes about 1.5 inches deeper than the dipstick but make sure you get the tube past that angle at the of the dip stick tube.
Old Apr 15, 2010 | 11:31 AM
  #58
Militia's Avatar
C63
Nice write up, will definitely come in handy!
Old Apr 15, 2010 | 12:21 PM
  #59
Glad I could help!
Old Apr 15, 2010 | 01:11 PM
  #60
AMMO1000hp's Avatar
C63
Fist off great writeup!
I am still a bit uneasy about this method though. I just don't see how this suction method could suck up any debris/particles when they would clearly sink to the lowest point of the pan. I would imagine that you may get some out but how would you really know you don't have bits of shaving, debris, ect.. still floating around down there? Sorry, I don't mean to be skeptic but I just would like to make just to get everything out of there especially for the first oil change after break-in is completed. After the first one I would definitely consider going about it using this method though.
Old May 23, 2010 | 04:08 PM
  #61
AMGC60-3's Avatar
W164 ML500,SMART For two,1994 C280(5speed manual) 1999 C230k station wagon
The filter socket is a must have, I bought one like 15 years ago from a German company called Hazet. Real handy thing to have.
Old May 24, 2010 | 12:07 AM
  #62
EUGENE-Taiwan's Avatar
Supercharged E92 M3
nice write up!
Old May 24, 2010 | 05:47 AM
  #63
_AMG_'s Avatar
C63
Why not just take it to the dealership?
Old May 30, 2010 | 10:39 PM
  #64
TTABrad's Avatar
2009 C63; Black/Sahara Beige; All but Tele-aid & CF; Infiniti M45; '89 Turbo Trans Am; Tahoe Z71;
Is there a computer reset necessary after changing the oil and, if so, does anyone know how to do it?
Old May 30, 2010 | 10:42 PM
  #65
Sincity's Avatar
I believe the reset procedure is in the manual.
Old May 31, 2010 | 11:09 AM
  #66
TTABrad's Avatar
I thought I had looked pretty close in the manuals, and I couldn't find the procedure. Anyone know where the process may be described? I apologize if it's real obvious and I'm just missing it.
Old May 31, 2010 | 02:24 PM
  #67
Mort's Avatar
Try this:
1.) Key in position 1
2.) Press Call Pickup and OK for 5 seconds
3.) Reset should be in menu that comes up
Work OK?
Old May 31, 2010 | 02:56 PM
  #68
TTABrad's Avatar
Thanks for the response. I got to the menu, found where it shows miles and time until next oil change, but cannot find how to reset.
Old May 31, 2010 | 03:06 PM
  #69
14cue's Avatar
05 C55
Nice work!
What you saved in labour helped pay for all those parts
I wish I had the patice to do this myself.
Old Jun 19, 2010 | 03:26 AM
  #70
DStrole's Avatar
2006 ML350
I need some help!! I over filled my ML350's engine oil this evening (about a quart as shown on the dipstick). The only reason I noticed was that as I drove home, about 2 miles, I noticed smoke coming out of the engine compartment. I stopped, opened the hood and on the left (passenger) side of the engine there was oil dripping all over the place. Now it is about 2 hous later and a lot of oil is dripping underneath the car. What is up?
Old Jun 19, 2010 | 05:02 PM
  #71
hcetzneb's Avatar
2004 Ran SRT-10,2007 S550,2016 E400c
Not to rain on everyones parade but the approved method of oil removal for 63/ 55 engines is to drain them... the reason is oil get trapped in the oil cooler in the front bumper... there is a drain plug on the bottom of it.. dealers do use extractors for other engines but never 63's it leaves about .5 to .75 of a quart in the engine
Old Jun 19, 2010 | 09:04 PM
  #72
No rain here.
As mentioned in previous posts, the extraction method outlined here is a great/no-mess "in-between" solution for those wanting more frequent changes than the factory recommended schedule. Draining via both plugs will remove more oil. Nobody is arguing that.
Old Jun 20, 2010 | 11:58 PM
  #73
Arclight338's Avatar
09 C63 11 E350
Originally Posted by Sincity
The dealer also extracts it from the top. This was discussed in the early 2000s here on mbworld and IIRC, the consensus was that extracting from top was as good as draining it.
Not according to my neighbor,who is a senior MB Tech. And I was able to watch my "A" service and the oil was indeed drained via the oilpan drain plug.
Very good write-up though and for the inexperienced that INSIST on doing their own oil changes,its safer than cross-threading the drain plug.
Old Jun 21, 2010 | 12:00 AM
  #74
09 C63 11 E350
Did you properly install the fill cap?
Old Jun 21, 2010 | 10:34 PM
  #75
DStrole's Avatar
2006 ML350
Tanks for your note. Yes, the fill cap was properly threaded and tight.
